Old 5th January 2021, 11:11   #1  |  Link
neil wilkes
neil wilkes's Avatar
DTS-HD MAS encoder has stopped working....why?
Someone please help?
My legally purchased and supposedly perpetually licensed DTS-HD MAS encoder suite has stopped working, and I am not the only person this is happening to.
Error log attached, and it is saying there is a 'configuration file error'.
NOTHING has changed except the calendar year - Windows 7 Pro, same version of Java.
A friend has the same issue on Windows 10 so it is not the OS.
Anyone got any ideas, please?
www.opusproductions.com
Multichannel Audio Productions
DVD-Audio/Video Authoring specialists
neil wilkes is offline   Reply With Quote
Old 5th January 2021, 11:41   #2  |  Link
digitalvideo
hi,
have you reported this to DTS?
regards,
digitalvideo is offline   Reply With Quote
Old 5th January 2021, 12:31   #3  |  Link
jlw_4049
This can only be fixed by the DTS encoder developers
Sent from my SM-G986U1 using Tapatalk
jlw_4049 is offline   Reply With Quote
Old 5th January 2021, 16:18   #4  |  Link
filler56789
SuperVirus
filler56789's Avatar
According to Google,
"Error 8018 – Encoder: Initialization – invalid configuration file" is listed on the user manual of the g*dd@mn software...
As everybody knows,
error messages very-often do not mean what they say.
filler56789 is offline   Reply With Quote
Old 5th January 2021, 20:06   #5  |  Link
jpsdr
Maybe it doesn't like the new year...
My github.
Old 5th January 2021, 21:48   #6  |  Link
filler56789
SuperVirus
Yeah, the Y2K20 bug... OR design flaw, who knows?
That's it, DTS Inc. must be pestered...
Old 5th January 2021, 22:03   #7  |  Link
jpsdr
Change the date rolling back the year, maybe you'll have a surprise...
My github.
Old 5th January 2021, 23:47   #8  |  Link
filler56789
SuperVirus
No surprise at all
— been there, done that, confirmed that it works.
But it's just a workaround (and a very-annoying one), not a solution :-/
Old 6th January 2021, 10:36   #9  |  Link
neil wilkes
Yes, I did go back to DTS for support, and as I explained to them in the follow-up this encoder cost me a lot of money at the time.
But I am getting ahead of myself:
They replied telling me that this is no longer supported, and told me I could buy an upgrade to the (Mac only) DTS-X encoder.
I guess you can imagine my response to that.
To say I was not exactly impressed would be an understatement but the long & short of it is that I got a free DTS-X encoder from them, so anybody with the same issue as me should absolutely write to DTS support.
The approach I used was that I had paid a lot of money in good faith for a perpetual license, and who was going to pay for the 'upgrade' please & that IMO the least they could do would be to provide me with a free one.
To my complete surprise, this is what then happened and was waiting in my in-box this morning - and I will redeem the iLOK code shortly, in case they cancel it after reading this thread (which is extremely unlikely I admit).
So anybody who has a license for this that has stopped working should absolutely get onto DTS - PM me and I will be more than happy to give you the exact wording I used that got results for me.
The 'gotcha' is that you will need a bloody expensive dongle (a MacBook) to make it run though.
Old 6th January 2021, 11:23   #10  |  Link
filler56789
SuperVirus
Now it's impossible to determine whether the problem is a bug (past) + laziness (present) or a time-bomb, oooops, an intentional design flaw, I mean.
Old 7th January 2021, 09:40   #11  |  Link
neil wilkes
Possibly.
My friend does not run a DAW - just an authoring business, so he has tried resetting the system clock and that works in version 2.0 of the encoder. Versions 2.5 & 2.6 are now stuck in 'pending', which is a different issue altogether.
Reading between the lines, this is a time bomb. We have also started to see one version of Steinberg's WaveLab time out on a permanent license as well - I cannot remember if it is v6 or v7, and from memory it is v6 that is timed out now.
So much for spending hard earned money on permanent licenses!!
Old 7th January 2021, 15:04   #12  |  Link
filler56789
SuperVirus
Something like this:
The DTS:X Encoder Suite is the successor to DTS-HD Master Audio Suite...
blah-blah-blah...
Existing owners of DTS Master Audio Suite are entitled to a special upgrade discount. Contact us at info at scenarist dot com for more information on this exclusive offer.
source: https://www.scenarist.com/dts-x-encoder-landing/
Then the users of the DTS:X encoder suite should check whether the new software is time-bombed too :-/
Old 7th January 2021, 19:26   #13  |  Link
SeeMoreDigital
Life's clearer in 4K UHD
SeeMoreDigital's Avatar
I wonder what the logic is behind releasing the DTS-X Encoder Suite for Mac OS's only?
Old 11th January 2021, 07:59   #14  |  Link
rik1138
Here's a fix I'm using for DTS-HD Master Audio Suite ver 2.60.22. Replace the DtsJobQueue.exe in the install folder with this one.
There's only a one-byte difference between this file and the original one on my install, so if you have a newer (or older) version, maybe see if they compare or not.
(The change is byte 418E5 from 79 (in the original file) to EB.
I didn't fix this, I found it on another forum...
Alternate link, should last longer...
https://www.dropbox.com/s/s1mtj6dhn5...Queue.exe?dl=0
rik1138 is offline   Reply With Quote
Old 11th January 2021, 15:41   #15  |  Link
filler56789
SuperVirus
Download link will only be active for a week. Not sure if it's cool to attach it directly to the forum post...
https://we.tl/t-BDhKAPd5Ei
The maximum filesize for the attachments is 200 KB,
regardless of their "coolness" (or lack of) :-/
Old 13th January 2021, 03:00   #16  |  Link
Emulgator
Big Bit Savings Now !
Emulgator's Avatar
A dozen years ago the very popular DAW Logic Audio until version 5.something had been compiled for Windows and Mac.
Any musician, producer, hobbyist, who had bought Logic had the free choice to run it on one or the other hardware.
This changed. Money changed hands, and the cutoff began.
From the very next version Logic 6 was only compiled for Mac.
I was wondering why, my brother (musician) too, and then we had to acknowledge that this move
had forced the complete Logic userbase worldwide into buying exclusively Macs for the coming decades.
A very long lever continuing generation of income exclusively for only one hardware producer.
Every Logic user needed a Mac from now on, and still does.
Old 15th January 2021, 03:11   #17  |  Link
Jim_Pansen
Oh man, wow! You have rescued my life!
I'm in an ongoing production right now. Thank you so much!
Best
Jim
Jim_Pansen is offline   Reply With Quote
Old 15th January 2021, 05:57   #18  |  Link
filler56789
SuperVirus
Just confirming that the trick also works for the ancient version 2.00.24.
All one has to do is: open the original DtsJobQueue.exe in a hex editor,
look for the byte-sequence "BF D0 2B FA 79", replace "79" with "EB", save.
Old 24th January 2021, 10:54   #19  |  Link
Bgalakazam
Thank you for the easy fix. Hex editor was straight-forward.
Bgalakazam is offline   Reply With Quote
Old 24th January 2021, 10:55   #20  |  Link
richardpl
It this equivalence of cracking?
richardpl is offline   Reply With Quote
master audio suite, time bomb
