Thread Tools Display Modes
Old 17th August 2025, 08:50   #1  |  Link
jay123210599
High Quality, Visually Indistinguishable AVIFs
I decided to make high quality lossy animated AVIFs to save space. Which quality setting would make the best visually indistinguishable AVIFs, crf 18, or something lower?
jay123210599 is offline   Reply With Quote
Old 17th August 2025, 13:28   #2  |  Link
Z2697
Definitely.
Z2697 is offline   Reply With Quote
Old 17th August 2025, 14:28   #3  |  Link
jay123210599
Originally Posted by Z2697 View Post
Definitely.
Definitely what?
Old 17th August 2025, 15:24   #4  |  Link
Z2697
If you can't distinguish it, then it's indistinguishable. Simple.
Old 17th August 2025, 21:57   #5  |  Link
jay123210599
I decided to ran a few tests to see which avif would have the best quality and the best visually indistinguishable.
Test 1: -crf 23
Test 2: -crf 19
Test 3: -crf 18
Test 4: -crf 10
Test 5: -crf 5
Test 6: -crf 1
Command used for all avifs:
ffmpeg -i test.mkv -c:v libaom-av1 -crf  -cpu-used 7 test.avif
Test files: https://www.mediafire.com/file/ppur2..._avifs.7z/file
Old 19th August 2025, 23:40   #6  |  Link
benwaggoner
Which is going to be dependent on content, visual acuity, resolution, frame rate, and so much else.
I would expect more than six point difference in CRF required for the 1% easiest content and scenarios versus the 1% hardest.
Ben Waggoner
My Compression Book
avif, image-quality
Thread Tools
