#21101 | Link | |
I have tried every fix I can find, regarding this issue, and nothing works. Except what I suggested. |
#21102 | Link |
Unfortunately your solution (clean install and then rebuild apps etc) takes a couple of days on my setup (I know i did it last November) so I think I will see if I can find anything with a couple of clean installs (23H2) and 24H2 and a something like regshot. Hopefully can find some time over the weekend and see if I find anything.
#21103 | Link | |
Until some brainiac on this forum comes up with a solution that actually does work, then that's it ! |
#21104 | Link |
Dear Atak Snajpera
There're some errors caused by the overlay script in RipBot. Sample video is here (1080p): https://mega.nz/file/QkpGETzI#7ud8IB...NzGlgk1BgsfexI A. Overlay's Scaling Factor Error (UNRESIZED) The error appears, see this pic, only at certain values as shown below, it's when the video is NOT RESIZED. Code:
| 0.03 | 0.06 | 0.08 | 0.13 | 0.16 | 0.18 | 0.23 | 0.26 | 0.28 | 0.33 | 0.36 | 0.38 | 0.43 | 0.46 | 0.48 | | 0.53 | 0.56 | 0.58 | 0.63 | 0.66 | 0.68 | 0.73 | 0.76 | 0.78 | 0.83 | 0.86 | 0.88 | 0.93 | 0.97 | 0.98 | Another error appears, also only at certain values, as listed below, it only occurs in conditions when the video is RESIZED from 1080p to a lower, either by selecting one of the predefined resolution options (i.e. HD-Ready 1280x720), or by specifying the desired resolution (i.e. Custom [1.78:1]). Code:
| 0.04 | 0.07 | 0.09 | 0.14 | 0.17 | 0.19 | 0.24 | 0.27 | 0.29 | 0.34 | 0.37 | 0.39 | 0.44 | 0.47 | 0.49 | | 0.54 | 0.57 | 0.59 | 0.64 | 0.67 | 0.69 | 0.74 | 0.77 | 0.79 | 0.84 | 0.87 | 0.89 | 0.94 | 0.98 | 0.99 |
Cheers, D Last edited by dipais; 5th February 2025 at 16:31. |
#21105 | Link | |
When I tested using one of my fresh 24h2 machines as a client, what I noticed is that the share permission is not being set correctly. On a box earlier than 24H2 or upgraded to 24H2, that share permission is set to everyone-full control. On the 24H2 PC from scratch acting as a client, the share permission on mine is set to "Builtin" with full control. While the DE Client window is up and not connecting to anything at the start of a job, if you go into the share settings of the ripbot264temp folder and add everyone with full control, then connect each server in the client window, they will then connect and finish the job. That share command must be sent to the folder programmatically at the start of each job, as once 1 job ends and another is started, the permissions reset back to "Builtin" and you would have to add in everyone again and repeat the process. I realize this is not an ideal work around.... 24H2 must have changed something in the way someone can programmatically set a share permission. This is a separate issue that may arise also, sharing without passwords with 24H2. I still had to turn off the smb signing on my server only fresh 24H2 installs to reach back to the client share. Bottom Line is Microsoft really tightened down SMB with 24H2, and it is going to take some time and patience to work through everything. |
#21106 | Link |
This is my script for sharing C:\Temp\RipBot264temp folder (manually change it if it is necessary).
Paste this to notepad and save as ShareFolder.cmd . Run it as ADMINISTRATOR and check output messages. Code:
set MySid=S-1-1-0
for /f "delims=' skip=1" %%a in ('"wmic path win32_account where SID='%MySid%' get name"') do (
set myvar=%%a
goto :loop_end
:loop_end
call :Trim myvar %myvar%
call :Share
:Trim
SetLocal EnableDelayedExpansion
set params=%*
for /f "tokens=1*" %%a in ("!Params!") do EndLocal & set %1=%%b
exit /b
:Share
net share RipBot264temp /DELETE /Y
net share RipBot264temp="C:\Temp\RipBot264temp" /GRANT:"%myvar%",FULL
icacls "C:\Temp\RipBot264temp" /T /C /Q /Grant:R %MySid%:(OI)(CI)F
icacls "C:\Temp\RipBot264temp" /T /C /Q /inheritance:e
pause
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 6th February 2025 at 00:57. |
#21107 | Link | |
on client that works: D:\>net share RipBot264temp="d:\Temp\RipBot264temp" /GRANT:"Everyone",FULL RipBot264temp was shared successfully. On one that doesn't: D:\>net share RipBot264temp="D:\Temp\RipBot264temp" /GRANT:"",FULL System error 3 has occurred. If I hardcode /GRANT:"Everyone",FULL in place of the /GRANT:"%myvar%",FULL it appears to be OK |
#21109 | Link |
Try this. WMIC replaced by Powershell by DeepSeek AI.
