Old 9th April 2023, 13:21   #801  |  Link
MartinEesmaa
Hi, Gravitator!
It seems vvencapp reported an error message of your sample file:
Parameter Check Error: Detected non-standard Frame Rate 13978/583 (23.98 Hz). Default TicksPerSecond (27000000) can not be used. possible TicksPerSecond: 8149174
You need to add --tickspersec -1 or possible number of console said example 8149174 on vvencapp console command to encode probably VVC video.
I encoded your sample file on my FFmpeg VVCEasy command, but three duplicated frames:
ffmpeg_vvceasy -i space_6s.mkv -c:v libvvenc -preset faster -b:v 0 -qp 30 y4m.266
frame= 149 fps= 16 q=0.0 Lsize= 902kB time=00:00:05.96 bitrate=1238.5kbits/s dup=3 drop=0 speed=0.631x
video:902kB audio:0kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 0.000000%
- Martin Eesmaa
MartinEesmaa is offline   Reply With Quote
Old 9th April 2023, 13:36   #802  |  Link
Gravitator
It doesn't help.
Win10x64, Xeon E5450, GTX 750 2GB, DDR3 8GB.
Gravitator is offline   Reply With Quote
Old 9th April 2023, 13:39   #803  |  Link
MartinEesmaa
Why it doesn't help?
I know why ticks per second could be quite moderate difficult, but I hope Multicoreware x266 encoder doesn't need ticks per second necessary, so we should wait a little bit to get x266 encoder in H2 2023.
Here is the transcoded from your matroska sample file to Y4M report:
YUV4MPEG2 W1920 H1080 F13978:583 Ip A1:1 C420mpeg2 XYSCSS=420MPEG2
Try change from F13978:583 to F24000:1001 without using tickspersecond command.
- Martin Eesmaa
Old 9th April 2023, 13:49   #804  |  Link
Gravitator
The output of the parameter validation error continues.
Old 9th April 2023, 13:52   #805  |  Link
Gravitator
This problem has a connection with the output of yuv4mpegpipe (rawvideo goes without an error).
Old 9th April 2023, 13:59   #806  |  Link
MartinEesmaa
Oh ok, I see the rawvideo does not have problems, but Y4M does only some errors for some reasons of frame rate per second.
I looked issue for reference: https://github.com/fraunhoferhhi/vvenc/issues/252.
This could be bug for Fraunhofer HHI VVC encoder.
Maybe I encoded your sample file to libx264 with matroska container without duplicates frames, but encoding to raw bitstream reports duplicate frames. So I think VVC matroska is not finished yet.
I think Fraunhofer HHI VVC encoder is experimental I'd say, but I recommend we wait for Multicoreware x266 encoder or just make issue/discussion to vvenc github repository.
- Martin Eesmaa
Old 9th April 2023, 14:29   #807  |  Link
Gravitator
They are already treating > https://github.com/fraunhoferhhi/vvenc/pull/255
Old 9th April 2023, 15:30   #808  |  Link
Gravitator
Replace --tickspersecond -1 with --tickspersec -1 > It's going fine now
Old 10th April 2023, 01:03   #809  |  Link
MartinEesmaa
Sorry, my bad. It's tickspersec, not tickspersecond. I hope the tickspersec -1 is gonna encode probably.
- Martin Eesmaa
Old 16th April 2023, 21:56   #810  |  Link
Yups
chipsandcheese compared HEVC, AV1, VVC....interesting read.
Codecs for the 4K Era: HEVC, AV1, VVC and Beyond
Yups is offline   Reply With Quote
Old 17th April 2023, 08:38   #811  |  Link
birdie
Artem S. Tashkinov
birdie's Avatar
From the research: "VVenC is still in heavy development and doesn’t currently support CRF. Therefore, we use the next best option – two-pass variable bitrate (VBR) – for VVC"
What? What version did they use? From 2 years ago?
From https://github.com/fraunhoferhhi/vvenc/wiki/Usage
--qp,-q 	32 	Quantization parameter (0..63)
which is basically CRF.
birdie is offline   Reply With Quote
Old 17th April 2023, 09:19   #812  |  Link
nevcairiel
QP and CRF is not the same. CRF will modify the QP to compensate for frame complexity, providing similar "perceived" quality for all frames, while keeping bitrate in check.
Constant QP is the simplest compression mode you can think of, really, as you don't do any rate-control at all.
nevcairiel is online now   Reply With Quote
Old 17th April 2023, 16:47   #813  |  Link
hajj_3
it says they used v1.7.0 which was released 5 months ago.
Old 22nd May 2023, 11:21   #814  |  Link
birdie
Artem S. Tashkinov
birdie's Avatar
A native VVC decoder has been submitted to FFmpeg: https://www.mail-archive.com/ffmpeg-...eg.org/#147681
There's a number of objections, so it's not yet a done deal.
Old 31st May 2023, 02:41   #815  |  Link
Dann0245
Is VVC film grain synthesis real?
https://github.com/fraunhoferhhi/vvenc/issues/278
Dann0245 is offline   Reply With Quote
Old 31st May 2023, 12:55   #816  |  Link
quietvoid
Film grain synthesis in VVC would probably be based on the H.274 Film grain characteristics SEI.
Given HEVC supports it, I assume VVC will as well.
LG C2 OLED | GitHub Projects
quietvoid is offline   Reply With Quote
Old 1st June 2023, 23:32   #817  |  Link
benwaggoner
The AV1 FGS implementation seems richer (although still with its own issues). And it's entirely post processing. I've heard interest in letting VVC be able to access that mode as well via SEI.
Ben Waggoner
My Compression Book
Old 29th June 2023, 23:39   #818  |  Link
ShortKatz
Seems some parts have been checked in to the main code now. But I have no idea which parts and which VVC functions FFmpeg now has.
ShortKatz is offline   Reply With Quote
Old 4th July 2023, 10:29   #819  |  Link
birdie
Artem S. Tashkinov
birdie's Avatar
Native VVC support is a go! I guess we'll have preliminary support very soon, in less than a month.
Old 5th July 2023, 19:59   #820  |  Link
ShortKatz
That would be wonderful. At the moment the decoder/encoder is still missing. You can mux a VVC stream from e.g. a MP4 container into a MKV container. But converting the VVC stream into any other format fails. Same for converting any video stream into VVC.
