Old 16th September 2023, 12:19   #1  |  Link
RGMOfficial
RGMOfficial's Avatar
Simulating Analog Video Smear
I've been thinking about:
How i can recreate an analog video smear like this?
I've been wanting to do this effect somehow.
AviSynth+ Projects:
DotCrawl++
RGMOfficial is offline   Reply With Quote
Old 16th September 2023, 12:36   #2  |  Link
anton_foy
Blurred chroma displacement on the blue channel? If you mean that smear on the right side if the text below aswell?
anton_foy is offline   Reply With Quote
Old 16th September 2023, 12:55   #3  |  Link
RGMOfficial
Yep. I'm talking about the smear on the right side of the text.
But this can happen to luma as well.
Also, i prefer you detail the channels as YUV.
AviSynth+ Projects:
DotCrawl++
Old 16th September 2023, 13:40   #4  |  Link
Emulgator
Big Bit Savings Now !
Emulgator's Avatar
Convolution will let you destroy your source in so many ways.
You may want to abuse this:
https://forum.doom9.org/showthread.php?t=182604
Old 16th September 2023, 14:24   #5  |  Link
real.finder
reverse https://forum.doom9.org/showthread.php?p=1728274
See My Avisynth Stuff
Old 16th September 2023, 18:43   #6  |  Link
lansing
There is a stand alone software to do these VHS stuff:
https://github.com/JargeZ/ntscqt
Old 14th October 2023, 16:42   #7  |  Link
RGMOfficial
So... i later discovered that i can just simply use edgesidebleed with negative numbers to simulate the smear, so... yeah. Great tool!
But still, thanks for the help, guys. You guys are so helpful.
edgesidebleed(w2=-0.055,w4=-0.055,w8=-0.025,w16=-0.05,w32=-0.005,chroma=false)
AviSynth+ Projects:
DotCrawl++
analog, analog video, simulation
