Thread Tools Display Modes
Old 2nd March 2025, 14:14   #1  |  Link
jay123210599
AVIF to APNG
What can I use to convert animated AVIF files to APNGs without losing quality? Can ffmpeg do it? If so, how?
jay123210599 is offline   Reply With Quote
Old 4th March 2025, 02:12   #2  |  Link
benwaggoner
APNG is a lossless RGB format while AVIF is an (almost always) lossy format typically in YUV. So there would be some format conversion loss. And for most content, you'd actually wind up increasing the file size, as PNG's native lossless compression doesn't work well with the sort of slight variations a frequency transform codec tends to introduce. PNG can be quite efficient for computer-rendered graphics ala PowerPoint or a desktop, but is ill suited for continuous tone content like a photograph.
I'd guess AVIF and APNG have similar compatibility profiles, so what's your scenario for wanting to do this conversion? You may well be better off just sticking with AVIF, or generating the APNG from original uncompressed sources if available.
Ben Waggoner
My Compression Book
Old 4th March 2025, 14:17   #3  |  Link
GeoffreyA
Try something to this effect:
ffmpeg -i "INPUT.avif" -sws_flags accurate_rnd+full_chroma_int "OUTPUT.apng"
GeoffreyA is offline   Reply With Quote
Old 4th March 2025, 17:47   #4  |  Link
Z2697
The answer is already, literally just 1 scientific poking away, or actually already answered by our replies in his old trolling threads
Z2697 is offline   Reply With Quote
Old 4th March 2025, 17:54   #5  |  Link
Z2697
Actually here's a catch LOL.
As I have mentioned many times, animated HEIF is just like a normal video file, but with the first key frame referenced as "thumbnail image".
Now, for FFmpeg, when reading such HEIF it sees them as two video streams, the default stream selection will probably pick the wrong one.
Old 5th March 2025, 06:21   #6  |  Link
GeoffreyA
Now, for FFmpeg, when reading HEIF it sees them as two video streams, the default stream selection will probably pick the wrong one.
Alas, there's always a glitch with FFmpeg!
Old 5th March 2025, 17:32   #7  |  Link
Z2697
I'm OK to call it a feature, not a bug
Old 5th March 2025, 20:09   #8  |  Link
GeoffreyA
All right, with due deference to the FF of the MPEG, we'll call it a feature
Old 5th March 2025, 21:09   #9  |  Link
benwaggoner
Yeah, you can specify the stream you want to use in the command line.
FFmpeg can do anything, if you can figure out the syntax. But the syntax is not easy to figure out!
Ben Waggoner
My Compression Book
Old 6th March 2025, 07:27   #10  |  Link
GeoffreyA
When I discovered FFmpeg in 2018, I was astonished that it could do anything, quite a departure from the old way of using a range of tools to encode something. In the 2000s, I would use DVD Decrypter, DVD Audio Extractor, Azid, XMPEG, and VirtualDub to go from DVD to DivX-MP3 AVI. FFmpeg's syntax is like an obscure, miniature programming language at times, but when one finds something out, it's another weapon in one's toolkit.
avif, converstion, png
Thread Tools
