Old 11th November 2015, 12:34   #541  |  Link
Khanattila
Khanattila's Avatar
A few more slight adjustment.
https://github.com/Khanattila/KNLMea...ses/tag/v0.7.3
KNLMeansCL v0.7.3
* Removed 'default' and 'all' device_type.
* More controls of the OpenCL platform.
* Better error handling.
* VapourSynth: fixed frame properties.
github.com
Khanattila is offline   Reply With Quote
Old 11th November 2015, 14:22   #542  |  Link
Reel.Deel
Hi Khanattila,
KNLMeansCL works fine with AviSynth+ r1576 but with x64 I get this error message:
Avisynth read error: KNLMeansCL: fatal error! (AviSynthGetFrame)
Old 11th November 2015, 14:42   #543  |  Link
Khanattila
Khanattila's Avatar
Originally Posted by Reel.Deel View Post
Hi Khanattila,
Script?
github.com
Old 11th November 2015, 14:43   #544  |  Link
Reel.Deel
Originally Posted by Khanattila View Post
Script?
ColorBars(pixel_type="YV12")
KNLMeansCL()
Old 11th November 2015, 14:52   #545  |  Link
~ VEGETA ~
The cult of personality
~ VEGETA ~'s Avatar
It's faster than the original but still very slow compared to KNLMeansCL.
I did some tests here.
I used dfttest rather than tnlmeans and it was extremely slow! is it at least faster than this?
~ VEGETA ~ is offline   Reply With Quote
Old 11th November 2015, 15:50   #546  |  Link
Groucho2004
It mostly depends on your CPU. Also, it takes less time to try it out than to write all these posts.
Old 11th November 2015, 16:13   #547  |  Link
Groucho2004
Works for me (WinXP64SP2):
[General info]
Log file created with:                 AVSMeter 2.1.5 (x64)
Script file:                           F:\test.avs
Command line switches:                 -log -gpu
Avisynth version string:               AviSynth+ 0.1 (r1576, x64)
Avisynth file version:                 2.6.0.5
Avisynth Interface Version:            5
Avisynth MT support:                   No
Avisynth.dll linker/compiler version:  11.0
Avisynth.dll location:                 D:\WINNT\system32\AviSynth.dll
Avisynth.dll time stamp:               2014-01-03, 17:11:18
PluginDir2_5  (HKLM, x64):             E:\Apps\VideoTools\AvisynthRepository\AVSPLUS_x64\plugins
[Clip info]
Number of frames:               107892
Length (hh:mm:ss.ms):     00:59:59.996
Frame width:                       640
Frame height:                      480
Framerate:                      29.970 (30000/1001)
Colorspace:                       YV12
Audio channels:                      2
Audio bits/sample:                  16
Audio sample rate:               48000
Audio samples:               172799827
[Runtime info]
Frames processed:               320 (0 - 319)
FPS (min | max | average):      64.64 | 65.75 | 65.49
Memory usage (phys | virt):     34 | 73 MB
Thread count:                   8
CPU usage (average):            25%
GPU usage (average):            95%
Video engine load (average):    0%
GPU memory usage:               61 MB
Time (elapsed):                 00:00:04.887
[Script]
KNLMeansCL()
[Graphics card info]
Card name:               NVIDIA GeForce GTX 750
GPU name:                GM107
Memory size:             1024
OpenCL version:          OpenCL 1.2 CUDA
Driver version:          6.14.13.5012 (ForceWare 350.12) / XP64
Info collected with:     GPU-Z 0.8.6
Old 11th November 2015, 19:12   #548  |  Link
Reel.Deel
That's odd, it also works on my work computer. Last time I had problems with KNLMeansCL my home computer worked but not my work computer . If it's a driver issues, it's kinda weird that it works in 32-bit but not 64-bit. Anyways when I get home I'll update drivers and report back.
