30th March 2020, 09:15 | #681 | Link | ||
Qbittorrent post: https://github.com/qbittorrent/qBittorrent/issues/12316 |
30th March 2020, 17:36 | #682 | Link |
MKVToolNix author
I've just modified mkvmerge to abort with appropriate error messages if the user attempts to append or split FLAC audio tracks. Additionally I've converted the text from issue 953 sneaker_ger has linked to into an official entry in my FAQ.
Latest MKVToolNix is v83.0 If I ever ask you to upload something, please use my file server. |
31st March 2020, 07:57 | #683 | Link |
Thanks Mosu
1st April 2020, 13:15 | #684 | Link |
Is there a way to make a MVC (3D Blu-ray) mux with MKVToolNix directly from the mounted .ISO of the decrypted Blu-ray? I know for regular 2D blu-rays you can just drag in the .pls. Doing that on a 3D blu-ray gives you a 2D mux.
2nd April 2020, 08:36 | #686 | Link |
MKVToolNix author
It might happen one day, but I've never really been motivated to work on that functionality.
2nd April 2020, 12:56 | #687 | Link |
So the MKV container can handle MVC video (from a 3D blu-ray), and MKVToolNix can correctly handle/process/manipulate/export a MKV that already contains a MVC video stream (from a 3D blu-ray), but it has no ability to mux it from the demuxed streams or a blu-ray source? What's different about having it already in a .mkv vs. demuxed elementary streams?
2nd April 2020, 21:44 | #688 | Link |
MKVToolNix author
Data already present in Matroska can simply be kept as-is. Data read from other container formats has to be parsed and converted into structures suitable for storage in Matroska.
4th April 2020, 15:11 | #690 | Link |
MKVToolNix author
MKVToolNix v45.0.0 released
Hello dear people,
I sincerely hope you're all healthy or at least on the way there. I'm fine, and having some more time on my hands I was able to get more done wrt. MKVToolNix. So this release is a bit bigger than the previous ones. Nothing's changed for package managers. Here are the usual links: the MKVToolNix home page, the Windows installer/portable version & macOS DMG & Linux AppImage and the source code. The Windows and macOS binaries as well as the Linux AppImage are available already. The other Linux binaries are still being built and will be available over the course of the next couple of hours. Here are the NEWS since the previous release: Version 45.0.0 "Heaven in Pennies" 2020-04-04 New features and enhancements
Bug fixes
So try to have some fun, especially in these trying times.
6th April 2020, 11:12 | #693 | Link |
Is it possible to log actual start and finish timecodes for all parts from "--split parts:" output?
as a temporarily solution I am using "--split timecodes:" instead of "--split parts:", this way I can calculate times manually Last edited by zn; 6th April 2020 at 22:53. |
11th April 2020, 07:26 | #694 | Link |
Small question:
I noticed that mkv has rotaion options:
-> Do VLC, MPC-HC and other players support these? (they would be useful when reencoding mp4 files which were recorded by a mobile with a mp4 rotation flag) Cu Selur Ps.: Okay, did a small test using: Code:
mkvmerge --ui-language en -o "E:\Output\source with rotation flag.mkv" --global-tags "E:\Temp\source with rotation flag_08_56_54_1010__06.xml" -d 0 --default-track 0:yes --projection-type 0:0 --projection-pose-roll 0:90 --track-name 0:"VideoHandle" --language 0:en --default-duration 0:2984100/100000fps --aspect-ratio-factor 0:1/1 --fourcc 0:MP4V --no-chapters --compression -1:none --forced-track 0:yes --no-audio --no-subtitles --timecodes 0:"E:\Temp\timecodeV2_08_56_54_1010.tc" "E:\Temp\08_56_54_1010_03.264" Last edited by Selur; 11th April 2020 at 07:59. |
14th April 2020, 05:51 | #695 | Link |
@Mosu
https://bugreports.qt.io/browse/QTBUG-82701 What's the current version of Qt used in the latest version of MKVToolNix? |
14th April 2020, 18:28 | #696 | Link |
MKVToolNix author
You can check the Qt version your particular copy was built against via "Help" → "System information".
14th April 2020, 18:29 | #697 | Link |
MKVToolNix author
There's no functionality that outputs those timestamps.
14th April 2020, 22:41 | #699 | Link |
MKVToolNix author
v45 is built with Qt 5.14.2, which is the latest release available.
matroska |
