Old 21st January 2010, 20:07   #1  |  Link
pvh1987
Audio and video out of sync
Hi
I am capturing old VHS video with a standard VCR plugged into an older Pinnacle TV Tuner Card using composite and audio captured with on board soundcard. I am using VirtualVCR.
No matter what AV Sync settings I use in VirtualVCR, the result is out of sync. The big problem is that it will be perfect in the beginning of the video and in the end it off by 200 ms or even more (the video is about 40 min long). I can't figure out how to correct this.
I am using the Huffyuv codec for video (PAL 25 fps, 720x576) and the audio is PCM 16bit at 48kHz.
I would like to know the source of the problem. I cannot be true that I have to correct every capture - It will take a very long time because the out-of-sync is not constant. What can I do to ensure total sync without doing nasty frame rates or audio sample rate? I am mastering for DVD so I want the quality as perfect as possible.
And a second question. I am capturing composite video using a very high quality cable and high quality SCART-converter plug. Still, there is some flickering noise on the picture. I am not talking about interlaced video - it is like a bad TV signal. Is the tuner card not good enough? It gets a lot worse using S-Video. I guess my VCR is not capable of outputting S-Video correctly.
I can live with the slight video noise if I get the audio/video sync to work.
Any help is appreciated. Thank you very much
pvh1987 is offline   Reply With Quote
Old 21st January 2010, 20:10   #2  |  Link
pvh1987
By the way - I had no frame dropping during capture if that is important. I am using a fast computer so I simply can't figure out why there should be any problems at all.
Old 21st January 2010, 21:04   #3  |  Link
setarip_old
setarip_old's Avatar
Hi!
Have you considered the possibility that your VCR might be at fault (stretched tape, dirty heads, etc.)?
setarip_old is offline   Reply With Quote
Old 21st January 2010, 21:19   #4  |  Link
manolito
manolito's Avatar
Try VirtualDub!
I spent a lot of time resolving AV sync issues in a very similar scenario. VirtualVCR can repair sync issues, but only to a certain amount. Then it just gives up.
My experience with VirtualDub is very good. I have a very slow computer, and capturing to Huffyuv does not work because the I/O bus cannot take the data rate. PicVideo MJPEG codec at quality 19 is the maximum my computer can take. And I have to capture "blind", i.e. I have to tell VDub to not display the image during capturing.
But the AV sync routines in VDub are excellent, even with a badly damaged tape I do get perfect sync.
Good luck
manolito
Old 21st January 2010, 22:20   #5  |  Link
lordsmurf
lordsmurf's Avatar
Yes, this is VERY important to know. Most sync errors are caused by random frame loss.
I wonder if your system is accurately reporting frame loss, however. I've seen that too, where the capture software was making a mistake.
Double-check yourself against this guide: http://www.digitalfaq.com/guides/vid...ped-frames.htm
If you're still sure there are no dropped frames, then look at other areas. For example, how do you know there is an audio sync error? Maybe your player software is at fault. I'll assume you've not yet edited/authored it (and therefore not made a DVD to watch on TV).
Back in town.
If you want my advice, then find me at the DigitalFAQ forum. Glad to assist.
Last edited by lordsmurf; 21st January 2010 at 22:23. Reason: I can't believe I've been registered here for 7 years, and this is my first post? Really? Has doom9 crashed or lost any posts in the last 7 years?
lordsmurf is offline   Reply With Quote
Old 21st January 2010, 22:21   #6  |  Link
pvh1987
Actually, I used VirtualDub the first time. It crashed when I started to record. It crashed so bad I could not close the program even when using task mananger several times. I needed to reboot before being able to use any other capture software.
I might try it again anyway.
Maybe I should get a dedicated video grabber instead of a TV Tuner combo to get a cleaner video signal? There is a lot of cheap stuff out there, I see. Even with USB2 connection. Do you think it will be better than my current TV Card? I think it is a Pinnacle PCTV Pro: http://images.anewbiz.net/EbayPics/V..._PC_TV_Pro.jpg
I am totally sure that my videotape is in perfect condition. It has been stored in a normal room and only played a few times.
