Old 17th June 2023, 20:45   #1  |  Link
edumj
Create BDN XML only Text Subtitles
I've asked this in the "Subtitles" part of the forum, but someone told me I could ask in "Advanced Authoring" (or maybe here it's better).
I would like to know a way to create BDN text subtitles (TextST format, not PGS), to import them in Scenarist BD, or at least the right xml format should I use to create a "Custom text format template" in Subtitle Edit.
edumj is offline   Reply With Quote
Old 16th October 2023, 00:35   #2  |  Link
nbenson
Blu-Ray Remasterer
The only method I've found is to use Lemony Pro Subtitler at www.lemonysubtitler.com
nbenson is offline   Reply With Quote
