Old 8th October 2025, 16:20   #121  |  Link
Sagittaire
Testeur de codecs
Sagittaire's Avatar
Originally Posted by littleD View Post
Another Ryzen to the chart, my first buy.
| CPU | Ryzen 5 8645HS w/ Radeon 760M Graphics
| H264 - x264 - 1080p - HDR - Multipart encoding - 1611 frames | 131.440 s
| H265 - x265 - 1080p - HDR - Multipart encoding - 1611 frames | 143.743 s
| AV1 - SVT-AV1 - 1080p - HDR - Multipart encoding - 1611 frames | 173.557 s
| H266 - VVEnc - 1080p - HDR - Multipart encoding - 1611 frames | 253.541 s
| Overall - 1080p - HDR - ABR Ladder encoding - 1611 frames | 669.482 s
well this little 8645HS is on par with 11900K (top desktop CPU for Intel in 2021).
Le Sagittaire ... ;-)
1- Ateme AVC or x264
2- VP7 or RV10 only for anime
3- XviD, DivX or WMV9
Old 9th October 2025, 09:40   #122  |  Link
Marsu42
Huba Huba
Marsu42's Avatar
...and the older desktop cpu won't be able to match the newer mobile-ish cpu with performance per wats.
Speaking of older, there's my good ol' dual-core Tigerlake mobile cpu:
| CPU | 11th Gen Core i5-1135G7
| H264 - x264 - 1080p - HDR - Multipart encoding - 1611 frames | 467.611 s
| H265 - x265 - 1080p - HDR - Multipart encoding - 1611 frames | 437.727 s
| AV1 - SVT-AV1 - 1080p - HDR - Multipart encoding - 1611 frames | 532.568 s
| H266 - VVEnc - 1080p - HDR - Multipart encoding - 1611 frames | 827.772 s
| Overall - 1080p - HDR - ABR Ladder encoding - 1611 frames | 2091.543 s
"The innocent have nothing to fear" :stupid:
Marsu42 is offline   Reply With Quote
Old 9th October 2025, 12:53   #123  |  Link
littleD
littleD's Avatar
Funny part is that Ryzen™ 5 8645HS is the same as its first installment 7640HS form half of the 2023.
And this looks same as newer Ryzen 5 240. So AMD just rebranded some processors due to Intel +++process node incompetence.
The next gen is Ryzen AI with perf/eco cores. While the wattage is much smaller, then for example AI 350 from previous page is bit slower than 8645HS with less cores, so this time, its AMD who went to Ultra models (U ment as ultra efficiency).
Not sure how this P/E cores story will end up, since the efficiency clocking is still much better on Android than on Windows with Power Plans from the previous epoque.
littleD is offline   Reply With Quote
Old 15th December 2025, 23:52   #124  |  Link
hajj_3
Laptop Core i3-1215U with ddr4 sodimm:
encoded 1611 frames in 2087.46s (0.77 fps), 2277.61 kb/s, Avg QP:29.10
[aac @ 000002427035e240] Qavg: 2222.263
run.sh: line 82: warning: command substitution: ignored null byte in input
| CPU                                                             | 12th Gen Intel(R) Core(TM) i3-1215U
| H264 - x264 - 1080p - HDR - Multipart encoding - 1611 frames    |  285.732 s
| H265 - x265 - 1080p - HDR - Multipart encoding - 1611 frames    |  386.295 s
| AV1 - SVT-AV1 - 1080p - HDR  - Multipart encoding - 1611 frames |  445.209 s
| H266 - VVEnc - 1080p - HDR  - Multipart encoding - 1611 frames  |  724.074 s
| Overall - 1080p - HDR  - ABR Ladder encoding - 1611 frames      |  2087.893 s
Old 25th December 2025, 14:20   #125  |  Link
charliebaby
charliebaby's Avatar
| CPU | Ryzen 9 9950X3D 16-Core Processor
| H264 - x264 - 1080p - HDR - Multipart encoding - 1611 frames | 35.075 s
| H265 - x265 - 1080p - HDR - Multipart encoding - 1611 frames | 38.385 s
| AV1 - SVT-AV1 - 1080p - HDR - Multipart encoding - 1611 frames | 40.828 s
| H266 - VVEnc - 1080p - HDR - Multipart encoding - 1611 frames | 73.365 s
| Overall - 1080p - HDR - ABR Ladder encoding - 1611 frames | 239.468 s
charliebaby is offline   Reply With Quote
Old 27th December 2025, 17:21   #126  |  Link
renq
Which settings and cooling did you use? There's already a 9950X3D score posted - https://forum.doom9.org/showpost.php...7&postcount=81 - but their overall score is 195 seconds, an 18% improvement.
renq is offline   Reply With Quote
Old 27th December 2025, 20:22   #127  |  Link
Z2697
Anything except SVT-AV1 is a lot slower, I wonder what magic dust he uses on his computer. To make this distinct performance, I mean.
Or he replaced the encoder with newer version, as we all know that SVT-AV1 made major changes to the presets that re-balanced the speed and quality, it was somewhat recent.
Z2697 is offline   Reply With Quote
Old 1st January 2026, 20:15   #128  |  Link
Sagittaire
Testeur de codecs
Sagittaire's Avatar
I don't replace ffmpeg.exe with newer build in original version.
Anyway Within the limits of uncertainty, the result for SVT-AV1 is the same (41.492s vs 40.828s).
To get the best possible result in this test, no background tasks should be running.
And Asmodian result use PBO profil for 9950x3D.
Old 1st January 2026, 20:22   #129  |  Link
Sagittaire
Testeur de codecs
Sagittaire's Avatar
Always no Intel 285K for test this benchmark ... ???
Old 1st January 2026, 21:22   #130  |  Link
Z2697
So I said "he", charliebaby, if he replaced the binary while others don't, that will make a bit sense, as SVT-AV1 is the only one encoder in the test that has been tweaking presets quite recently.
No other reasonable hardware/software tuning should make such a different effect.
av1, benchmark, codec comparison, x264, x265
