Old 29th September 2019, 15:19   #3541  |  Link
Jamaika
Hi Selur
Have you tried to add codec jctvc or jvetvvc to ffmpeg? Does 'media-autobuild_suite' enable this?
Cu Jamaika
Jamaika is offline   Reply With Quote
Old 29th September 2019, 15:26   #3542  |  Link
Selur
Selur's Avatar
Nope, I've never tried jctvc or jvetvvc and MBAS doesn't support them.
Old 29th September 2019, 15:31   #3543  |  Link
Jamaika
Well done with hybrid.
I ask out of curiosity because I was interested in your question about the new svt hevc codec?
Old 29th September 2019, 15:35   #3544  |  Link
Selur
Selur's Avatar
Thought about adding support for the SVT encoders to Hybrid, but that turns out to be dead end for now, since the seem to be more broken then working atm.
Old 29th September 2019, 15:36   #3545  |  Link
Jamaika
Maybe, have you added SVT to x265 in the new Hybrid?
Old 29th September 2019, 16:41   #3546  |  Link
Selur
Selur's Avatar
No I haven't added support for SVT since compiling x265 with SVT support failed in MBAS and I prefer to use the standalone application since it offers access to more of the switches.
Atm. STVs HEVC encoder (same for x265 with SVT) isn't really useful for me since you can't specify VUI flags for luma scale (pc/tv) or color matrix, thus ending up with wrong colors on playback.
(Also with piping not working properly in the current stand alone StvHevcEncApp, I wouldn't recommend using this encoder for anything but general technology tests,..)
Cu Selur
Old 2nd October 2019, 20:53   #3547  |  Link
Rumbah
I just noticed that with Hybrid 2019.09.30.1 the x264 --b-adapt setting is one too low:
From the documentation:
      --b-adapt <integer>     Adaptive B-frame decision method [1]
                                  Higher values may lower threading efficiency.
                                  - 0: Disabled
                                  - 1: Fast
                                  - 2: Optimal (slow with high --bframes)
In the advanced x264 Hybrid setting it says and sets optimal=1 and fast=0. The presets Hybrid sets get it wrong, too.
Rumbah is offline   Reply With Quote
Old 3rd October 2019, 10:43   #3548  |  Link
aj89
HI
How ican remove gui encode frome media info
i dont like show hybrid name
aj89 is offline   Reply With Quote
Old 3rd November 2019, 09:55   #3549  |  Link
Selur
Selur's Avatar
Hybrid rev 2019.11.03.1:
*fixed*
  • VideoModel: loading a preset overwrote the resolution&c
  • Vapoursynth: SMDeGrain Ui glitch
  • Vapoursynth: KNLMeansCL, color adjustment for cmode
  • Vapoursynth: LWLibavSource: don't add prefer_hw for AVC with high bit depth
  • Vapoursynth: CTMF dependency missing for TemporalDegrain depending of Input and/or settings
*changed*
  • Analyse: Always using '--File_TestContinuousFileNames=0' with MediaInfo.
  • Avisynth: adjust interlaced crop handling
  • NVEncC: adjusted progress indication
  • Subtitle: Teletext handling
  • muxing: explicilty set empty 'name'-tags when using MP4box to avoid a bug in MediaInfo
  • Video: NVEncC support for --multiref-l0/--multiref-l1
  • Video: adjusting To Kvazaar updates
*added*
  • Vapoursynth: FilterView 'difference'-mode
  • Video: support SVT-HEVC
  • Avisynth: added support for TemporalDegrain2
-> downloads: http://www.selur.de/downloads
Cu Selur
Old 3rd November 2019, 09:58   #3550  |  Link
Selur
Selur's Avatar
Arghh,.. email notification doesn't seem to work in the forum atm.
@Rumbah: Opening Hybrid, 'x264->Frames->B-Frame Settings->Adaptive b-frame decision' odes list 'fast', 'optimal' and 'disabled', but the command line seems wrong.
-> will look into it => disabled and optimal are switched :/
@aj89: If you don't like Hybrid, don't use it. (I don't see any valid reason for not adding that info during the muxing.)
Old 4th November 2019, 18:49   #3551  |  Link
von Suppé
von Suppé's Avatar
Hi Selur,
I get an error when trying to recode a video (pls from a BD) with x264 (with "--bluray compat" in the commandline). It says: "Current output framerate 29.97 is not allowed.
29.97 fps is allowed for bluray when video is interlaced. The source is a BD.
MediaInfo on the source-playlist:
Scan type: MBAFF
Scan type, store method: Interleaved fields
Scan order: Top Field First
I recall having these types of video transcoded earlier succesfully.
