Old 26th May 2008, 11:05   #2101  |  Link
Kado
Otaku
Kado's Avatar
Originally Posted by Gawwad View Post
on nvidia 8600GT HD apple trailers (and other HD .mov trailers) do not work with DXVA for some reason
e.g. http://www.jurassicpunk.com/clips/wa...ailer.480p.mov
i renamed the extension to .hdmov
without DXVA:
with DXVA:
on ati HD 2600XT, all HD apple trailers (and other HD .mov trailers) 480p, 720p and 1080p plays perfectly with DXVA
Confirmed for mpc internal dxva, but cyberlink's decoder does not produce that even when using dxva.
In the school, the three guys met. Their relation had been changed in the season, and turned into three love stories.
Kado is offline
Old 26th May 2008, 11:14   #2102  |  Link
Kado
Otaku
Kado's Avatar
Originally Posted by Aleksoid1978 View Post
Probably work only DXVA2 mode - but on XP ModeH264_VLD_NoFGT only DXVA1
Because XP has no dxva2 support.
Kado is offline
Old 26th May 2008, 12:45   #2103  |  Link
frequenzy
System specs:
intel e8200
abit-in73hd w/ onboard video
4GB RAM
vista ultimate x64 sp1
mpc-hc build 518
when I try to play this video (wmv 1080p)
http://download.microsoft.com/download/9/2/b/92b48c2f-cc5a-4d15-ae40-30ec542db8bb/Dolphins_1080.exe
not fullscreen - works perfectly
fullscreen - lags and stutters
Tried using bsplayer and windows media player - video played fine on fullscreen mode
any ideas??? I would really like to use MPC-HC
frequenzy is offline
Old 26th May 2008, 12:49   #2104  |  Link
_xxl
ffdshow user
_xxl's Avatar
mpc
Is this encoded with slices?
_xxl is offline
Old 26th May 2008, 13:02   #2105  |  Link
Aleksoid1978
Aleksoid1978's Avatar
Why HW Decoding work using Cyberlink H.254/AVC Decoder ???
on FullHD 1920x1080 SpiderMan - CPU load 5-15%, PitInfo - DXVA.
whan use DXVAChecker.exe on XP, it show:
Cyberlink(PDVD7.x) support ModeH264_VLD_NoFGT on DXVA1
Cyberlink(PDVD8.x) support ModeH264_VLD_NoFGT on DXVA2
MPC - Video Decoder support ModeH264_VLD_NoFGT on DXVA1.
But why last build not work on XP - on first post write that on XP - DXVA1+WMR, Overlay
to Casimir666 - last build must work on XP on Nvidia or NOT, it work only on DXVA2 ???
P.S. - But DXVA1 fine work on 'right' rip where ref_num<=4. Turns out that(sorry for this English ) last Casimir666 "New release that should solve the macroblocking problem for the nVidia graphics card" work only on VISTA/DXVA2 ??? Can you do it and for DXVA1(XP)
Aleksoid1978 is offline
Old 26th May 2008, 15:11   #2106  |  Link
lexor
that can't be right, I have ref=8, bframes=4 (do bframes matter for this?) encode that plays fine on XP with MPC+DXVA1.
On a different note, is anyone maintaining an up-to-date compiles of MPC? I'm interested in trying 523build to see if some of my files may play now that SAR restriction is removed.
Geforce GTX 260
Windows 7, 64bit, Core i7
MPC-HC, Foobar2000
lexor is offline
Old 26th May 2008, 15:50   #2107  |  Link
carnage_pl
carnage_pl's Avatar
Can someone tell me what the EVR buffers are and what is the difference between 3 and 20 ?
carnage_pl is offline
Old 26th May 2008, 16:05   #2108  |  Link
MatMaul
please test these samples :
http://www.etud.insa-toulouse.fr/~mv...in_profile.mp4
http://www.etud.insa-toulouse.fr/~mv...rdel/cavlc.mp4
does it work with earlier revision ?
EDIT :
some sliced samples for testing too :
http://www.etud.insa-toulouse.fr/~mv...slice_high.mp4
http://www.etud.insa-toulouse.fr/~mv...slice_main.mp4
http://www.etud.insa-toulouse.fr/~mv...lice_cavlc.mp4
MatMaul is offline
Old 26th May 2008, 16:36   #2109  |  Link
gngn
the hedgehog
gngn's Avatar
could you please upload a sample of this video with ref=8 ? i am a big anime-fan, so i have a lots of different encoded files, and none with ref>4 will play with MPC-HC. the makroblocking issue of some files is now gone with the r523 that Casimir666 posted.