Is it easy to use a video grabber with VirtualDub/VirtualVCR or similiar free software?
I want to know if I should just stick to my current card or get a better one to get rid of the sync problems and hopefully get a cleaner video capture?
Thanks for the help so far
Old 21st January 2010, 22:25   #7  |  Link
lordsmurf
lordsmurf's Avatar
You just said the "p" word. I don't suggest products from that company, no. It rarely ends on a positive note, for most people, with the consumer products.
Have you considered trying uncompressed capturing, just to see what happens? I've seen huffyUV cause out-of-sync issues before, with no dropped frames.
Back in town.
Old 21st January 2010, 23:19   #8  |  Link
pvh1987
Well, I guess I should just buy a better card from another company and then start from there.
Is there any card or USB-stick that you guys will recommend? I guess it should be based on a bt8x8 chip - looks like it is very supported. I am open to everything else, but I want to use it with free capture software.
I don't care if it has a tv-tuner as well - but it is very important that the composite input will produce a clean sharp picture at 720x576 PAL. I know that composite is not the most hifi connection to use, but it is the one I will be using for digitizing my VHS tapes.
I really hope to get some advice here - I would like to get started soon. It is time consuming work so I would like the very best quality from a consumer card - don't want to use a lot of money just to digitize VHS.
Old 22nd January 2010, 04:38   #9  |  Link
lordsmurf
lordsmurf's Avatar
Does it have to be a PCI card? Is an AGP card possible? (Not PCI express.)
Budget?
Location?
I can surely help.
Back in town.
Old 22nd January 2010, 10:17   #10  |  Link
Ghitulescu
Ghitulescu's Avatar
Unless you have a special need for that recording, I would suggest you something else.
I did very long time ago PC captures and I always have more or less problems. Not dropped frames, or asynch, but color space errors, driver resizing (capture window), frame interpolation (so they don't report a dropped frame but create an artificial one instead), things that most people do not notice. Because I'm a perfectionist.
For some 7 years now I use the hardware way, I capture to a DVD recorder (well, it's a good one) using a studio SVHS feeder (there are also other gear in between). So I don't care about anything (I live in PAL land, so most NTSC issues are moot), drivers, software, HDD, graphic card - the engineers did it for me. Cutting I do frame accurate (it's possible also on MPEG-2 files). Transitions, I don't need. Image improvers, I do in hardware (for things only the software can do, it's not worth capturing, unless the tapes are unicate). Bingo.
If you care about that tape, then rent (or buy used) a good VCR and a good DVD recorder. Don't forget the TBC, you'll desperately need one. Or use the VHS->DVD services of a professional lab - if it's an one-time job.
Old 22nd January 2010, 16:36   #11  |  Link
pvh1987
I don't want a DVD or harddisk recorder. Maybe in the future so I can capture digital TV streams in MPEG2 and MPEG4 with no loss.
I simply want a device that will let me capture analog video and put it into a 720x576 25fps PAL uncompressed (or nearly uncompressed) video file.
I live in Denmark. My budget is like $100-200 for the moment. Right know, I only want to capture VHS, so reference grade equipment is not needed.
Well, I am a high end hifi freak so I am kind of a perfectionist myself, but I want to use the money where it matters and I really can't see why I should by an expensive device from Canopus or something like that, just to capture som old VHS with reasonable quaility and synced audio/video.
I have no need to output analog video. Only input is needed.
My old school had a Dazzle-device that would capture analog video and audio and turn it into a DV-file using Adobe Premiere (I guess another DV capture program could be used instead). I never tried it, but I guess it worked just fine. DV must be good enough for SD video. I don't know about sound, but if it's synced to the video, I could record the sound again with a dedicated soundcard and sync the audio stream to the other DV-audio stream. Maybe that's the way to go?
