Old 9th November 2022, 12:42   #1  |  Link
AOA
[SOLVED] QTGMC - Weird ghost artifacts
Hello.
I am trying to deinterlace Haruhi's DVD.
In the past I've already used QTGMC and didn't really have any problems with it but with this source I suddenly get some weird artifacts that seem to stem from lines in the past frame. I'm not fully experienced with interlaced material but also couldn't find other posts about a similar problem.
clip = core.lsmas.LWLibavSource("VTS_01_1.VOB")
qtgmc = hav.QTGMC(Input=clip, Preset='Slower', EZDenoise=1, NoisePreset="Slow", Sharpness=1, TFF=True, FPSDivisor=2, InputType=0,
NoiseProcess=2, GrainRestore=0.4, NoiseRestore=0.2, Sigma=1.8, NoiseDeint="Generate", StabilizeNoise=True)
rescale = insaneAA.rescale(qtgmc, dx=854, dy=480)
rescale.set_output()
Example output: https://slow.pics/c/UnhBOGf1
Is it possible to get rid of these "ghostings" or am I out of luck?
AOA is offline   Reply With Quote
Old 9th November 2022, 15:30   #2  |  Link
Selur
Selur's Avatar
Source probably isn't interlaced, but a mix of content. From just a single frame, no idea whether those artifacts can be avoided.
Old 9th November 2022, 15:38   #3  |  Link
AOA
Hm ok. Should I upload more screenshots, or should I upload a small clip of that scene to mega, ...?
Mixed content sounds very complex.
Do you have any tips for me, or should I just give up?
Edit: Waiting for moderator approval.
Old 9th November 2022, 16:01   #4  |  Link
kedautinh12
Upload small clip will easy to findout solution
Edit: if you update to mega will faster than Waiting for moderator approval
kedautinh12 is online now   Reply With Quote
Old 9th November 2022, 16:24   #5  |  Link
AOA
Ok thanks for the tip.
Are 200 frames enough?
https://mega.nz/file/JRd3GZCB#cVK6qP...8JoGUpMBtJB-qA
This scene is much shorter with only 50 frames but the artifacts are a lot more noticeable:
https://mega.nz/file/BFFnUQAT#JPifgn...Du8XxfEPFZBSq4
Should I add the unprocessed clips?
Old 9th November 2022, 17:45   #6  |  Link
Reel.Deel
Yes, it's always best to supply the original clip.
Old 9th November 2022, 17:55   #7  |  Link
AOA
Oh.
Here is the src for the second clip:
https://mega.nz/file/dUEx0bJb#CcyaMb...CSQ41-zuZaB__8
Greetings from the inability to cut a video without encoding. Sorry
Old 9th November 2022, 18:38   #8  |  Link
mastrboy
Oh.
You need IVTC, not deinterlacing for this source. (It's 3:2 pulldown, aka telecined)
Though the clip is too short to determine if its CFR or VFR, TFM/Tdecimate can deal with both scenarios: http://avisynth.nl/index.php/TIVTC
(You can use QTGMC when fieldmatching fails in TFM with the clip2 parameter, but most sources don't need it.)
(i have a tendency to drunk post)
mastrboy is offline   Reply With Quote
Old 9th November 2022, 19:18   #9  |  Link
AOA
Thank you so much. Found some great stuff in core.vivtc, which seems to be the solution.
No more artifacts and something new I can learn, YAY!!!
THANK YOU!!
deinterlace dvd, noob, qtgmc
