Old 14th January 2007, 01:10   #21  |  Link
Janvitos
I believe there might be some issues with BackupHDDVD.
In the meantime, please be patient, as some people will release new and improved decrypters in the near future.
Janvitos is offline   Reply With Quote
Old 14th January 2007, 01:14   #22  |  Link
Albion
Many thanks Janvitos.My eyes will not drift very far from this forum.
Albion is offline   Reply With Quote
Old 14th January 2007, 01:59   #23  |  Link
Janvitos
Would it be possible to make this post a sticky ?
I will surely keep it updated with all the keys i can get my hands on.
Old 14th January 2007, 02:03   #24  |  Link
jokin
Dwight Schrute's homeboy
B32592B86E782DBAEB4801FC1CD1B64CB3FF94A3=World Trade Center |V|01/13/07|DA41B36D90C25E533EE84A307EB2D929
jokin is offline   Reply With Quote
Old 14th January 2007, 02:11   #25  |  Link
blutach
Country Member
blutach's Avatar
Done.
Regards
Les
Only use genuine Verbatim or Taiyo Yuden media.
blutach is offline   Reply With Quote
Old 14th January 2007, 02:15   #26  |  Link
Janvitos
Thanks to you bluatch.
Old 14th January 2007, 02:42   #27  |  Link
He-Man
Posts: n/a
I can see both you and "tonyp12" has kept an updated list in this topic. The only difference is that "tonyp12" has sorted the list in alphabetical order sorted by title name. Maybe you should just copy/paste tonyp12's list to the first post?
Old 14th January 2007, 04:16   #28  |  Link
JarrettH
How did you arrive at finding the keys, Janvitos? I'm very interested to know, but not too technically savvy. Muslix seemed to push you in the right direction when he replied a couple days ago.
Old 14th January 2007, 04:51   #29  |  Link
jkenzie
3D357B0653A66176583C5218FD0149EAF8832FB0=Last Samurai |V|MM/DD/YY| B65DB93DA1649D7193F6E44CD17BA775
F1E5D1838BC981C160DBD54ABEE09F7D39513CB7=Troy |V|MM/DD/YY| 42C70F81BAFDA8657AB92870CA4306EC
3D378CED7721EDE58DBC4589FF28CACD7904EF11=U-571 |V|MM/DD/YY| F4A1910CCD8C19E5E4A3431F9CF7B578
50DE6B4C60D14B1EB8010B706D6A3E36915010B5=We Were Soldiers |V|MM/DD/YY| C7F9F5D110B2F742F37B0A731B77D9E3
7E0FE374FA11E4007228606E95E1A9B374D8EA69=16 Blocks |V|MM/DD/YY| DB8702D6FC60E08F27633EC2399371F5
3702CEC237108E6F47F055F15FBF911C763FDEB2=Unforgiven |V|MM/DD/YY| F29A1B26604D67418F1A9553FD2CD6E3
79C2A2333E5A1C1C5C4514433B03AD019584472D=Kiss Kiss Bang Bang |V|MM/DD/YY| 46B1C70D472A98FC54D994F70699F541
A0782506B1358638EF9B2FFE293FD9D987C22E46=Excalibur |V|MM/DD/YY| 547CB24972DFC3D3624630EBCC37FB44
jkenzie is offline   Reply With Quote
Old 14th January 2007, 05:25   #30  |  Link
Eeknay
522ADA398E00E3A9273A1D1A8B238F6F385D7F0A=Superman: The Movie (USA) |V|MM/DD/YY| C84C68DD726E4949087260EB87999957
544058F1CA886E838E142803968BB9CD8F67843F=Superman II: The Richard Donner Cut (USA) |V|MM/DD/YY| 1B097ADA5B818DF113BBEC81B6435BE4
6F5620E0D8FE645CB4EC9BAD371EC8F994916D54=Constantine (USA) |V|MM/DD/YY| 6FC6ACCF3DA5C835C8988905BDAAFC49
B258E8970D734D56D56734AFCA38A8C1D9B5F5BF=The Matador (USA) |V|MM/DD/YY| 0C629B5F194D4208908FF8FD79E8C9E0
28EEB3AC1BD582B2D0930614B0DB838F13A63536=Harry Potter and the Goblet of Fire (UK) |V|MM/DD/YY| 53C7466A62E37583266EE68A3490ADFB
Same IME problem with Constantine + Harry Potter.
