Thread Tools Display Modes
Old 9th January 2026, 05:53   #1  |  Link
sacdman
sacdman's Avatar
BD Rebuilder and creating a disc with files... not from a BD
I am looking to create a BD with 12 titles, which I have made from VHS tapes. I am not looking to take a previous BD and work with that. Any and all assistance is greatly appreciated. I am not interested in BDedit as that looks very comples.
For my BD, all I want to do is add the files and add a main menu with a list of titles, along with my own custom menu background image. I really think that this should be quite simple, but so far I have had issues. I add my files with "Import" and select a background image of my own for the disc.
I am not creating chapters on the main menu for each title. I have a nice background and just need links to each program on the main menu.
When I load the BDMV folders into VLC, I do see the image I created for this menu, but the links to each program on the menu simply are not there. My image is a 1920x1080 jpg image.
I would suspect that this should be pretty straight forward. Can I only create a BDMV folder from a previous Blu-ray or DVD structure, or is it possible to do this from scratch like I am attempting to do here?
I have looked at the HIDDENOPTS.TXT and the BDREBUILDER.INI but I have no idea which options I need to use for this very basic blu-ray structure and I have made several attempts to create BDMV but so far have been unsuccessful. With VLC I can access the titles listed and can access them from the "Playback" option in VLC, but again, the main menu shows no links to the programs at all.
My concern is I would burn the blu-ray, pop it into my bluray player and have a main menu and no way to access the titles. All 12 of them can be played, but again, not from the main menu.
If someone here has exprerience builing a simple blu-ray structure like this I would really appreciate it. Thanks.
sacdman is offline   Reply With Quote
Old 9th January 2026, 10:22   #2  |  Link
RetsimLegin
a) I seem to recall that for some reason, menus generated by BDRebuilder don't work in VLC. I stand to be corrected. They may (I have never tried it) work in a disc player, and if you want to go this route, doing a test burn to a RE (rewritable) might give you an answer.
b) For what you describe - and this is what I use: DeanBG's MultiAVCHD will get you there easily, and it will play in VLC. A couple of hints, though:
- save your project frequently. The app does, in my experience, crash from time to time without warning nor any recovery. You need to restart and reload the project as per your last save.
- when you are done, it will generate a folder AVCHD, rather than a disc .iso. You can play this folder directly in VLC. Something like imgburn will then make you an .iso from your AVCHD folder and then you can burn it to a disc.
- ideally your source files will already be BD compatible. If they aren't (or you aren't sure) you could use BDRebuilder initially to generate your sources; take it's finished product and pull out all the streams from the end result and then use them as sources for your disc.
RetsimLegin is offline   Reply With Quote
Old 10th January 2026, 04:05   #3  |  Link
sacdman
sacdman's Avatar
Working with multiAVCHD and still no joy.
Okay, I don't know what that means to take out streams. Is that demuxing? I also have made a few attempts to create a BD with multiAVCHD but it have had mixed results. Here is some information... Again, thanks for your help! I have added a log file below. I hope this will help.
There are a lot of settings and it appears that it is not encoding some of my .h264 .mp4 files. The Audio is AC3 and encoded at 1920x1080 with Shutter Encorder. The TV show is SCTV from the 70s. Still sort of flailing around here and not sure if I can even set up a work flow that will be convenient. Any and all help is appreciated. Thanks again!
Attachments Pending Approval
File Type: txt multiAVCHD.txt
Old 10th January 2026, 17:30   #4  |  Link
jdobbs
Not sure whether you've tried this -- but just in case:
1. Go to the SETTINGS/IMPORT/QUICK PLAY SETTINGS menu as select the background you want to use (or just keep the default).
