Old 11th September 2012, 19:08   #20141  |  Link
v0lt
What do you think about moving the mixer from MpaDecFilter to AudioSwitcher? And about removing the "custom channel mapping"?
v0lt is offline
Old 11th September 2012, 20:22   #20142  |  Link
Mercury_22
Do not remove the "custom channel mapping"!!!!!!!!!!!!!!!!!
And yes "moving the mixer from MpaDecFilter to AudioSwitcher" seems a good idea
EDIT : Also it will be nice if you could add independent volume levels for each channel like in FFD
Windows 10 19042.508 x64, HD7790 Adrenalin 2020 Edition 20.9.1, HDMI Full RGB 4:4:4
Mercury_22 is offline
Old 11th September 2012, 20:25   #20143  |  Link
betaking
Fantasy Codecs writer
betaking's Avatar
+1!I also agree with you!
betaking is offline
Old 11th September 2012, 22:19   #20144  |  Link
jq963152
Hello,
with MPC-HC x64 1.6.3.5818, hardware acceleration apparently is not used on videos with resolutions beyond 1920x1080?
Why is that?
And is there any way to use hardware acceleration on videos with resolutions beyond 1920x1080?
Thanks in advance.
jq963152 is offline
Old 12th September 2012, 03:25   #20145  |  Link
v0lt
Call type of your video card.
v0lt is offline
Old 12th September 2012, 03:56   #20146  |  Link
JanWillem32
JanWillem32's Avatar
@jq963152: It's at the bottom of the page: https://github.com/mpc-hc/mpc-hc/blo...pegContext.cpp . There are restrictions to the size. If you see any case that needs to be corrected, please give us some documentation. We can then patch these items.
development folder, containing MPC-HC experimental tester builds, pixel shaders and more: http://www.mediafire.com/?xwsoo403c53hv
JanWillem32 is offline
Old 12th September 2012, 13:44   #20147  |  Link
jq963152
Thanks for your replies.
NVIDIA GeForce GT 520 (GF119)
Well, not sure, not a programmer, but the text from your link apparently states the following (among other things):
Originally Posted by https://github.com/mpc-hc/mpc-hc/blob/master/src/filters/transform/MPCVideoDec/FfmpegContext.cpp
https://github.com/mpc-hc/mpc-hc/blob/master/src/filters/transform/MPCVideoDec/FfmpegContext.cpp#L165
nVidia cards support level 5.1 since drivers v6.14.11.7800 for XP and drivers v7.15.11.7800 for Vista/7
https://github.com/mpc-hc/mpc-hc/blo...ntext.cpp#L188
HD4xxx, HD5xxx, and HD6xxx AMD/ATI cards support level 5.1 since drivers v8.14.1.6105 (Catalyst 10.4)
And at least according to Wikipedia:
http://en.wikipedia.org/wiki/H.264/MPEG-4_AVC#Levels
AVC HP@L5.1 apparently would allow for much higher resolutions than 1920x1080, wouldn't it?
Also, in the LAV Filters thread apparently the following was posted:
Only Ivy Bridge does 4K decoding, if you're running it on your 2500k from your signature, no 4K for you.
NVIDIA (via CUVID) only supports it with VP5 (VDPAU Feature Set D). AMD claims to support it with the 7xxx series, but in my tests, it just failed miserably.
Originally Posted by Pat357 View Post
Try it with LAV CUDA or LAV CB, as in these modes IIRC, there are no blocks on any resolutions. (res > 1080p HD)
LAV Native DXVA might block some res. higher then 1920x1088 IIRC
And apparently when playing back 3840x2160 video here for example with a GT 520, hardware acceleration apparently is only shown as "active" in the LAV Video Configuration panel when it is set to LAV CUVID or LAV DXVA2 (copy-back).
But when setting it to LAV DXVA2 (native) or when using internal MPC-HC Video Decoder it apparently is falling back to software decoding.
