Old 19th November 2024, 21:42   #41  |  Link
Z2697
| CPU                                                             | AMD Ryzen 9 9950X 16-Core Processor
| H264 - x264 - 1080p - HDR - Multipart encoding - 1611 frames    |  28.501 s
| H265 - x265 - 1080p - HDR - Multipart encoding - 1611 frames    |  36.658 s
| AV1 - SVT-AV1 - 1080p - HDR  - Multipart encoding - 1611 frames |  43.394 s
| H266 - VVEnc - 1080p - HDR  - Multipart encoding - 1611 frames  |  74.648 s
| Overall - 1080p - HDR  - ABR Ladder encoding - 1611 frames      |  207.049 s
Just a quick and dirty test.
But already showing big W.
Z2697 is offline   Reply With Quote
Old 20th November 2024, 00:26   #42  |  Link
Zebulon84
| CPU                                                             | 12th Gen Intel(R) Core(TM) i3-12100
| H264 - x264 - 1080p - HDR - Multipart encoding - 1611 frames    |  251.392 s
| H265 - x265 - 1080p - HDR - Multipart encoding - 1611 frames    |  231.605 s
| AV1 - SVT-AV1 - 1080p - HDR  - Multipart encoding - 1611 frames |  261.596 s
| H266 - VVEnc - 1080p - HDR  - Multipart encoding - 1611 frames  |  430.054 s
| Overall - 1080p - HDR  - ABR Ladder encoding - 1611 frames      |  1167.038 s
Running on linux + virtualbox + a freshly installed Windows 10 with 8 Go memory (DDR4 3000) for the virtual machine.
Zebulon84 is offline   Reply With Quote
Old 20th November 2024, 14:20   #43  |  Link
Sagittaire
Testeur de codecs
Sagittaire's Avatar
Originally Posted by Z2697 View Post
| CPU                                                             |  Ryzen 9 7950X      | AMD Ryzen 9 9950X
| H264 - x264 - 1080p - HDR - Multipart encoding - 1611 frames    |  45.86 fps          |  56.52 fps +23%
| H265 - x265 - 1080p - HDR - Multipart encoding - 1611 frames    |  36.97 fps          |  43.95 fps +19%
| AV1 - SVT-AV1 - 1080p - HDR  - Multipart encoding - 1611 frames |  29.84 fps          |  37.12 fps +24%
| H266 - VVEnc - 1080p - HDR  - Multipart encoding - 1611 frames  |  18.51 fps          |  21.58 fps +17%
| Overall - 1080p - HDR  - ABR Ladder encoding - 6444 frames      |  25.73 fps          |  31.12 fps +21%
Clearly, for enconding, 9950X is a big improuvement if you compare with 7950X
Other codec test for CPU don't show that simply because these test are not at 100% for CPU charge or/and at power limit:
https://www.computerbase.de/2024-08/...oreanwendungen
https://www.tomshardware.com/pc-comp...x-cpu-review/3
Le Sagittaire ... ;-)
1- Ateme AVC or x264
2- VP7 or RV10 only for anime
3- XviD, DivX or WMV9
Old 20th November 2024, 21:02   #44  |  Link
Krawhitham
| CPU                                                             | AMD Ryzen 9 5950X 16-Core Processor
| H264 - x264 - 1080p - HDR - Multipart encoding - 1611 frames    |  58.348 s
| H265 - x265 - 1080p - HDR - Multipart encoding - 1611 frames    |  68.090 s
| AV1 - SVT-AV1 - 1080p - HDR  - Multipart encoding - 1611 frames |  79.863 s
| H266 - VVEnc - 1080p - HDR  - Multipart encoding - 1611 frames  |  127.898 s
| Overall - 1080p - HDR  - ABR Ladder encoding - 1611 frames      |  350.710 s
Asrock X570 Phantom Gaming X
64gb DDR4 3600
Krawhitham is offline   Reply With Quote
Old 20th November 2024, 21:04   #45  |  Link
Sagittaire
Testeur de codecs
Sagittaire's Avatar
64gb DDR4 3600
Well 5950X, 7950X and 9950X comparison is now possible ... ;-)
Old 20th November 2024, 21:18   #46  |  Link
Sagittaire
Testeur de codecs
Sagittaire's Avatar
64gb DDR4 3600
| CPU                                                             |  Ryzen 9 5950X      |  Ryzen 9 7950X      |  Ryzen 9 9950X
| H264 - x264 - 1080p - HDR - Multipart encoding - 1611 frames    |  27.61 fps          |  45.86 fps +66%     |  56.52 fps +23%
| H265 - x265 - 1080p - HDR - Multipart encoding - 1611 frames    |  23.66 fps          |  36.97 fps +56%     |  43.95 fps +19%
| AV1 - SVT-AV1 - 1080p - HDR  - Multipart encoding - 1611 frames |  20.17 fps          |  29.84 fps +48%     |  37.12 fps +24%
| H266 - VVEnc - 1080p - HDR  - Multipart encoding - 1611 frames  |  12.59 fps          |  18.51 fps +47%     |  21.58 fps +17%
| Overall - 1080p - HDR  - ABR Ladder encoding - 6444 frames      |  18.37 fps          |  25.73 fps +40%     |  31.12 fps +21%
Well 5950X results are stranges. You are sure that your CPU don't have another task during the benchmark?
