Old 15th September 2022, 05:11   #1  |  Link
birdie
Artem S. Tashkinov
birdie's Avatar
Open source machine learning for video compression
Details and claims
Using open source software, Collabora has developed an efficient compression pipeline that enables a face video broadcasting system that achieves the same visual quality as the H.264 standard while only using one-tenth of the bandwidth.
https://www.youtube.com/watch?v=jGQeuOacxSE
birdie is offline   Reply With Quote
Old 15th September 2022, 19:54   #2  |  Link
Blue_MiSfit
Derek Prestegard IRL
Blue_MiSfit's Avatar
Sure, I've seen a few apps like this. They're not really sending video per-se. It's more like some image data and some data about how to move that image data around to get motion. Kind of like motion compensation taken _way_ further, but very specialized
Old 16th September 2022, 01:50   #3  |  Link
MasterNobody
Yes, pretty much it is generated talking head (and probably can't generate anything else like for example soccer video). Also this talking head looks plastic and emotionless.
Eyes only look straight, the tongue is almost invisible.
There are no wrinkles on the forehead showing expression. And something is wrong with the teeth.
MasterNobody is offline   Reply With Quote
Old 16th September 2022, 04:24   #4  |  Link
rwill
Reminds me of this:
https://www.matrox.com/sites/default..._datasheet.pdf
"Matrox HeadCasting™ Engine
The unique Matrox HeadCasting™ Engine is designed specifically to accelerate the animation of a high-definition 1, photo-realistic 3D version of your head in real time, while offloading your CPU."
artificial_intelligence