Why are resolutions beyond 1920x1080 blocked with LAV DXVA2 (native) and internal MPC-HC Video Decoder (which is DXVA2 native as well, isn't it?)?
jq963152 is offline
Old 12th September 2012, 14:01   #20148  |  Link
nevcairiel
Its blocked with DXVA2 Native in LAV because auto-detection of 4k support is not working properly, and if it enabled it but doesnt support it, you get a black screen, which is no good.
Either i'll have to fix the auto-detection (might be tricky) or simply add a checkbox so people can turn on 4k DXVA if they think their Hardware can do it.
In any case, I've been rather busy with a lot of different things over the last few weeks, and not much got done.
nevcairiel is offline
Old 12th September 2012, 14:06   #20149  |  Link
jq963152
But with VP5 you would not get a black screen, or would you ?
That would probably be appreciated .
jq963152 is offline
Old 13th September 2012, 13:36   #20150  |  Link
jq963152
No reply from you ?
jq963152 is offline
Old 13th September 2012, 16:57   #20151  |  Link
JanWillem32
I recently patched some of the DXVA code, so I know what variables are stored and how these are used. You can take a look at the registry part that is read for this function by using regedit.exe . The keys for the various video adapters are listed in "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Video" . The correct adapter is selected by using the monitor handle. The device and driver identifier keys can be seen under the "0000" key.
Here comes the problem: only very few keys in there are standardized, the rest is driver-specific.
The three identifiers that are stored are the vendor ID, the hardware ID and the driver revision. The device and hardware ID is in plain text. For example, my video adapter is; "pci\ven_1002&dev_9460" . http://www.pcidatabase.com/search.ph..._search=Search
These three numbers are used to determine the capabilities of the device and driver, as you can see in the link I posted to the source code. These values are acquired by reading spec sheets and by trial and error testing. There are no ways to directly query these detailed things from the standard driver-linked interfaces in software.
So what we need is data on what manufacturer ID, what device ID or which series of IDs and which driver revisions have which specific capabilities.
Old 13th September 2012, 17:13   #20152  |  Link
jq963152
Could you possibly do something similar to what "nevcairiel" suggested for LAV Filters:
At least as long as auto-detection is not working properly?
Suggestion:
In MPC-HC x64 1.6.3.5818, if you go to:
Filters ---> MPC-HC Video Decoder ---> DXVA Settings ---> DXVA (H.264) Compatibility check
apparently you can choose between:
Full check, Skip level check, Skip ref frame check, Skip all checks
So how about adding something like "Skip width and height check" or "Skip resolution check" or "Skip framesize check" or something like that ?
jq963152 is offline
Old 13th September 2012, 19:20   #20153  |  Link
v0lt
jq963152
Nvidia cards can not decode 4k in DXVA mode. Tested on GTX 680.
Nvidia cards are limited:
width <= 2032 && height <= 2032 && width*height <= 8190*16*16
Nvidia officially declares support for the width and height of 2048 pixels and 8192 macroblock for H264, but this is not true.
Why? Will you look at the a black square?
There were cases in the fall of BSOD.
v0lt is offline
Old 13th September 2012, 19:33   #20154  |  Link
Keiyakusha
契約者
Keiyakusha's Avatar
Does it work in cuvid mode? Do they really say it should work with DXVA, or they say that this is theoretical limit of the engine? Cause this is different things... Maybe its dxva-specific limitation, which you can expect from such old technology. Also noone cares much about dxva these days
Keiyakusha is offline
Old 13th September 2012, 20:43   #20155  |  Link
v0lt
MPCVideoDec does not support cuvid mode.
v0lt is offline
Old 13th September 2012, 20:50   #20156  |  Link
Keiyakusha
契約者
Keiyakusha's Avatar
I know. But you better check it too before saying that nvidia's hardware doesn't supports what it claims. Does they realy say it should work with DXVA, or they say the hardware is capable of decoding 2048 pixels and 8192 macroblock? You didn't answered.