2. Do the same for background audio.
3. Go to FILE/IMPORT/VIDEO FILES and select the files you want to put in the BD.
4. A dialog will pop up in which you can change the TITLE for the menu and edit file names (if you want).
In the end it will create a PSEUDO-BD you can use as a source to do an actual encode (to make sure everything is BD compliant). Run the job and burn it to a disc (if you want). I do this all the time.
jdobbs.softworks@gmail.com
Old 11th January 2026, 03:50   #5  |  Link
sacdman
sacdman's Avatar
I think this is the way I have been doing it... more or less
I did look at the popup when importing the files at the end... I did see a place where I can rename it... Is that what is needed? I am trying this now and will let you know how it goes... thanks!
sacdman
Old 11th January 2026, 10:46   #6  |  Link
RetsimLegin
Sorry for the terminology. If you do want to go this route, what I meant was:
Allow BDRebuilder to make your compilation to ensure BD-Video compatibility. It will (or should) re-encode any that aren't.
Open that compilation in your file explorer.
Find the folder BDMV > STREAM and in there you will find several .m2ts files each numbered. Typically there will be one or more with the lead digit 0 (like 000000.m2ts; 000001.m2ts etc.) and these are your actual movies. Others with different lead digits are menus etc.
Copy only the 0... files to elsewhere.
I'd rename them to reflect their contents at this point but it isn't necessary.
Those will be the media files you will add to your compilation.
Old 11th January 2026, 21:55   #7  |  Link
sacdman
sacdman's Avatar
Menu issue still persists.
I have tried again to create a BD. The only program on my PC I have that read BD menus is VLC. I simply mount the ISO and open it in VLC. I have attached a photo of what my menu looks like in VLC. Below is the config ini details and below that is the log file. Thanks again for being so helpful.
Here are the details from the config file
[Options]
VERSION=0.62.0.16
ENCODER=0
MODE=0
ENCODE_QUALITY=2
ONEPASS_ENCODING=0
AUTO_QUALITY=0
REENCODE_MENUS=1
MENU_AUDIO=C:\Users\SACD-MAN\Documents\BD_Rebuilder\Tools\blankclip\BLANK.AC3
IMPORT_THRESHOLD=15
QUICK_PLAY_THRESHOLD=10
MENU_AUTO_BACKGROUND=0
MENU_AUTO_DVDAUDIO=0
MENU_PLAY_SEQUENTIAL=0
MENU_START_WITH_MENU=1
IMPORT_LIMIT_LANG=0
IMPORT_KEEP_PLAYALL=0
IMPORT_PREPARE_MKV=0
TARGET_SIZE=23500
AUTO_BURN=2
AUDIO_TO_KEEP=eng;
SUBS_TO_KEEP=
SD_CONVERT=0
OPEN_GOP=0
RESIZE_1080=0
RESIZE_1440=0
RESIZE_720=0
DEINTERLACE=1
SD_TO_1080=1
IGNORE_3D=0
CONVERT_WIDE=0
DTS_REENCODE=0
AC3_REENCODE=0
AC3_640=1
AC3_192=0
KEEP_HD_AUDIO=0
AUDIO_DRC=0
DECODER=0
AVCHD=1
REMOVE_WORKFILES=0
REMOVE_OUTPUT=0
USE_FILTERS=0
BDMV_CERT_ONLY=0
IVTC_PULLDOWN=0
ASSUME_DVD_PAL=0
FRIMSOURCE=0
COMPLETION_BEEP=0
OUTPUT_SBS=0
NEROAAC=0
SUPTITLE=0
PGSTOSRT=0
AUDIO_TRACK_LIMIT=1
SUBTITLE_TRACK_LIMIT=0
CUSTOM_TARGET_SIZE=23500
QUICK_EXTRAS=0
[Paths]
WORKING_PATH=F:\SCTV BD PROJECT EXTRA BITS AND TOOLS\SCTV DISC 1\
SOURCE_PATH=F:\SCTV BD PROJECT EXTRA BITS AND TOOLS\IMPORTS\SEASON_1\
Log file
[01/11/26] BD Rebuilder v0.62.16
[12:52:17] Source:  SEASON_1
  - Input BD size: 13.49 GB
  - Approximate total content: [04:45:13.656]
