Old 24th January 2021, 11:11   #21  |  Link
jpsdr
Hard to say...
I would think of maybe "no", because it's not something allowing you to run it without a license, but allowing you to just run it when you have license, because without, you can't (despite having a lifetime non-stop license).
But it's just a two cents thought, i'm not law expert.
And even more, it could be different according countries, the "right" to modify legitimate bought programs to allow it to run on your system when the seller/support is unable fo provide a solution, still staying in your license use.
My github.
Old 25th January 2021, 05:05   #22  |  Link
filler56789
SuperVirus
filler56789's Avatar
Originally Posted by richardpl View Post
It this equivalence of cracking?
I am not a lawyer but I think the answer is źno╗.
Changing one byte to disable a time-bomb in a software that was assumed to not have a time-bomb is very-different from a dongle crack or a keygen, for example.
P.S.: Several years ago Patrakov gave us a free open-sourced DCA encoder, maybe it is time for someone else to develop an open-source DTS-Express encoder and a pure lossless DTS encoder as well
filler56789 is offline   Reply With Quote
Old 26th February 2021, 12:00   #23  |  Link
EMR
Originally Posted by filler56789 View Post
Just confirming that the trick also works for the ancient version 2.00.24.
All one has to do is: open the original DtsJobQueue.exe in a hex editor,
look for the byte-sequence "BF D0 2B FA 79", replace "79" with "EB", save.
That is a terrific solution for all users of the Windows version of DTS-HD MAS. Is there a similar solution for the Mac OS X version? I would need either a patched version of the DtsJobQueue Unix executable or the relevant instructions to hex-edit said executable, or a patched DTSEncoder.app.
EMR is offline   Reply With Quote
Old 27th February 2021, 09:59   #24  |  Link
filler56789
SuperVirus
Probably there is, but I have no idea of what it would be :-/
I have just opened the DTSJobQueue for Mac with a hex editor, but only because of, let's say, my "morbid curiosity", since I cannot imagine what I should be looking for in it...
Are you sure of that?
I mean, that the time-bomb in the Mac edition of the Master Audio Suite is in that file :-/
Old 27th February 2021, 11:37   #25  |  Link
EMR
[COLOR="Blue"]Are you sure of that?
A Mac "app" is, in reality, a folder with or without an icon. Because of that, the DtsJobQueue Unix executable is included in DTSEncoder.app, which is the folder that you double-click to do the encoding. It will run the relevant executable Unix file(s) as needed. So, it is possible to edit an app, usually meaning (hex-)editing one or more Unix executable files and one or more "plist" configuration files or the like.
As for the specific location of the time bomb in the OS X version, my hunch is that it's there because that's where the Windows version included said time bomb. More likely than not, both the Windows and the OS X versions include the same source code. I would assume the developers only adapted minor portions of their code to make it run on both platforms doing exactly the same thing. After adapting whatever they needed to change, compiling the code for both platforms would have been straightforward. If my hunch is correct, then that's where the OS X time bomb should be.
Old 27th February 2021, 17:04   #26  |  Link
filler56789
SuperVirus
Thanks for the information, because I really know almost-nothing about the Mac operating system.
Old 5th March 2021, 09:29   #27  |  Link
Overdrive80
Anime addict
Overdrive80's Avatar
Originally Posted by neil wilkes View Post
Someone please help?
My legally purchased and supposedly perpetually licensed DTS-HD MAS encoder suite has stopped working, and I am not the only person this is happening to.
Error log attached, and it is saying there is a 'configuration file error'.
NOTHING has changed except the calendar year - Windows 7 Pro, same version of Java.
A friend has the same issue on Windows 10 so it is not the OS.
Anyone got any ideas, please?
Are you testing with jre-6u45-windows-i586 version? In my case, it was one solution.
Intel i7-6700K + Noctua NH-D15 + Z170A XPower G. Titanium + Kingston HyperX Savage DDR4 2x8GB + Radeon RX580 8GB DDR5 + ADATA SX8200 Pro 1 TB + Antec EDG750 80 Plus Gold Mod + Corsair 780T Graphite
Overdrive80 is offline   Reply With Quote
Old 18th April 2021, 06:59   #28  |  Link
badflame
Great!!!
badflame is offline   Reply With Quote
Old 17th May 2021, 18:52   #29  |  Link
Lyris
How did you figure this out?
Lyris is offline   Reply With Quote
Old 18th May 2021, 01:37   #30  |  Link
filler56789
SuperVirus
By looking at the original patched .EXE shared by rik1138:
Originally Posted by rik1138 View Post
Here's a fix I'm using for DTS-HD Master Audio Suite ver 2.60.22. Replace the DtsJobQueue.exe in the install folder with this one.
There's only a one-byte difference between this file and the original one on my install, so if you have a newer (or older) version, maybe see if they compare or not.
(The change is byte 418E5 from 79 (in the original file) to EB.
I didn't fix this, I found it on another forum...
Then I checked whether the bytes that appeared before the "evil 79" in the 2.60.22 executable also appeared in the 2.00.24 executable... and the answer was *YES*.
So I edited the older .EXE, tested it, and saw that the modification worked.
Old 19th May 2021, 18:07   #31  |  Link
Lyris
Aha, so DTS themselves released a version that doesn't have this "booby trap" in it. Essentially we're just reverting part of it back to an older version.
master audio suite, time bomb