Am I doing something wrong? Using your latest version.
Cheers
von Suppé
Old 10th November 2019, 09:36   #3552  |  Link
Selur
Selur's Avatar
Need more details, for example what framer rate and resolution does you video have?
Hybrid should check that you use one of the following resolution and frame rate combinations:
  • 1920/1440x1080 23.976p/24p/25i/29.97i
  • 1280x720 23.97p. 24p, 50p, 59,940p
  • 720x576 25i
  • 720x480 29.97i
and only complain if blu-ray comatibility is enabled and none of these combinations is used.
If you aim for interlaced output, make sure to enable either 'x264->Frames->Advanced Frame Settings->Interlaced encoding' or 'x264->Frames->Advanced Frame Settings->Force bff' otherwise x264 and Hybrid would assume that the output should be progressive.
Cu Selur
Ps.: I assume 'x264->Base->Restriction Settings->Hardware' is enabled and set to 'Bluray/AVCHD' and you didn't add '--bluray-compat' through a custom command line addition.
Old 10th November 2019, 12:05   #3553  |  Link
von Suppé
von Suppé's Avatar
MediaInfo states:
Width: 1920 pixels
Height: 1080 pixels
Frame rate: 29.970 (30000/1001) FPS
Checking "Interlaced encoding" both with and without "Force bff"checked gave me same error "Crashed with exit status 0"
I also remuxed playlist into mkv and tried that as input, same errors.
Edit: Got it, sorry. My bad, my guess. Audio was set to "ignore". Changed to "passthrough all", now it's running.
Old 10th November 2019, 14:44   #3554  |  Link
Selur
Selur's Avatar
Don't realls get what the audio has to with it all, but if you found the problem happy that worked out.
Cu Selur
Old 23rd November 2019, 22:29   #3555  |  Link
Selur
Selur's Avatar
Hybrid rev 2019.11.23.1:
*fixed*
  • muxing: ffmpeg indicating vfr even when video is cfr
  • video: x265 HDR-10+ signaling
  • video: maxCLL typo related to STV-HEVC encoding (can't be used there anyways so more a cosmetic fix)
  • video: NVEncC multi level typo bug
  • Avisynth: crop not working with custom resizer
  • muxing: mp4 language passthrough
  • gui: VIDEOHANDLING problem on Linux
*changed*
  • profiles: Do not allow to load Global Profiles while a source is loaded.
  • Vapoursynth: Make sure that after QTGMC the clip is preceived as frame based.
  • video: NVEncC allow L0 and L1 references at the same time
  • video: x265 added support for 'scenecut-aware-qp' with 'scenecut-window' and 'max-qp-delta'
Cu Selur
Old 27th November 2019, 09:46   #3556  |  Link
ReinerSchweinlin
I did my first test runs with hybrid and have to say the amount of capabilities in hybrid is impressive, thank you for this nice peace of software
I wanted to resize some stuff with waifu2x which works good. Since my testfiles are all yu12 (XVID, old Cartoons, etc..) - would it be possible to change the intermediate Colourspace to YU12 or RGB24 instead of RGB48 - would speed benefit from it? I don´t need 1080p to 8k resizes, but want to restore some rare old footage, some captured from VHS.
Any advice on a potent grafix card for waifu2x resize up to around 300 $/€? It seems NVIDIA is supportet better but some ATI Cards have mor bang for the buck (maybe use vulkan with ati)?
Old 27th November 2019, 10:18   #3557  |  Link
ReinerSchweinlin
I just noticed one thing: after resizing with waifu2x, the resulting file seems to have a different color range than the original one - the script seems to convert to TV levels, black now is dark grey and bright areas are a little dimmer (maybe PC->TV Conversion forced?) - any way I can change that in the settings? Looked around, but can´t find it.
Old 27th November 2019, 11:25   #3558  |  Link
Sharc
With avisynth enabled (or similar with vapoursynth):
Tab Filtering -> Avisynth -> Tab Color -> Tickbox ColorYUV -> Levels …..
Old 27th November 2019, 14:50   #3559  |  Link
ReinerSchweinlin
Thank you. I have nothing selcted and "ange conversion" says: "do not"... But it does... I tried setting levels manualy, didn´t help. The script says:
# Setting color range to TV (limited) range.
clip = core.std.SetFrameProp(clip=clip, prop="_ColorRange", intval=1)
maybe this is causing the color change?
Old 27th November 2019, 16:35   #3560  |  Link
ReinerSchweinlin
I did another check - if waifu2x is disabled, colours are passed through unchanged. With waifu2x enabled, range is altered automaticaly.