  - Target BD size: 22.95 GB
  - Windows Version: 6.2 [9200]
  - Quick-Play Reauthoring mode enabled
  - Resize: SD to HD 1080 enabled
  - Quality: High Quality (Default), Two Pass
  - Decoding/Frame serving: DirectShow
  - Audio Settings: AC3=0 DTS=0 HD=0 Kbs=640
[12:52:17] PHASE ONE, Encoding
 - [12:52:17] Processing: VID_00001 (1 of 12)
 - [12:52:17] Extracting A/V streams [VID_00001]
 - [12:52:56] Reencoding video [VID_00001]
   - Rate/Length: 29.970fps, 42,780 frames
   - Bitrate: 10,218 Kbs
 - [12:52:56] Reencoding: VID_00001, Pass 1 of 2
 - [12:56:55] Reencoding: VID_00001, Pass 2 of 2
 - [13:06:09] Video Encode complete
 - [13:06:09] Processing audio tracks
 - [13:06:09] Multiplexing M2TS
 - [13:06:31] Processing: VID_00002 (2 of 12)
 - [13:06:31] Extracting A/V streams [VID_00002]
 - [13:07:12] Reencoding video [VID_00002]
   - Rate/Length: 29.970fps, 42,885 frames
   - Bitrate: 10,217 Kbs
 - [13:07:12] Reencoding: VID_00002, Pass 1 of 2
 - [13:11:10] Reencoding: VID_00002, Pass 2 of 2
 - [13:20:22] Video Encode complete
 - [13:20:22] Processing audio tracks
 - [13:20:22] Multiplexing M2TS
 - [13:20:44] Processing: VID_00003 (3 of 12)
 - [13:20:44] Extracting A/V streams [VID_00003]
 - [13:21:24] Reencoding video [VID_00003]
   - Rate/Length: 29.970fps, 42,705 frames
 - [13:21:24] Reencoding: VID_00003, Pass 1 of 2
 - [13:25:13] Reencoding: VID_00003, Pass 2 of 2
 - [13:34:17] Video Encode complete
 - [13:34:17] Processing audio tracks
 - [13:34:17] Multiplexing M2TS
 - [13:34:40] Processing: VID_00004 (4 of 12)
 - [13:34:40] Extracting A/V streams [VID_00004]
 - [13:35:21] Reencoding video [VID_00004]
   - Rate/Length: 29.970fps, 42,675 frames
 - [13:35:21] Reencoding: VID_00004, Pass 1 of 2
 - [13:39:06] Reencoding: VID_00004, Pass 2 of 2
 - [13:48:14] Video Encode complete
 - [13:48:14] Processing audio tracks
 - [13:48:14] Multiplexing M2TS
 - [13:48:36] Processing: VID_00005 (5 of 12)
 - [13:48:36] Extracting A/V streams [VID_00005]
 - [13:49:14] Reencoding video [VID_00005]
   - Bitrate: 10,215 Kbs
 - [13:49:14] Reencoding: VID_00005, Pass 1 of 2
 - [13:52:51] Reencoding: VID_00005, Pass 2 of 2
 - [14:01:46] Video Encode complete
 - [14:01:46] Processing audio tracks
 - [14:01:46] Multiplexing M2TS
 - [14:02:08] Processing: VID_00006 (6 of 12)
 - [14:02:08] Extracting A/V streams [VID_00006]
 - [14:02:48] Reencoding video [VID_00006]
   - Rate/Length: 29.970fps, 42,750 frames
 - [14:02:48] Reencoding: VID_00006, Pass 1 of 2
 - [14:06:47] Reencoding: VID_00006, Pass 2 of 2
 - [14:16:02] Video Encode complete
 - [14:16:02] Processing audio tracks
 - [14:16:02] Multiplexing M2TS
 - [14:16:24] Processing: VID_00007 (7 of 12)
 - [14:16:24] Extracting A/V streams [VID_00007]
 - [14:17:01] Reencoding video [VID_00007]
   - Rate/Length: 29.970fps, 42,645 frames
 - [14:17:01] Reencoding: VID_00007, Pass 1 of 2
 - [14:21:03] Reencoding: VID_00007, Pass 2 of 2
 - [14:30:13] Video Encode complete
 - [14:30:13] Processing audio tracks
 - [14:30:13] Multiplexing M2TS
 - [14:30:35] Processing: VID_00008 (8 of 12)
 - [14:30:35] Extracting A/V streams [VID_00008]
 - [14:31:14] Reencoding video [VID_00008]