The TV-card solution is a bit messy to me, but if it works and have just as good quality (or better) - that will be fine.
For postprocessing I want to split and cut, maybe deinterlacing as well. That can be done with avisynth, so I don't need any fancy video editing software.
Again - thanks a lot for helping me with this
Old 22nd January 2010, 21:30   #12  |  Link
zilog jones
zilog jones's Avatar
DV should be more than enough for VHS, you can try this if it is an available option.
Why would you need to de-interlace? What is your destination format going to be? If it is DVD it will be unecessary.
Have you tried getting the latest drivers for your TV card? It is very odd that it made VirtualDub crash like that - are you using the latest version of that too? What kind of specs is your PC?
I have a Pinnacle PCTV Stereo and have had very little trouble with it. Mine is a Philips SAA7134 based card though - if yours is exactly like the picture you linked to it has some sort of Connexant chip which means it is probably a completely unrelated card.
Although this will probably not solve your capturing problem, I would highly recommend investing in a decent high-end S-VHS VCR with a built-in TBC. It doesn't have to be a professional deck - I have a Panasonic NV-HS960 which was one of the top of the range consumer models circa 2000 and am very happy with results. You can easily get something like this for <€100 on eBay. However if it's just for the one cassette it's probably not worth it.
Originally Posted by Ghitulescu View Post
...SVHS feeder...
Do you mean a VCR?
...unless the tapes are unicate..
What do you mean by "unicate"?
zilog jones is offline   Reply With Quote
Old 23rd January 2010, 17:50   #13  |  Link
pvh1987
I just downloaded the latest VirtualDub. Now the capture works - at least it has not crashed yet.
I also tried capturing with no compression (YUV2-capture). The audio and video was not sync at all. Even for a capture less than a minute long. This drives me crazy
I looked at the stats and I could see, that the capture process used between 0 and 6% CPU. The frame rate was not exactly 25, just a little faster like 25.000345 or something. This was changing all the time, but always a little faster than it should be. I guess there is no need to worry about that.
The audio was captured at 48008 Hz? That is strange... it should capture at 48000 precisely. Maybe that's why the audio doesn't match with the video over time, because it is played back at 48000 Hz but captured at 48008? That could explain it.
However, it does not explain why the audio and video was way out of sync in my uncompressed capture.
I really feel like an idiot wasting time on some really bad equipment - how hard can it be to transfer some old VHS to DVD with reasonable quality? Very hard, it shows
Right now I have a fear of buying another TV card and get the same results.
I would like a device like Canopus ADVC 55, but that's just too expensive for the few tapes I need to capture. If anybody know a cheaper alternative, I would like to know about it.
Of course, I am still open to TV card solutions if I get my sync problems fixed. Maybe some of you have some ideas about the audio captured at 48008 Hz?
Old 23rd January 2010, 17:55   #14  |  Link
pvh1987
Update: I tried capturing in VirtualDub again, and this time the audio sample rate was changing from being way off and then nearly 48000 after a while. It still looks like it is running too fast, like between 48000 and 48010 Hz.
Old 24th January 2010, 10:54   #15  |  Link
Ghitulescu
Ghitulescu's Avatar
Originally Posted by zilog jones View Post
Do you mean a VCR?
Yes, there are several flavours of VCR, the workhorse is called a feeder - you know, that type that gives you the exact frame even after hundreds of FWD/REW. It doesn't record, because it's a player.
Unicate - well, all family tapes are unicate, because nobody else has a copy of them
Or one-time shows.
Old 24th January 2010, 11:04   #16  |  Link
Ghitulescu
Ghitulescu's Avatar
It is.
Despite some people here and overthere have a bad image of MiniDV, it still remains the best codec for amateurs. It's so good that it even jumped into the profi field. So I always recommend a hardware conversion to DV/MiniDV. DV is I-Frame so you can cut it frame accurate. You can even change the colorics with no video reencoding, as they are separate stored.
