Old 16th August 2023, 12:41   #1  |  Link
cypher007
arrrrrgh!!! just want to remove one m2ts from mpls
ok tried mpls2json to remove an annoying startup to a movie thats 22sec.
it worked but removed the chapters. so i changed the 22sec m2ts in the mpls file to point at the main movie. plays fine chapters there all works cool. open the m2ts in ripbot264 and it doesnt see the mpls. ok i figure use tsmuxer gui to recreate a new BD folder using the new mpls. works but the chapters are out.
theres goto be an easier way of doing this.
p.s. mpls edit in ripbot just hangs analysing when i click edit.
cypher007 is offline   Reply With Quote
Old 16th August 2023, 14:36   #2  |  Link
TDS
Formally known as .......
TDS's Avatar
Sent you a PM.
What about this :-
https://www.videohelp.com/software/BDedit
https://forum.videohelp.com/threads/...le-%28-mpls%29
https://www.videohelp.com/software/BD-Rebuilder
Is this almost the same question ??
https://forum.doom9.org/showthread.p...24#post1966824
Long term RipBot264 user.
RB 1.27.1 (std)
RB 1.27.1 (fully loaded, OOD)
PD 7.5 (new)
TDS is offline   Reply With Quote
Old 18th August 2023, 06:06   #3  |  Link
Lowpro
There's got to be an easier way of doing this.
You can knock out this task in 15 seconds with BDedit. Launch the application. Go to the PLAYLIST tab. Select the MPLS in question from the drop-down list. Select the PlayItem in question. Use the keyboard combination "Shift+Delete" to delete. Click "Save" in the bottom left corner. Done.