Old 20th November 2024, 21:45   #47  |  Link
Krawhitham
1st run was ran with all windows closed
2nd run is after a reboot (windows 11) with Internet (NIC card disabled) turned off, antivirus & firewall disabled.
| CPU                                                             |  Ryzen 9 5950X 16-Core Processor
| H264 - x264 - 1080p - HDR - Multipart encoding - 1611 frames    |  52.592 s
| H265 - x265 - 1080p - HDR - Multipart encoding - 1611 frames    |  66.851 s
| AV1 - SVT-AV1 - 1080p - HDR  - Multipart encoding - 1611 frames |  78.844 s
| H266 - VVEnc - 1080p - HDR  - Multipart encoding - 1611 frames  |  129.300 s
| Overall - 1080p - HDR  - ABR Ladder encoding - 1611 frames      |  352.515 s
Old 20th November 2024, 22:42   #48  |  Link
Sagittaire
Testeur de codecs
Sagittaire's Avatar
tanks for your contribution. Results are more coherents now:
| H264 - x264 - 1080p - HDR - Multipart encoding - 1611 frames    |  30.63 fps          |  45.86 fps +49%     |  56.52 fps +23%
| H265 - x265 - 1080p - HDR - Multipart encoding - 1611 frames    |  24.10 fps          |  36.97 fps +53%     |  43.95 fps +19%
| AV1 - SVT-AV1 - 1080p - HDR  - Multipart encoding - 1611 frames |  20.43 fps          |  29.84 fps +46%     |  37.12 fps +24%
| H266 - VVEnc - 1080p - HDR  - Multipart encoding - 1611 frames  |  12.45 fps          |  18.51 fps +48%     |  21.58 fps +17%
| Overall - 1080p - HDR  - ABR Ladder encoding - 6444 frames      |  18.28 fps          |  25.73 fps +41%     |  31.12 fps +21%
The difference between 5950X and 7950X is really impressive ...
Old 21st November 2024, 07:49   #49  |  Link
Z2697
Yes, I've used 5950X as well. At settings for everyday usage, comparing the Cinebench R23 score, 5950X is like 28,000~30,000 range at best, 7950X is 38,000~40,000 at best, and 9950X is only 43,000~44,500 at best (at least currently). Really HUGE improvement between Zen4 and Zen3.
But I'm still pretty happy with Zen5.
I did more tuning after the previously posted result, it might be able to get a better one now, but I'll save that until maybe two days later, after I replace the cooler (still shipping).
Old 23rd November 2024, 19:47   #50  |  Link
Z2697
New result.
What about new cooler, if you ask, it's... the exact same model (Thermalright PA140), I just want to leave the old one for 7950X.
And of course both are white, white is the new trend, yay.
| CPU                                                             |  Ryzen 9 9950X 16-Core Processor
| H264 - x264 - 1080p - HDR - Multipart encoding - 1611 frames    |  27.864 s                +26% 7905X
| H265 - x265 - 1080p - HDR - Multipart encoding - 1611 frames    |  34.895 s                +24.6% 7950X
| AV1 - SVT-AV1 - 1080p - HDR  - Multipart encoding - 1611 frames |  41.628 s                +29.7% 7950X
| H266 - VVEnc - 1080p - HDR  - Multipart encoding - 1611 frames  |  70.095 s                +24.2% 7950X
| Overall - 1080p - HDR  - ABR Ladder encoding - 1611 frames      |  198.267 s                +26.3% 7950X
Last edited by Z2697; 23rd November 2024 at 21:14. Reason: add the percentage uplift (#48 data as ref)
Old 24th November 2024, 00:01   #51  |  Link
Sagittaire
Testeur de codecs
Sagittaire's Avatar
New result.
No overclocking or PBO?
Just 9950X at default stock?
Old 24th November 2024, 02:21   #52  |  Link
Z2697
PBO, curve optimizer -10 only, also I think both of my results are with unlocked power limit, the default is limited to 200w even with PBO (auto). After unlocking the power draw reported by PPT is ~250w with peaks at 270w.
Do you prefer all stock result?
Old 24th November 2024, 09:17   #53  |  Link
Sagittaire
Testeur de codecs
Sagittaire's Avatar
Yes, because other CPU result will be at stock.
