Old 13th October 2024, 20:25   #1  |  Link
eXtremeDevil
eXtremeDevil's Avatar
S-Video input video artifacts
Hi, I'm trying to capture a VHS. I have an August VGB100 Video Capture device:
https://www.amazon.co.uk/august-capt.../dp/B008F0SARC
It has two inputs, composite and S-Video. I understand S-Video offers a higher quality, so I'm trying to use that one to capture. However, compared to composite input, I see some weird artifacts on the video:
Composite:
S-Video:
Sorry about frames not being the same, but I couldn't pause the VHS. But I see the effect is clearly visible. The composite signal may have lower quality, but at least it seems somewhat clean.
I have tried with different S-Video cables and also with another capture device, a Hauppauge USB-Live 2, and the results are the same.
However, I have also tried the same cables and the same capture devices with a Sony Hi8 HandyCam and the effect is less visible with the August device, and nonexistent with the Hauppauge device.
So now I suspect of two things: the VHS player itself, or the SCART to S-Video/Composite device I use, something like this:
Where do you think the problem could be? Am I in the right direction? What is the origin of this effect?
Thanks in advance!
eXtremeDevil is offline   Reply With Quote
Old 13th October 2024, 23:07   #2  |  Link
Sharc
Your VHS player seems not to support S-Video but Composite only (or the S-Video is not wired to the SCART plug). What model is your player?
If it would support S-Video it would have an S-Video port in addition to the SCART - and you wouldn't need the SCART adapter. Your adapter cannot convert a Composite signal to S-Video. The S-video signal (Y/C wires) must be provided by the player like your Hi8 camera apparently does.
Old 14th October 2024, 08:40   #3  |  Link
eXtremeDevil
If the S-Video is not wired to the SCART plug, how am I getting an image? Could you please explain me something? I thought any SCART output could be converted to any Composite and/or S-Video input, but are you saying not all SCART output ports are the same, internally?
I have actually search for VHS players with native S-Video ports in second hand shops here in my city, but all the players I found had only SCART ports, nothing more. Are the ones with S-Video rarer?
Old 14th October 2024, 12:58   #4  |  Link
Sharc
Signal crosstalk between wires and/or within the adaptor plug for example.
No. For S-Video you need a player which supports it. Typically an S-VHS recorder/player (preferably with TBC) rather than just a VHS recorder/player.
Only S-VHS recorders/players will provide S-Video which is wired to specific pins on the SCART plug (Europe) and/or have a separate S-Video connector.
Again: What is your player model (brand, type)? Does it have a menu setting for "S-Video"? Check the manual.
Yes, S-VHS recorders/players are of higher quality, successors of VHS, more expensive, and equipment in good condition is the longer the more difficult to find. In Europe the S-Video (if the player supports it at all) is usually also wired to the SCART plug on dedicated pins.
Maybe take a look here:
https://vcrshop.com/category/vcr/
Look for 'S-VHS' or 'SUPER-VHS' devices. But first read the manual of your equipment to see if it is S-VHS compliant or VHS only. Check the menu settings.
Edit:
If you have to live with Composite use a capture device with a good luma/chroma separating filter. I don't know the August VGB100. The USB-Live 2 is also no masterpiece in this respect. The I-O Data GV-USB2 performs better in this respect.
Old 14th October 2024, 13:06   #5  |  Link
eXtremeDevil
No. For S-Video you need a player which supports it. Typically an S-VHS recorder/player rather than just a VHS recorder/player.
Again: What is your player model (brand, type)? Does it have a menu setting for "S-Video" at all?
Understood!
Sorry, I forgot to mention the model. It seems to be a Phillips VR 550. I don't have the remote right now, so I cannot access the menu, but after your explanations, I doubt it has S-Video capability.
Yes, as S-VHS recorders/players are of higher quality, successors of VHS, more expensive, and equipment in good condition is the longer the more difficult to find. In Europe the S-Video (if the plyer supports it) is usually also wired to the SCART plug.
Understood, my father bought this VCR back in the day, but I doubt it was a higher quality one. I guess I'll stick with composite, it is not worth the cost of buying a higher model for what I want to digitalize.
Signal crosstalk between wires and/or within the adaptor plug.
I'm not sure I get this. If my VCR does not have S-Video capability, how can I see the image? Is it something like "some pins are missing so you see something, but with artifacts, because of the specific S-Video pins not being present?
BTW, another question not related to this topic (sorry): Where does the wobble effect come from? I mean the typical, not a hard one that makes the video impossible to watch. I tried to find info but I had no success. Is it the VCR motor, or is it the tape? Just curious about this.
Thanks in advance!
Old 14th October 2024, 13:43   #6  |  Link
Sharc
The Philips VR500 is VHS only. No S-video capability.