Edit: It turned out out to be a drive issue. Sorry for another false alarm . The drivers were not that outdated but I guess it requires the latest and greatest.
Old 11th November 2015, 20:08   #549  |  Link
kalehrl
Hi Khanattila,
I complained some time ago that knlmeanscl didn't work when using x264 encoder with MeGUI.
I just tested the latest version and it works now.
In the meantime, I updated my AMD driver to the latest beta instead of the latest release which I used before.
Also, there were some MeGUI updates as well.
Not really sure what fixed it but the important thing is, it works now!
kalehrl is offline   Reply With Quote
Old 12th November 2015, 16:15   #550  |  Link
Khanattila
Khanattila's Avatar
Happy that everything seems to be working.
github.com
Old 12th November 2015, 17:18   #551  |  Link
Xebika
I can't get it to work with both the newest Nvidia driver for my GeForce GTX 960 in Win 10 x64 because it crashes, i also tried replace with the included DLL from the v0.7.3 release.
And tried with an older version of the driver but the same result.
Xebika is offline   Reply With Quote
Old 12th November 2015, 19:04   #552  |  Link
Khanattila
Khanattila's Avatar
Some more details? I tried a GTX 760 in Win 10 x64 and seems to work.
github.com
Old 13th November 2015, 06:10   #553  |  Link
Xebika
Which details do you need??
Old 13th November 2015, 10:13   #554  |  Link
Khanattila
Khanattila's Avatar
VapourSynth or AviSynth? Which version? Script used? Crashes without giving some error code?
I also need a report by GPU Caps Viewer 1.25.0: http://www.geeks3d.com/20150821/gpu-...l-opencl-cuda/
(tool -> export data -> http://pastebin.com/hF6F59Ks)
Can be any type of error.
Have you tried to do a clean installation of the drivers?
PS. Previous versions of KNLMeansCL will work? Probably I forgot something.
github.com
Old 13th November 2015, 17:11   #555  |  Link
Khanattila
Khanattila's Avatar
Only NVIDIA requires a recent driver and the last ones are only for marketing.
github.com
Old 13th November 2015, 19:54   #556  |  Link
Xebika
AviSynth 2.6 x86
I think maybe it approaches freezes then crash, and didn't have any choices then close it
Script:
DGSource("C:\Video\Video.dgi",fieldop=0, deinterlace=1)
crop(18, 36, -10, -8)
Spline36Resize(768,576) # Spline36 (Neutral)
Levels(5, 1, 255, 0, 255)
SmoothContrast(contrast=0.1, sat=0.2)
LSFmod(defaults="slow")
KNLMeansCL(D=1, A=1, h=4.5)
GPU Caps Viewer Report: http://pastebin.com/5DPK2Wqt
I have tried both clean installation of windows and drivers
Last working release is v0.6.11
Old 13th November 2015, 22:20   #557  |  Link
Khanattila
Khanattila's Avatar
AviSynth 2.6 x86
Script:
Since I updated OpenCL APIs from 1.1 to 1.2 you have these problems... Thank you NVIDIA. I have to investigate a bit.
github.com
Old 19th November 2015, 17:46   #558  |  Link
Khanattila
Khanattila's Avatar
AviSynth 2.6 x86
Script:
I do not see anything strange...
You could try running "OpenCL Device Query" and post the results.
github.com
Old 19th November 2015, 18:06   #559  |  Link
Xebika
Here: http://pastebin.com/6Ey7bPuA
Old 19th November 2015, 23:12   #560  |  Link
Khanattila
Khanattila's Avatar
It really is a problem that I do not understand.
You can try this last attempt: replace "C:\Windows\System32\OpenCL.dll" with "C:\Program Files\NVIDIA Corporation\OpenCL\OpenCL.dll".
Also you can this program to see if there are all dependencies files.
In some configurations is not used OpenCL.dll in the System32 folder.
(File ==> Open ==> KNLMeansCL.dll)
github.com