   - Rate/Length: 29.970fps, 42,825 frames
 - [14:31:14] Reencoding: VID_00008, Pass 1 of 2
 - [14:35:23] Reencoding: VID_00008, Pass 2 of 2
 - [14:44:36] Video Encode complete
 - [14:44:36] Processing audio tracks
 - [14:44:36] Multiplexing M2TS
 - [14:44:57] Processing: VID_00009 (9 of 12)
 - [14:44:57] Extracting A/V streams [VID_00009]
 - [14:45:33] Reencoding video [VID_00009]
   - Rate/Length: 29.970fps, 42,690 frames
 - [14:45:33] Reencoding: VID_00009, Pass 1 of 2
 - [14:49:19] Reencoding: VID_00009, Pass 2 of 2
 - [14:58:33] Video Encode complete
 - [14:58:33] Processing audio tracks
 - [14:58:33] Multiplexing M2TS
 - [14:58:54] Processing: VID_00010 (10 of 12)
 - [14:58:54] Extracting A/V streams [VID_00010]
 - [14:59:30] Reencoding video [VID_00010]
 - [14:59:30] Reencoding: VID_00010, Pass 1 of 2
 - [15:03:18] Reencoding: VID_00010, Pass 2 of 2
 - [15:12:38] Video Encode complete
 - [15:12:38] Processing audio tracks
 - [15:12:38] Multiplexing M2TS
 - [15:12:58] Processing: VID_00011 (11 of 12)
 - [15:12:58] Extracting A/V streams [VID_00011]
 - [15:13:38] Reencoding video [VID_00011]
   - Rate/Length: 29.970fps, 42,615 frames
 - [15:13:38] Reencoding: VID_00011, Pass 1 of 2
 - [15:18:05] Reencoding: VID_00011, Pass 2 of 2
 - [15:27:25] Video Encode complete
 - [15:27:25] Processing audio tracks
 - [15:27:25] Multiplexing M2TS
 - [15:27:46] Processing: VID_00012 (12 of 12)
 - [15:27:46] Extracting A/V streams [VID_00012]
 - [15:28:25] Reencoding video [VID_00012]
   - Rate/Length: 29.970fps, 42,900 frames
 - [15:28:25] Reencoding: VID_00012, Pass 1 of 2
 - [15:32:04] Reencoding: VID_00012, Pass 2 of 2
 - [15:41:12] Video Encode complete
 - [15:41:12] Processing audio tracks
 - [15:41:12] Multiplexing M2TS
[15:41:35]PHASE ONE complete
[15:41:35]PHASE TWO - Rebuild Started
 - [15:41:35] Rebuilding BD file Structure
[15:41:35] - Encode and Rebuild complete
[15:41:35] Writing BD structure to ISO file
 - ImgBurn completed successfully
[15:54:36] JOB: SEASON_1 finished.
[01/11/26] Checking System Settings
  - BD-Rebuilder v0.62.16
  - Working Path Free Space: 1,637.41GB
  - AVISYNTH Version: 2.6.0.6, Ok
  - LAVFILTERS:  Ok
  - X264:  Ok
  - X265:  Ok
  - AFTEN:  Ok
  - FAAC:  Ok
  - MP4BOX:  Ok
  - WAVI:  Ok
  - TSMUXER:  Ok
  - FRIMEncode:  Ok
  - FRIMDecode:  Ok
[01/11/26] Systems Settings Check complete
I hope this can help show where I am missing what may be needed. And again, thanks for much for your help!!
File Type: jpg menuinvlc.jpg
Old 12th January 2026, 16:42   #8  |  Link
jdobbs
I'd suggest you burn it to a BD and test it on a real Blu-Ray player. I suspect it is a problem in VLC, not BD-RB. If it works on the player, that confirms my suspicion.
Old 12th January 2026, 18:41   #9  |  Link
sacdman
sacdman's Avatar
I tried a different BD player that supports menus called iToolShare and again, the menu issue persists. Any and all suggestions are appreciated. Thanks.
Old 12th January 2026, 22:17   #10  |  Link
jdobbs
Don't know what to say. Importing video files and creating discs with menus is the thing I do more than anything else with BD Rebuilder - and I've never had a problem.