Eeknay is offline   Reply With Quote
Old 14th January 2007, 07:57   #31  |  Link
jokin
Look here. http://forum.doom9.org/showpost.php?...&postcount=642
Old 14th January 2007, 13:29   #32  |  Link
He-Man
Posts: n/a
What pushed him and others in the right direction was LordSloth who posted the link to the Google scavenger hunt for half a title key based on the text posted on pastebin.com.
Where LordSloth found the pastebin.com link I don't know, and I don't know who started the scavenger hunt. The guy posting the scavenger hunt at pastebin.com must have found a title key on his own.
Read from this first post by LordSloth and on-wards:
http://forum.doom9.org/showthread.ph...804#post932804
Old 14th January 2007, 19:26   #33  |  Link
arnezami
Concerning publishing Title/Volume Keys:
I was wondering if there is an easy (and computationally fast) way to determine whether or not any given Volume Key/Title Key is real or fake.
In other words: can we envision a program that looks at your HD DVD, takes a few (but specific) parts of encrypted material and checks whether or not a given key is working? Didn't muslix64 use this "known-plain-text" technique? Can we predict what a (part of a) file should like like when decrypted? And if so, how precise?
This would be relevant if untrusted sources would/had to be used to verify if their keys are correct. Effectively making it possible to decentralize verification.
Regards,
arnezami
PS. I'm not sure if this is the right place to post (but since we are publishing Volume Keys here...). It also relates somewhat to this thread. I'll leave it to the mods .
arnezami is offline   Reply With Quote
Old 14th January 2007, 20:25   #34  |  Link
evdberg
Yes we can, see my posts here and here.
evdberg is offline   Reply With Quote
Old 15th January 2007, 06:31   #35  |  Link
tonyp12
I have created a javascript titlesorter
TitleSorter.hta
Just place it in the same folder as your keydb.cfg file.
and double click it to run.
There will be more work on it:
A text box to input other lists and merge data.
To option to omit the word "The" in sorting.
The file is not Digitaly Signed, how do I do that so you do not get warning messages?
tonyp12 is offline   Reply With Quote
Old 15th January 2007, 20:31   #36  |  Link
MrDVD
Hallo, i dont own a HDDVD-Rom but maybe anyone know if there are diff @ the Keys between USA and GER ? Maybe someone can check it with King Kong as i know it was also included @ the german X360 HDVD-Rom
MrDVD is offline   Reply With Quote
Old 15th January 2007, 20:35   #37  |  Link
Jerky_san
MrDVD I don't believe there is.. Since there isn't region codes on them if I remember right. I also don't think they are because the night the first keys were discovered I think someone tried a European disc and it did have the same key..
Jerky_san is offline   Reply With Quote
Old 15th January 2007, 22:05   #38  |  Link
MrDVD
Got now the info that the SHA1 for King Kong and Serenity is diff compared to the US one so i think the key is also diff. Has the US version all languages on it ?
Old 15th January 2007, 22:13   #39  |  Link
2bigkings
i think that there are different keys between the US and European Version. Please release European Keys and a Step-By-step backuphddvd guide for me (perhaps via pm)
2bigkings is offline   Reply With Quote
Old 15th January 2007, 23:41   #40  |  Link
honai
Posts: n/a
A suggestion for the title names:
We ought to use a naming convention for titles so that we don't get duplicate entries. I recommend using IMDB.com as the reference, so "Chronicles of Riddick" should rather be "The Chronicles of Riddick" (http://imdb.com/title/tt0296572/).
