Old 25th September 2024, 21:21   #21  |  Link
rgr
Fill gaps with what?
If you fill with decoded silence at the midle of a strong sound, when you recode that you can obtain a click, because encoders must be initialized with the last value of previous frame.
Support some clicks is ok but many...
Silence shouldn't generate clicks. So how does eac3to do it?
eac3to show 53 but only with 5 ms or more, sure there are much more short than 5 ms.
Possible, but after 4 hours of recording the video perfectly matches the audio.
If you want recode that file the unique solution is preserve the timestamps and aply them the the new audio (of course to video also).
ffmpeg works fine, but I have to use Avisynth
Check if your standalone recorder have other options to store your video/audio
Unfortunately not.
rgr is offline   Reply With Quote
Old 26th September 2024, 13:23   #22  |  Link
tebasuna51
tebasuna51's Avatar
eac3to only can insert or delete complete audio frames.
With some codecs can insert a silence frame or repeat the last frames (the parameter -edit=H:MM:SS.MMM,Xms with -silence or -loop)
I doubt it can create AAC silence frames then only the -loop can be used.
When the gaps are big than 21.333 it can repeat 1 frame, like I say that can produce, or not, a audible click.
For what?
Old 28th September 2024, 14:32   #23  |  Link
rgr
I checked the audio produced by eac3to -- in places where there were gaps, the sound is OK.
For what?
Postprocessing.
Old 29th September 2024, 00:19   #24  |  Link
tebasuna51
tebasuna51's Avatar
You must process video and audio in a separate way, inside AviSynth you can lose the sync.
Old 29th September 2024, 08:55   #25  |  Link
rgr
Yes, that's how it is at the moment.
Of course I can also load an audio file from eac3to into the Avisynth script and it works.
audio shift, lwlibavaudiosource
