Old 3rd August 2023, 22:01   #1  |  Link
maldon
Find out the encoding settings of an original blu-ray as in this case.
From what I see in a thread on this forum,
https://forum.makemkv.com/forum/view...yle=11&t=22183
it is possible to find out the encoding settings that were used to encode an original blu-ray, something I was unaware of.
Arrow blu-ray disc of the movie "Donnie Darko"
Encoding settings:
cabac=1 / ref=4 / deblock=0:-1:-1 / analyse=0x3:0x133 / me=umh / subme=10 / psy=1 / psy_rd=1.00:0.15 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-3 / threads=12 / lookahead_threads=2 / sliced_threads=0 / slices=4 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=1 / constrained_intra=0 / bframes=3 / b_pyramid=1 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=1 / weightp=1 / keyint=24 / keyint_min=1 / scenecut=40 / intra_refresh=0 / rc_lookahead=24 / rc=abr / mbtree=0 / bitrate=35000 / ratetol=1.0 / qcomp=0.10 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=38000 / vbv_bufsize=28500 / nal_hrd=vbr / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:0.50
Are the encoding settings only visible on some original blu-ray discs and not on others? if so, why?
If with Mediainfo it is not always possible to view the encoding settings, with what other software would it be possible?
maldon is offline   Reply With Quote
Old 3rd August 2023, 22:53   #2  |  Link
Emulgator
Big Bit Savings Now !
Emulgator's Avatar
Only if the settings are added to the bitstream as x264 does by default.
Other professional blu-ray encoders do not have this implemented.
x264 is only used for a selection of Blu-rays, so one can not expect to see parameter listings in all cases.
Old 3rd August 2023, 23:11   #3  |  Link
maldon
So, for example, if they use a software like Handbrake, would those settings be visible?
I suppose Handbrake is not a professional blu-ray encoder. I would like to know the name of the ones used in the professional blu-ray encoding world, if anyone knows.
Old 3rd August 2023, 23:42   #4  |  Link
Emulgator
Emulgator's Avatar
Ateme Titan
https://www.ateme.com/press/scenaris...-atemeencoder/
Cinemacraft
https://siliconphilosophies.de/cinemacraft-cc-hde/
Mainconcept
(SDKs only ATM)
Sony Blu-code (dead)
https://www.sonycreativesoftware.com...e_brochure.pdf
Old 7th August 2023, 13:58   #5  |  Link
maldon
Thanks a lot.
How many hours (approximately) could it take to re-encode that same blu-ray with the same encoding settings with software like that?
Encoding settings:
I mean with a computer:
-With Intel i7
-With M2.
-With M2 Pro.
-With M2 Max.