Fresh 24H2 does not have WMIC tool. When you upgrade from older version WMIC.exe is still there. Code:
@echo off
setlocal enabledelayedexpansion
set "SID=S-1-1-0"
set "USERNAME="
for /f "delims=" %%a in ('
powershell -Command "$sid = New-Object System.Security.Principal.SecurityIdentifier('%SID%'); try { $name = $sid.Translate([System.Security.Principal.NTAccount]).Value; Write-Output $name } catch { exit 1 }"
') do set "USERNAME=%%a"
if "%USERNAME%"=="" (
echo No user name found for : %SID%
exit /b 1
) else (
echo Found user name for %SID%: %USERNAME%
endlocal
call :Trim myvar %USERNAME%
call :Share
:Trim
set params=%*
exit /b
:Share
icacls "C:\Temp\RipBot264temp" /T /C /Q /Grant:R %Sid%:(OI)(CI)F
pause
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 6th February 2025 at 01:03. |
#21110 | Link | |
D:\>for /F "delims=" %a in (' powershell -Command "$sid = New-Object System.Security.Principal.SecurityIdentifier(''); try { $name = $sid.Translate([System.Security.Principal.NTAccount]).Value; Write-Output $name } catch { exit 1 }" ') do set "USERNAME=%a" D:\>set "USERNAME=New-Object : Exception calling ".ctor" with "1" argument(s): "Value was invalid." D:\>set "USERNAME=Parameter name: sddlForm"" D:\>set "USERNAME=At line:1 char:8" D:\>set "USERNAME=+ $sid = New-Object System.Security.Principal.SecurityIdentifier(''); t ..." D:\>set "USERNAME=+ ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~" D:\>set "USERNAME= + CategoryInfo : InvalidOperation: ( [New-Object], MethodInvocationException"D:\>set "USERNAME= + FullyQualifiedErrorId : ConstructorInvokedThrowException,Microsoft.PowerShell.Commands.NewObjectCommand" D:\>set "USERNAME= " D:\>if " " == "" ( echo No user name found for : exit /b 1 ) else (echo Found user name for : ) Found user name for : D:\>endlocal D:\>call :Trim myvar D:\>SetLocal EnableDelayedExpansion D:\>set params=myvar D:\>for /F "tokens=1*" %a in ("!Params!") do EndLocal & set myvar=%b D:\>EndLocal & set myvar= D:\>exit /b D:\>call :Share D:\>net share RipBot264temp /DELETE /Y RipBot264temp was deleted successfully. D:\>net share RipBot264temp="D:\Temp\RipBot264temp" /GRANT:"",FULL RipBot264temp was shared successfully. D:\>icacls "D:\Temp\RipBot264temp" /T /C /Q /Grant:R OI)(CI)FSuccessfully processed 420 files; Failed processing 0 files D:\>icacls "d:\Temp\RipBot264temp" /T /C /Q /inheritance:e Successfully processed 420 files; Failed processing 0 files |
#21111 | Link |
works fine on my 24h2 in VM (RUN AS ADMINISTRATOR)
#21112 | Link |
script now runs, I had the drives letters wriong. however the share permissions are set to my local account name, not everyone on my pc just doing a %myvar% returns the local account name as well D:\>%myvar% 'rleva' is not recognized as an internal or external command, operable program or batch file. Last edited by rlev11; 6th February 2025 at 01:24. |
#21114 | Link |
Try this
rem @echo off
set "SID=S-1-1-0"
set "USER="
') do set "USER=%%a"
if "%USER%"=="" (
echo No username found for %SID%
exit /b 1
) else (
echo Found username for %SID%: %USER%
net share RipBot264temp="C:\Temp\RipBot264temp" /GRANT:"%USER%",FULL
icacls "C:\Temp\RipBot264temp" /T /C /Q /Grant:R *%SID%:(OI)(CI)F
endlocal
pause
#21115 | Link | |
D:\>if "Everyone" == "" ( echo No username found for S-1-1-0 exit /b 1 ) else (echo Found username for S-1-1-0: Everyone ) Found username for S-1-1-0: Everyone D:\>net share RipBot264temp /DELETE /Y RipBot264temp was deleted successfully. D:\>net share RipBot264temp="D:\Temp\RipBot264temp" /GRANT:"Everyone",FULL RipBot264temp was shared successfully. D:\>icacls "D:\Temp\RipBot264temp" /T /C /Q /Grant:R *S-1-1-0 OI)(CI)FSuccessfully processed 420 files; Failed processing 0 files D:\>icacls "D:\Temp\RipBot264temp" /T /C /Q /inheritance:e Successfully processed 420 files; Failed processing 0 files Last edited by rlev11; 6th February 2025 at 01:50. |
#21116 | Link |
Yeah. It also works on Windows 7 as well. I will update EncodingClient.exe this weekend with this new script...
Without DeepSeek AI I would have no idea how to get that EVERYONE string with powershell.
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 6th February 2025 at 01:55. |
#21118 | Link |
do you still have WMIC.exe on updated PC?
#21119 | Link |
checking, yes... know where you are going with this I think, I'll run the script on that one and make sure it doesn't go BOOM. give me a minute
Looks Good D:\>set "SID=S-1-1-0" D:\>set "USER=" D:\>for /F "delims=" %a in (' powershell -Command "$sid = New-Object System.Security.Principal.SecurityIdentifier('S-1-1-0'); try { $name = $sid.Translate([System.Security.Principal.NTAccount]).Value; Write-Output $name } catch { exit 1 }" ') do set "USER=%a" D:\>set "USER=Everyone" D:\>if "Everyone" == "" ( echo No username found for S-1-1-0 exit /b 1 ) else (echo Found username for S-1-1-0: Everyone ) Found username for S-1-1-0: Everyone D:\>net share RipBot264temp /DELETE /Y RipBot264temp was deleted successfully. D:\>net share RipBot264temp="D:\Temp\RipBot264temp" /GRANT:"Everyone",FULL RipBot264temp was shared successfully. D:\>icacls "D:\Temp\RipBot264temp" /T /C /Q /Grant:R *S-1-1-0 OI)(CI)FSuccessfully processed 1184 files; Failed processing 0 files D:\>icacls "D:\Temp\RipBot264temp" /T /C /Q /inheritance:e Successfully processed 1184 files; Failed processing 0 files Last edited by rlev11; 6th February 2025 at 02:02. |
#21120 | Link |
ok. So One problem solved. Time to bed now (it is after 02:00)...
| Tags |
| 264, 265, appletv, avchd, bluray, gui, iphone, ipod, ps3, psp, ripbot264, x264 2-pass, x264 gui, x264_64, x265, xbox360 |
| Display Modes | |
