18th January 2016, 06:12 | #81 | Link | ||
Is the 2015 10 23 version the best version to use? |
18th January 2016, 06:43 | #82 | Link | |
I give you this version to avoid performance problems that may occur, I use "2015 9 10" until today, but I currently do experiments in the quality difference between the two and seems that "2015 10 23" is better until now, except it faster and more stable in performance
See My Avisynth Stuff |
18th January 2016, 10:33 | #84 | Link | |
http://forum.doom9.org/showthread.ph...30#post1325630 It removes blinking lines on top or bottom, but this was in 2009 for Yadif, and as he told it was used by TGMC, I guess it's also used by QTGMC and is maybe not needed in that case. |
18th January 2016, 14:40 | #85 | Link | |
18th January 2016, 22:26 | #86 | Link | |
18th January 2016, 23:26 | #87 | Link | |
See My Avisynth Stuff Last edited by real.finder; 18th January 2016 at 23:28. |
18th January 2016, 23:44 | #88 | Link | ||
So, with your updates to support YUY2 and RgTools, you selectively do ConvertToYV16 and ConvertToYUY2 where necessary to get the file through (I suppose where Interleaved2Planar and Planar2Interleaved were)? Is that why a blanket ConvertToYV16 at the start doesn't work? EDIT: Actually, I'm not sure if this is you at VideoHelp or not but same thing is said as I said above: http://forum.videohelp.com/threads/3...=1#post2409148. I'll give this a go when I can, but certainly sounds good to me Quote:
19th January 2016, 01:00 | #89 | Link | |
last RgTools is already work with planar YUY2, so I did nothing for it "2015 9 10" was work with YUY2 for me but today after I replace it with "2015 10 23" I found it does not work with YUY2 so I did another edit that will replace "2015 10 23" http://forum.doom9.org/showpost.php?...postcount=2041 edit: and of course you still need SSE2Tools/SSE3Tools for planar YUY2
See My Avisynth Stuff Last edited by real.finder; 19th January 2016 at 01:07. |
19th January 2016, 01:54 | #90 | Link | |
19th January 2016, 03:12 | #91 | Link |
Getting rid of SSE2Tools would be the sane thing to do. All of the plugins QTGMC requires either support YUY2 or YV16. I looked at real.finder's mod some time ago and noticed he 'added support' for YV16 by adding lots of ConvertToYUY2().InterleavedToPlanar() / PlanarToInterleave().ConvertToYV16() . I started my own proper mod but have not got around to finishing it. Doing it correctly definetly takes more time and got a bit confusing since QTGMC has so many options. I have some VHS tapes I need to transfer so hopefully when that happens I'll be a bit more motivated to finish it. Don't hold your breath though .
19th January 2016, 03:24 | #92 | Link | |
I might take a look tonight at the code and see what's going on. Admittedly, I haven't really explored it a whole lot. Should there be any need for Interleaved2Planar and Planar2Interleave if you can just switch between YUY2 and YV16 where necessary? |
19th January 2016, 03:34 | #93 | Link |
No need, if the plugin supports YV16 then use it, if not then use ConvertToYUY2() before hand. The latest NNEDI3 supports YV16 but when using EdiMode="EEDI3+NNEDI3" you must use YUY2 since EEDI3 doesn't support YV16. Also make sure to set MVTools' planar parameter to false when processing YUY2.
19th January 2016, 03:58 | #94 | Link |
no
RgTools = RemoveGrain, Repair, BackwardClense, Clense, ForwardClense and VerticalCleaner in single plugin and RgTools not support YUY2 without Planar=true but RgTools more modern and support new avs 2.6 color formats Y8, YV16, YV24, YV411, and maybe has other features and by the way, I did small change in the last edit (typo in QTGMC_deflate) ------- @Reel.Deel I do it as a quick solution, if all requirements plugins support YV16 in the future then no need for any edit, but I did another changes that nothing to do with YUY2, like bob chroma bug in YV12, and if requirements plugins support YV16 in the future my edit in YUY2 will not adversely affect, it will work normally without remove YUY2 work around anyway, good luck with your edit
See My Avisynth Stuff Last edited by real.finder; 19th January 2016 at 12:08. |
19th January 2016, 07:59 | #95 | Link | ||
If MVTools2 does not support YV16, what exactly does Interleaved2Planar do? If you're not losing chroma resolution but you're doing Interleaved2Planar, isn't that effectively YV16? Quote:
Can it even be done without Interleaved2Planar etc if MVTools2 does not support YV16? I find it funny the main HTML page here for MVTools2 says "This trick will not be needed in Avisynth v2.6 with native support of planar YV16 format", yet MVTools2 has never been updated for YV16. Has the author disappeared? Last edited by mjr4077au; 19th January 2016 at 08:38. |
19th January 2016, 11:48 | #96 | Link | ||
20th January 2016, 00:11 | #97 | Link | ||
Apologies also because I was reading further back on the thread and found this: Quote:
28th January 2016, 16:30 | #98 | Link |
A user in the German doom9/Gleitz board always gets access violations (with script line numbers in the error message, so they are caught by AviSynth) trying to run QTGMC v3.32 or 3.33s with -Vit- and 06_taro DLLs on AviSynth 2.60 ST (default installer). It's hard to discover the true reason, latest line numbers point to a call of RemoveGrain.
Could we please – once again – collect all the recommended versions of plugins required in QTGMC in a current version (e.g. 2015-09-10 or 2016-01-19 – second attachment still pending approval)? Are RgTools now preferable over RemoveGrain patched by -Vit-, and is mt_masktools-26 patched by 06_taro in general the optimal one? |
28th January 2016, 18:20 | #99 | Link | |
29th January 2016, 09:05 | #100 | Link |
OK, thank you for the link.
The case of the stubborn crashes was solved, the final issue was a somehow wrong FFT3DFilter plugin for EZDenoise... The clip was in YV12, so 4:2:2 support was not crucial. |