Athlonx2@2,9Ghz,2G DDRAM2@800Mhz,WinXPSP3 x86,GF8600GTS-256M,Nvidiadrivers 295.73
latest MPC-HC (MVS2010 SP1, GCC 4.7.1)
VMR9renderless+VMR9MixerMode+YUVMixing,VSync+AccurateVSync,all GPUflushes on
gngn is offline
Old 26th May 2008, 16:46   #2110  |  Link
STaRGaZeR
4:2:0 hater
Dumb question guys: can DXVA be used in Vista64 using Overlay? I know that currently it's not supported though.
Also another question: When playing a file in MPC-HC with Vista 64 at least, changing volume using the keyboard buttons for example results in only changing the volume slider INSIDE MPC-HC, not the master volume of the OS. BSPlayer, WMP, etc. can do it perfectly. Is there any option to enable this? Because when MPC-HC slider is also at its higher value, I have to minimize it and then up the volume, which is annoying as hell.
Thanks for the program
STaRGaZeR is offline
Old 26th May 2008, 17:34   #2111  |  Link
Casimir666
We haven't made test on XP, but it should works (using DXVA1)
It's the number frames decoded in advanced (to keep playback smooth). In my opinion around 5 for this parameter is a good choice.
Tired of tearing?
Try this Media Player Classic mod : http://mpc-hc.sourceforge.net
Casimir666 is offline
Old 26th May 2008, 18:05   #2112  |  Link
Mercury_22
Any chance for a MPC-HC r523 x64 build ? Please !
Mercury_22 is offline
Old 26th May 2008, 18:39   #2113  |  Link
Vepar
Vepar's Avatar
I have small request to the developers. Could you please include mpc-hc build number somewhere on the about page or window titlebar or just add it to current version. I am really confused which build i currently have
As for DXVA i can confirm that my GPU is correctly recognized (8800gt) and DXVA works under Vista x64 sp1 for most movies that it didnt before but DONT work under XP sp2 (black screen. video not playing)
Also i can confirm that Apple trailers doesnt play (green screen). Tested on Dark Knight trailer.
Anyway, good work guys
Vepar is offline
Old 26th May 2008, 19:02   #2114  |  Link
Gawwad
newbie
Gawwad's Avatar
Originally Posted by MatMaul View Post
these 2 samples work perfectly with DXVA using the new release
but they did not work with DXVA using 522 build, because 522 build never supported DXVA with nvidia properly
the new release also didn't play this sample properly with DXVA:
http://rapidshare.com/files/11780178...eview.mkv.html
Gawwad is offline
Old 26th May 2008, 19:10   #2115  |  Link
MatMaul
I edit my previous post with new samples
MatMaul is offline
Old 26th May 2008, 19:46   #2116  |  Link
Vepar
Vepar's Avatar
vista x64 sp1 - 8800gt
mpc-hc r522 -> DXVA not used
mpc-hc (the one with GPU detection Casimir posted)
plays fine with DXVA
2/3 of the screen is green
Vepar is offline
Old 26th May 2008, 19:50   #2117  |  Link
MatMaul
ok so definitely a bug with slices.
seems to decode properly only the first slice (these samples have 4 slices per frame)
MatMaul is offline
Old 26th May 2008, 19:53   #2118  |  Link
Gawwad
newbie
Gawwad's Avatar
they do not work properly with DXVA
this is what i get when i play them with DXVA:
note: i tried the new build with over 70 proper 720p HDRip (from BluRay & HDDVD source), and they all work perfectly with DXVA and nvidia 8600GT
Gawwad is offline
Old 26th May 2008, 20:13   #2119  |  Link
ghostonline
I have an odd problem. last weekend, my friend showed me a chinese subtitle(*.ass) for the japanese anime 5CM (dvdrip-mkv & bdrip-m2ts).
his pc: q6600, 9800gtx, xp sp2
1. set mpc internal subtitle buffer to 0, and maximum texture resolution to Desktop.
2. output vmr9 renderless, cyberlink pdvd h264 decoder (dxva enabled)
at the end of anime, when the subtitle special effect starts(words fade in, fade away), the render properties shows frames dropped... the cpu usage is only around 16%.. this is a h264 encoded dvdrip-mkv. bdrip version with this same subtitle file only makes frames drop faster....
reduce maximum texture resolution will also reduce number of frames dropped.
this is kind of strange. I don't get why frames get dropped.
I tested on my own setup
qx9650
9800gx2
mpc-hc r523
vista64 sp1 (evr custom pres.)/xp sp2 (vmr9 renderless)
same behavior...
cpu is no where maximized. I just don't get why frames get dropped..
the funny part is: wit dxva enabled, the cpu is only working on subtitle and it still drop frames....
ghostonline is offline
Old 26th May 2008, 20:32   #2120  |  Link
shaolin95
Does anyone have the latest r523 (or is it r522) compiled?
shaolin95 is offline
dxva, h264, home cinema, media player classic, mpc-hc