Old 13th September 2012, 21:09   #20157  |  Link
v0lt
Nvidia says about DXVA. I and a few people checked DXVA. For our decoder such check is sufficient.
I specifically checked in CUVID (LAV Video Decoder 0.51.3). It does not support for the width and height of 2048 pixels and 8192 macroblocks. Nvidia is lying.
v0lt is offline
Old 13th September 2012, 21:22   #20158  |  Link
Keiyakusha
契約者
Keiyakusha's Avatar
At this moment LAV won't allow you to do it even if it will work. <-- edit: judging from the post below this maybe not very true
But if they say DXVA should work, that's too bad =(
On other forums people claim nvidia really decodes what it says, but not in DXVA
Old 13th September 2012, 22:16   #20159  |  Link
jq963152
But what about what Wikipedia says for example:
Originally Posted by en.wikipedia.org/wiki/Nvidia_PureVideo#The_Fifth_Generation_PureVideo_HD
http://en.wikipedia.org/wiki/Nvidia_PureVideo#The_Fifth_Generation_PureVideo_HD
The Fifth Generation PureVideo HD
The fifth generation of PureVideo HD, introduced with the Geforce GT 520 and also included in the Nvidia GeForce 600(Kepler) series GPUs has significantly improved performance when decoding H.264, VC-1 and MPEG-2 codecs [8]. It is also capable of decoding 4K resolution videos at 3840 x 2160 pixels, (doubling the 1080p high-definition television standard in both the vertical and horizontal dimensions), also known as Quad Full High Definition (QFHD). Also MVC (Multiview Video Coding) H.264 decoding support for Blu-ray 3D and other Full HD 3D at 1080p.[9]
Originally Posted by en.wikipedia.org/wiki/Nvidia_PureVideo#Feature_Set_D
http://en.wikipedia.org/wiki/Nvidia_...#Feature_Set_D
Feature Set D
Introduced 4K resolution / QFHD video decoding at up to 3840 x 2160 pixels
Tested on GTX 680.
How did you test that if it is currently blocked in MPC-HC?
Is this:
http://us.download.nvidia.com/XFree8...limits-decoder
your source for what you just posted?
From the LAV Filters thread:
Just tried using LAV CUVID and LAV DXVA2 (copy-back) on the 2560x1440p video and apparently it does work (both apparently are shown as being "active" in the LV Video Configuration panel) .
Also tried 3840x2160p testclip with LAV CUVID and LAV DXVA2 (copy-back). Apparently both are shown as being "active" in the LAV Video Configuration panel when playing back. But it appears to be very laggy with LAV DXVA2 (copy-back). With LAV CUVID it appears to be much better, although, unfortunately, not necessarily perfect either.
See above.
Using GT 520 (GF119) here with LAV Filters 0.51.3, both, LAV CUVID and LAV DXVA2 (copy-back) apparently are shown as being "active" in the LAV Video Configuration panel when playing back 3840x2160p testclip and even when playing back 4096x2304 testclip. But, as mentioned in the quote above, it appears to be very laggy with LAV DXVA2 (copy-back). With LAV CUVID it appears to be much better, although, unfortunately, not necessarily perfect either.
So why do you write it would not work?
Or has it something to do with 8192 macroblocks?
jq963152 is offline
Old 13th September 2012, 22:39   #20160  |  Link
nevcairiel
4K decoding works with CUVID on my 680.
I'll look into DXVA soon, there were some driver bugs that caused it to fail in earlier versions, but maybe those are fixed now.
Thats because the 520 does not have enough memory bandwidth for "copy back" modes like CUVID or DXVA2-CB, its to be expected, the card is too weak.
Although the decoder chip isn't really all that fast on 4K content either, it can do 24p just fine, but above 30fps it'll start to lag.
dxva, h264, home cinema, media player classic, mpc-hc
