Thread Tools Display Modes
Old 16th June 2025, 13:16   #1  |  Link
jay123210599
PNGs to a AVIF
How do I convert an image sequence of PNG files to an animated AVIF file?
jay123210599 is offline   Reply With Quote
Old 17th June 2025, 11:16   #2  |  Link
macappst
App Geek
macappst's Avatar
Here's a basic command that should do the trick:
ffmpeg -framerate 10 -i frame_%03d.png -c:v libaom-av1 -crf 30 -b:v 0 -pix_fmt yuv420p10le output.avif
A few notes:
-framerate 10
sets the animation speed (adjust as needed).
Make sure your PNGs are named like
, etc.
yuv420p10le
gives better quality/color for AVIF.
AVIF encoding is slow, just a heads up 😅
macappst is offline   Reply With Quote
Old 17th June 2025, 13:15   #3  |  Link
jay123210599
A few notes:
-framerate 10
, etc.
yuv420p10le
What's
-b:v 0
and
for?
Old 17th June 2025, 15:34   #4  |  Link
Z2697
Try to learn to use google. Or bing. Or duckduckgo. Or whatever search engine.
Z2697 is offline   Reply With Quote
Old 17th June 2025, 18:14   #5  |  Link
GeoffreyA
In earlier versions of FFmpeg's libaom wrapper, CRF was only enabled by -crf and -b:v 0.
-pix_fmt yuv420p10le sets the format to YV420 and the bit depth to 10 bit, recommended with AV1 because it improves efficiency and is supported on the standard profile. Indeed, all post-H.264 encoding is better off using 10-bit depth.
GeoffreyA is offline   Reply With Quote
Old 17th June 2025, 19:21   #6  |  Link
Z2697
There's a shortage of threads in VP9&AV1 forum and we need the mighty Jay to fill the space.
Old 17th June 2025, 23:09   #7  |  Link
jay123210599
How about for later versions?
Old 19th June 2025, 22:49   #8  |  Link
GeoffreyA
Not needed any more. Can be verified with -loglevel debug or trace.
avif, png
Thread Tools
