#1621 | Link | |
avcodec-61.dll avformat-61.dll avutil-59.dll swresample-5.dll swscale-8.dll
MPC-BE 1.8.9 and Nightly builds | VideoRenderer | ImageSource | ScriptSource | BassAudioSource |
#1622 | Link | |
It's related to the latest avlib_vdplugin_1.0.0.357, because as soon as I replace that with the older avlib-1.vdplugin 0.7.1.264 it works. |
#1623 | Link |
Can you reproduce the crash in normal mode (not capture mode)?
x64 or win32?
MPC-BE 1.8.9 and Nightly builds | VideoRenderer | ImageSource | ScriptSource | BassAudioSource Last edited by v0lt; 22nd May 2025 at 04:48. |
#1624 | Link | |
I also tested this with Beta win32 version and same issue!! Crash in both Capture and Normal mode. Last edited by SupermanTV; 22nd May 2025 at 05:44. |
#1625 | Link |
Do you have any details about the kind and possible reason of the crash? You know, reasons can be very different, like e.g. a missing runtime DLL or an unsupported CPU instruction ...
#1626 | Link |
I'm attaching the crash report..
Things I'm wondering about as possible causes: 1 - AMD chips? I only tested on my PC (AMD FX8370 *Win10 latest), and my laptop (AMD Ryzen 7 *Win11 latest). 2 - Anything different with the Compiler used? 3 - Maybe backtracking changes made from the Current Stable version. (*like this one: "Added saving and reading of encoder settings from the registry.") Would that affect the way the avlib_vdplugin communicates with FFMPEG BtbN maybe, not plugging ProRes codec properly? Last edited by SupermanTV; 22nd May 2025 at 18:08. Reason: term |
#1627 | Link |
Attachments are best posted on file sharing services.
Plain text can be posted on Pastebin.com. PS: I checked encoding in Prores on two computers and one laptop. At my request, a colleague checked on his computer. There were no crashes.
MPC-BE 1.8.9 and Nightly builds | VideoRenderer | ImageSource | ScriptSource | BassAudioSource Last edited by v0lt; 22nd May 2025 at 19:28. |
#1628 | Link | |
https://pastebin.com/ASeASUiQ Did you test on AMD chips? |
#1629 | Link |
#1633 | Link | |
If you know the video is 709 colour space but decode format doesn't show -709 in actual format box then click on 709 colour space. The correct colour will show on the panes then you can use the filters correctly. If you leave it at 'no change' then it won't affect the colour output so long there is 'no conversion' in the compression box. Tests. 4 clips. input 709 - output 709 - 709 on media info. colour same as original video - good input 709 - decode 601 - output 601 - 601 on media info. colour same as original video but mislabelled as 601 - bad input 709 - decode 601 - output forced 601 - 601 on media info. colour same as original video but mislabelled as 601 - bad input 709 - decode 601 - output forced 709 - 709 on media info. colour change from original video with correct label as 709 - bad Hope this helps. |
#1634 | Link |
Does anyone have the "Display > Use effect file: display.fx" setting working? What is it for? Are there any example .fx files that will work in VirtualDub?
#1635 | Link | |
Big Bit Savings Now !
A junction for later exploration left by Avery Lee, I guess. I had no use for it so far, but others might.
"To bypass shortcuts and find suffering...is called QUALity" (Die toten Augen von Friedrichshain) "Data reduction ? Yep, Sir. We're that issue working on. Synce invntoin uf lingöage..." Last edited by Emulgator; 12th June 2025 at 12:53. |
#1636 | Link | |
I found an example of display.fx in the help.
#1638 | Link |
Video - Frame Rate... - Change frame rate to (a higher value); but this will probably mess up the audio, if present. And the result may not match a secondary format specification.
| Display Modes | |