Old 13th January 2026, 00:05   #11  |  Link
sacdman
sacdman's Avatar
Which version are you using of BD rebuilder and I am also wondering if there is an issue with any of my settings and if I did the installation correctly? Any help there would be appreciated.
Old 13th January 2026, 02:21   #12  |  Link
jdobbs
Try removing MENU_AUTO_BACKGROUND=0 from you INI or set it to MENU_AUTO_BACKGROUND=1
Old 17th January 2026, 01:56   #13  |  Link
sacdman
sacdman's Avatar
New attempt but unsuccessul
I have tried again and removed the line you suggested. Again, a background shows up, but the menu links do not come up. Here is the config INI and I installed AVISynth, ffdshow and Haali Media Splitter. I also have K-Lite Codec Pack installed and that has LAV filters already. I am wondering if that is causing an issue? Could that be possible?
AUDIO_DRC=0
DECODER=2
AVCHD=1
REMOVE_WORKFILES=0
REMOVE_OUTPUT=0
USE_FILTERS=0
BDMV_CERT_ONLY=0
IVTC_PULLDOWN=0
ASSUME_DVD_PAL=0
FRIMSOURCE=0
COMPLETION_BEEP=0
OUTPUT_SBS=0
NEROAAC=0
SUPTITLE=0
PGSTOSRT=0
AUDIO_TRACK_LIMIT=1
SUBTITLE_TRACK_LIMIT=1
MENU_PLAY_SEQUENTIAL=1
MENU_ITEMS_PAGE=12
MENU_MAXITEMS=12
MENU_ROLLOVER=1
MENU_BACKDROP_AUTOSIZE=1
MENU_BACKDROP_OPACITY=0
MENU_HORIZONTAL=132
MENU_TOP=232
MENU_VERTICAL=232
MENU_PAGE_ENABLE=0
MENU_PREVNEXT_X=0
MENU_PREVNEXT_Y=0
MENU_CUSTOM_COLOR=GREY
MENU_INACTIVE_COLOR=SAME
MENU_ACTIVE_COLOR=WHITE
MENU_FONT=HELVETICA 55 ROMAN
MENU_FONT_BOLD=1
MENU_FONT_ITALIC=0
MENU_FORCE_QUICK=1
MENU_BACKGROUND=C:\Users\SACD-MAN\Documents\BD-RBV06216\BD_Rebuilder\Misc\menuback.jpg
MENU_AUDIO=C:\Users\SACD-MAN\Documents\BD-RBV06216\BD_Rebuilder\tools\blankclip\blank.ac3
IMPORT_LIMIT_LANG=0
[Paths]
WORKING_PATH=F:\SCTV\
SOURCE_PATH=F:\SCTV\IMPORTS\SEASON_1\
Old 17th January 2026, 10:23   #14  |  Link
RetsimLegin
As I said earlier, the most likely thing is that VLC and BDRB menus don't play together. I don't know why. I have never got a BDRB menu to work in VLC and gave up trying.
And as I said earlier, you could invest in a BDRE rewritable disc for testing purposes, and try your compilation in a tabletop BD player.
Or, as I said earlier - for VLC compatibilty use a different BD mastering app eg multiAVCHD.
Old 18th January 2026, 22:27   #15  |  Link
sacdman
sacdman's Avatar
Hi and thanks for all of you help so far. I have been trying to use multiAVCHD for a while now, but I do find it rather difficult to work with. I am wondering, where this is such an older piece of software, that it might have to run in compatibility mode? I am using Windows 10 Pro. If you could provide some details or advice on using multiAVCHD I would really appreciate it. Thanks again!
Old 20th January 2026, 09:11   #16  |  Link
RetsimLegin
As far as I know, the only thing I do special with it (on Win11, and Win10 before it) is run it as Administrator. I don't recall why - but there must have been a reason.
I'll happily answer specific other questions, if I can, but it's probably best you begin and then raise specifics when you encounter them rather thanme trying to write a full instruction manual.
bd rebuilder, bdrebuilder.ini, blu-ray, hiddenopts.txt, menu issues
Thread Tools
