#1642 | Link |
Life's clearer in 4K UHD
Not in the way you want to use it. No!
#1643 | Link |
If you have a stack of complex video filters, you can be happy when it still plays in normal speed. Usually it can't keep up anymore.
Being able to check the filtering result frame by frame is much more important in an editor than fast-forward playback. If you want to skip 50 frames button by button, hold the Alt key. Or pull the timeline slider with the mouse. |
#1646 | Link |
Did you re-encode the video? What media player are you using?
#1648 | Link |
With respect... You're exhausting!
#1649 | Link |
VirtualDub2 will not skip frames to ensure the frame rate during playback. It will prefer to show every frame, even if it will fall behind the timing.
Media players may do the opposite, e.g. skip decoding B frames and restrict themselves to displaying only I and P frames if that is necessary to keep up the desired playback speed. |
#1650 | Link | |
[click me] ![]() EDIT: Not sure, maybe have to also UnTick "Sync To Audio" (above 'Drop Frames When Behind').
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 14th July 2025 at 19:52. |
#1652 | Link |
There is a separate AVI source filter compatible with the ancient roots of VfW.
And there may have been input plugins for earlier VirtualDub versions which developed into the current ffmpeg based "Cached input driver", I believe... |
#1653 | Link |
Thanks. So its normal.
Another problem. I have a file compressed with ffmpeg -c:v libx265. So it's probably correct. It has a rather unusual framerate, "fpsnum=59972,fpsden=1000)" VirtualDub (the latest test version and the previous one as well) won't read it, crashing on frame 453 during playback. When jumping to the end of the file and rewinding frame by frame, you can see that the last frames are duplicates (even though they aren't). MPC plays correctly. File: https://files.fm/u/24bvfbgf45 Edit: I tested it with version VD 44282. It works fine there, no issues. Both with "Cache input driver" and with "FFmpeg (supported files)" Last edited by rgr; 24th July 2025 at 17:24. |
#1654 | Link |
VirtualDub ignores the _Matrix and _ColorRange flags when loading AviSynth scripts (it always assumes they are BT601 and limited).
I don't know if this will help, but for ffmpeg to recognize these flags, you need to use: ffmpeg.exe -avisynth_flags +all -i... . |
#1655 | Link | |
The only flag that ffmpeg does not enable by default is SAR, because that one relies on much more user awareness considering how common it is to resize things in AviSynth scripts. Code:
$ ffmpeg -h demuxer=avisynth
ffmpeg version r119297+62 master-ff9f3fb607 HEAD-1483607de1
contains: avs_pixfmts datetime merged new_pkgconfig silent_invoke versioninfo
Copyright (c) 2000-2025 the FFmpeg developers
built on Apr 18 2025 19:33:33 with gcc 14 (Ubuntu 14.2.0-19ubuntu2)
libavutil 60. 1.100 / 60. 1.100
libavcodec 62. 0.101 / 62. 0.101
libavformat 62. 0.100 / 62. 0.100
libavdevice 62. 0.100 / 62. 0.100
libavfilter 11. 0.100 / 11. 0.100
libswscale 9. 0.100 / 9. 0.100
libswresample 6. 0.100 / 6. 0.100
libpostproc 59. 1.100 / 59. 1.100
Demuxer avisynth [AviSynth script]:
Common extensions: avs.
AviSynth demuxer AVOptions:
-avisynth_flags <flags> .D......... set flags related to reading frame properties from script (AviSynth+ v3.7.1 or higher) (default field_order+range+primaries+transfer+matrix+chroma_location)
field_order .D......... read field order
range .D......... read color range
primaries .D......... read color primaries
transfer .D......... read color transfer characteristics
matrix .D......... read matrix coefficients
chroma_location .D......... read chroma location
sar .D......... read sample aspect ratio
ImageSource("GsKynKVaUAI7COX.jpeg").Crop(0,0,0,-1).ConvertToYV12()
propset("_FieldBased",0)
propset("_Primaries",4)
propset("_Transfer",4)
propset("_Matrix",4)
propset("_ChromaLocation",2)
propset("_ColorRange",0)
propset("_SARNum",4) # this and SARDen set to nonsense just to show whether it gets read
propset("_SARDen",3)
ffmpeg -v verbose -i test.avs Code:
Input #0, avisynth, from 'test.avs': Duration: 00:00:41.71, start: 0.000000, bitrate: 0 kb/s Stream #0:0: Video: rawvideo, 1 reference frame (I420 / 0x30323449), yuv420p(pc, fcc/bt470m/bt470m, progressive, topleft), 680x254, 24 fps, 24 tbr, 24 tbn Code:
Input #0, avisynth, from 'test.avs': Duration: 00:00:41.71, start: 0.000000, bitrate: 0 kb/s Stream #0:0: Video: rawvideo, 1 reference frame (I420 / 0x30323449), yuv420p(pc, fcc/bt470m/bt470m, progressive, topleft), 680x254, SAR 4:3 DAR 1360:381, 24 fps, 24 tbr, 24 tbn |
#1658 | Link | ||
For this reason, VirtualDub does not receive additional video stream parameters. See the description of the VIDEOINFOHEADER and BITMAPINFOHEADER structures.
MPC-BE 1.8.9 and Nightly builds | VideoRenderer | ImageSource | ScriptSource | BassAudioSource |
#1659 | Link | |
What about this file? https://files.fm/u/mywfgz46nj (it's short, so sometimes you have to jump to the end several times and go back frame by frame) This appears to be a problem with H265 files with open GOP. The effect should be like: this.https://gcdnb.pbrd.co/images/Q3xlj4A5fmA2.png?o=1 Last edited by rgr; 6th August 2025 at 12:29. |
#1660 | Link | |
However, VDub can probably abandon the default BT601, or at least apply the rule that if the height is >=720px, BT709 is assumed. At least some information about the decoding format (BT601/709/RGB, limited/full range, etc.) on the bottom bar would be useful
| Display Modes | |