But beware, if you use a camcorder (MiniDV/Digital8) in pass-through, you'll need a TBC before (a full-frame would be perfect). You need it anyway, but the camcorders are really bad in keeping the synch (drop frame) so there you really need one, unless your tape is directly issued from a camcorder and has no problems at all.
Old 24th January 2010, 15:35   #17  |  Link
zilog jones
@pvh1987: VirtualDub will resample the audio to keep it in sync with the video, so this could explain your 10 Hz increase, but I think the resulting audio track is resampled back to the original rate (mine always end up like this anyway, maybe the deviation isn't significant enough in my case, I don't pay too much attention to it...).
I can't explain the weird framerate though. Is this VHS tape in good condition? Is there a lot of noise, or are you getting dropped frames?
I think you should try finding a Philips based capture card if you do want to invest in another one - I think they are a lot less forgiving than the Connexant chips when it comes to VHS and other consumer analogue video formats. I think there are some ATI cards that are supposed to be good too but don't know much about them (there's another recent thread here somewhere discussing comb filters that mentions them).
Did you try checking Pinnacle's website for newer drivers? They might be available through Windows Update too.
MiniDV is another option, you can probably get a used camcorder pretty cheap but make sure it's one with analogue inputs, preferably S-video input in case you get a S-VHS deck.
OK, I hadn't heard that terminology before in reference to players.
Or one-time shows.
Do you mean unique? I don't think "unicate" is a word (it's not in any dictionary I can see anyway).
Old 24th January 2010, 15:37   #18  |  Link
pvh1987
I think I'm learning a lot right know.
I understand it like a hardware analog video to DV converter will not ensure synced audio and video. To get that, I will need a special (expensive) VCR?
I don't know what to do right know. I am not willing to put extensive amount of money in to such a small project.
A solution might be to capture audio at 96 kHz, force the frame rate to 25 fps and then convert the audio to 48 kHz but stretching or shrinking the samples a little to get the audio in sync with the video.
No matter what I do, I will need to use some time for each capture to get it right.
To me, it is understandable that a lot of stuff can go wrong in the capture process.
The question is now, if I should get another "cheap" TV card that will capture video without flicker. The video looks fine, but it looks like a layer of noise on top of each frame - it is hardly noticeable in light areas but dark and black areas are a little gray with noise on top instead of being pitch black. On the television using the same cables, it looks fine. So I think the TV card has some trouble. The same problem I have noticed several years ago capturing from the TV input.
Do you think I should get a "cheap" bt8x8-based Hauppauge card to replace my "crappy" Pinnacle PCTV Pro?
Or should I get a USB video grabber? Looks like an USB stick with 3-4 cables running out of it. I'm afraid to do this because I don't know what software will be able to use it.
Old 24th January 2010, 16:39   #19  |  Link
zilog jones
It depends, but a typical camcorder with analogue inputs may not be able to handle the instability of VHS video very well (i.e. you will get a lot of dropped frames), which is why Ghitulescu recommends a TBC (Time-base corrector) which will cost a lot. You can get a top-end consumer S-VHS VCR for a lot less.
If it's just the one tape it may be cheaper bringing it to some video transfer specialists.
Could you provide a sample clip of this noise?
bt8x8 is quite ancient now, there's a lot better stuff available these days. Card with 3D comb filters (mentioned here: http://forum.doom9.org/showthread.php?t=151560) should improve composite video capturing a lot - however I don't know how good they are for VHS capturing.
These could be even worse than what you already have. It's harder to know which chips these have as you can't physically see them like you can with a PCI/PCI-E card
Old 25th January 2010, 07:21   #20  |  Link
lordsmurf
lordsmurf's Avatar
I never got an answer on AGP vs PCI. ATI All In Wonder cards can work very well for this. And I have a few spares.
Converting video is harder than you think, assuming you care about quality.
For a small project, you may as well pay a pro service. The cost can come out the same in the end.
Back in town.
audio, capture, desync, out of sync, video
