Old 18th September 2013, 09:23   #1  |  Link
Cedvano
Blu-ray Specification
I would like to know if it's possible to find the last Blu-ray Specification.
I'd like know how work CLPI, MPLS...
It's for my own knowledge.
Thank you very much.
Cedvano is offline   Reply With Quote
Old 18th September 2013, 12:42   #2  |  Link
See here:
http://www.blu-raydisc.info/format-s...val-how-to.php
Do not ask for free or pirated versions as it violates our forum rule 6.
You may find some public domain descriptions of MPLS, CLPI, etc., using an appropriate Google search.
Old 18th September 2013, 14:05   #3  |  Link
Ghitulescu
Ghitulescu's Avatar
Originally Posted by Cedvano View Post
There is no secret in how to obtain them.
The legal owner is Blu-ray Disc Association, which has the web site neuron2 showed you.
So find quickly 5000$ and be sure you memorised all of them within one year, or find another 5000$ green brick of dead presidents.
Born in the USB (not USA)
Old 18th September 2013, 14:14   #4  |  Link
Cedvano
Ok, thanks. I did not know that it was paying.
It's expensive doing my curiosity.
Thank you very much for your help.
blu-ray, specifications