Moreover compare PBO and stock result will be interessing.
Old 24th November 2024, 10:01   #54  |  Link
Z2697
I'll try stock setting when I have chance (and can remember), I'm that kind of person who don't like to turn off their computer
I anticipate the stock performance will be like a mini 7950X (4nm vs 5nm, get the joke?) because the 200w power limit don't seem to exist for 7950X, I don't know, could be a BIOS thing. I also upgraded the motherboard from B650 (no E) to X670E.
Old 24th November 2024, 13:59   #55  |  Link
Sagittaire
Testeur de codecs
Sagittaire's Avatar
No because:
- IPC for Zen 5 is higher than Zen 4 (+9%)
- Clock for 9950X will be higher than 7950X at full charge (4nm vs 5 nm)
- You have full AVX-512 functionality for Zen 5 and not for zen 4
In fact the PBO gain is really small (2-3% maximum)
Old 24th November 2024, 15:44   #56  |  Link
Z2697
No because:
Not if it uses 25% less power.
Old 25th November 2024, 21:59   #57  |  Link
Z2697
Stock setting (including RAM).
Actually not as bas as I thought. But bad still.
| H264 - x264 - 1080p - HDR - Multipart encoding - 1611 frames    |  32.676 s
| H265 - x265 - 1080p - HDR - Multipart encoding - 1611 frames    |  38.351 s
| AV1 - SVT-AV1 - 1080p - HDR  - Multipart encoding - 1611 frames |  46.533 s
| H266 - VVEnc - 1080p - HDR  - Multipart encoding - 1611 frames  |  76.230 s
| Overall - 1080p - HDR  - ABR Ladder encoding - 1611 frames      |  216.719 s
Old 6th December 2024, 22:24   #58  |  Link
RanmaCanada
| CPU | AMD Ryzen 9 7950X3D 16-Core Processor
| H264 - x264 - 1080p - HDR - Multipart encoding - 1611 frames | 38.318 s
| H265 - x265 - 1080p - HDR - Multipart encoding - 1611 frames | 45.435 s
| AV1 - SVT-AV1 - 1080p - HDR - Multipart encoding - 1611 frames | 57.641 s
| H266 - VVEnc - 1080p - HDR - Multipart encoding - 1611 frames | 88.859 s
| Overall - 1080p - HDR - ABR Ladder encoding - 1611 frames | 257.600 s
Old 7th December 2024, 21:47   #59  |  Link
renq
| CPU                                                             | AMD Ryzen 5 7600X 6-Core Processor
| H264 - x264 - 1080p - HDR - Multipart encoding - 1611 frames    |  88.168 s
| H265 - x265 - 1080p - HDR - Multipart encoding - 1611 frames    |  102.724 s
| AV1 - SVT-AV1 - 1080p - HDR  - Multipart encoding - 1611 frames |  125.620 s
| H266 - VVEnc - 1080p - HDR  - Multipart encoding - 1611 frames  |  185.319 s
| Overall - 1080p - HDR  - ABR Ladder encoding - 1611 frames      |  486.553 s
| CPU                                                             | 12th Gen Intel(R) Core(TM) i5-12400 (AVX512 unlocked)
| H264 - x264 - 1080p - HDR - Multipart encoding - 1611 frames    |  116.620 s
| H265 - x265 - 1080p - HDR - Multipart encoding - 1611 frames    |  141.584 s
| AV1 - SVT-AV1 - 1080p - HDR  - Multipart encoding - 1611 frames |  149.133 s
| H266 - VVEnc - 1080p - HDR  - Multipart encoding - 1611 frames  |  262.928 s
| Overall - 1080p - HDR  - ABR Ladder encoding - 1611 frames      |  686.416 s
| CPU                                                             | 12th Gen  Core i5-12400 (AVX-512 off)
| H264 - x264 - 1080p - HDR - Multipart encoding - 1611 frames    |  115.997 s
| H265 - x265 - 1080p - HDR - Multipart encoding - 1611 frames    |  142.918 s
| AV1 - SVT-AV1 - 1080p - HDR  - Multipart encoding - 1611 frames |  156.254 s
| H266 - VVEnc - 1080p - HDR  - Multipart encoding - 1611 frames  |  266.348 s
| Overall - 1080p - HDR  - ABR Ladder encoding - 1611 frames      |  680.756 s
Last edited by renq; 8th December 2024 at 10:52. Reason: Added 12400 avx512 on/off
renq is offline   Reply With Quote
Old 8th December 2024, 16:50   #60  |  Link
renq
How come the avx off results overall time is 680,756, but when you add up the four separate scores, it comes to 681,517
av1, benchmark, codec comparison, x264, x265