The wobbling comes from time base errors (old tapes, poor/worn equipment ...).
It can be suppressed by using a TBC (TimeBaseCorrector) function as provided internally by high end S-VHS players, or by using extra external equipment. A low cost variant for stabilizing the picture would be to use a (recommended) DVD-recorder in passthrough mode, means in an arrangement like your player -> DVD recorder in passthrough with Composite IN -> S-video OUT -> capture device S-video IN.
Old 14th October 2024, 13:47   #7  |  Link
eXtremeDevil
A low cost variant would be to use a (recommended) DVD-recorder in passthrough mode, means in an arrangement like your player -> DVD recorder in passthrough with S-video OUT -> capture device.
Does all DVD-recorders have passthrough mode? What you're saying is, the DVD-recorder would be the one de-wobbling the image via software, right?
Old 14th October 2024, 14:02   #8  |  Link
Sharc
Basically most will, AFAIK. There are recommended models though like some Panasonics. You find a lot about this over at the videohelp forum and at digitalfaq.com
Old 14th October 2024, 14:22   #9  |  Link
eXtremeDevil
Cool, I'll try to find more info about an old Pioneer model I have. Although VCR to DVR connection would by via SCART, right?
Can you answer my last question about the other issue, please?
Old 14th October 2024, 14:39   #10  |  Link
Sharc
Yes. VCR to DVD recorder via SCART. Study the principles
As I wrote: Electromagnetic spillover (crosstalk) from composite signals to the S-wires of the cable. Check the wiring of the SCART connector and the wiring of the adapter. I don't have the circuit diagrams and the wiring details of your equipment, what gets looped to where etc.
You can find a lot of info about VHS capturing at the german gleitz forum as well.
https://gleitz-info.translate.goog/f..._x_tr_pto=wapp
Old 14th October 2024, 14:41   #11  |  Link
eXtremeDevil
Cool, thanks for all the information!
Old 14th October 2024, 17:54   #12  |  Link
Sharc
You get these artifacts when you inject a Composite signal into the S-video port (Y wire) of your capture device. Apparently your VHS player (plus adapter) simply loop the Composite signal to the Y wire of the S-video connector or the Y pin of the SCART connector
https://mega.nz/file/WJkE2STR#6GNZYO...9WmH8gvtyOl3rA
Old 14th October 2024, 20:13   #13  |  Link
eXtremeDevil
Thanks for making the time to investigate the details!
Old 19th October 2024, 19:30   #14  |  Link
eXtremeDevil
Hi again @Sharc. I went to my old house and rescued my old DVR. It is a Pioneer 545 HX. I don't see any passthrough options, unless it is the default behaviour of the DVR. Do you by any change know if passthrough is possible with this model? I will post on videohelp but I thought I could use this thread as well.
One question, would these VHS to DVR connections result in the same quality?
SCART out -> SCART to composite adapter -> Composite in
SCART out -> SCART in
SCART out with SCART to composite cable -> Composite in
Thanks in advance.
Old 20th October 2024, 09:55   #15  |  Link
RetsimLegin
Passthrough is happening all the time. You feed it your source signal and, alongside anything else you might be doing to it (recording it, for example) in the Pioneer, it outputs that signal at its output ports. Intended so you can monitor what you are doing.
Have you consided recording it first onto the Pioneer itself? And then extracting it by burning to a writable (I'd use a good RW so I can reuse it) disc and extract that onto your computer for any further work?
RetsimLegin is offline   Reply With Quote
Old 20th October 2024, 10:33   #16  |  Link
eXtremeDevil
Of course, I get it now, but I thought it was a special mode where the DVR would carry the signal almost "as is". What you say is true, but if I press the display button on the DVR for example, the carried VHS signal will also have the on screen info, the DVR OSD, so it is not purely the VHS signal just carried. That's why I thought it was a special passthrough mode.
I have consider it, but when recording, the quality is reduced and the video somewhat encoded. I want the pure source signal to encode it myself.
Old 20th October 2024, 15:17   #17  |  Link
RetsimLegin
I'm pretty certain that there are recording "quality" settings you can adjust to get the best out of it. The highest quality setting should not produce any visible artefacts. It's important, of course, to match the TV standard as well (although from recollection, if you do that wrong it won't record anything.) My own past experiences in doing exactly this suggest to me there is no negative impact on viewing such a recording vs. watching the tape directly.
When you later burn it to a disc, you do so in "high speed" mode which does not change the video at all. Not even slightly. And when you extract it to your computer - ditto.
So you have on your PC the first (digital) generation of what you recorded. Just as you would, in fact, if you captured it onto the computer.
If I were to conjecture an advantage - computers are often and frequently busy doing other things you don't see. There is always the possibility that it does something over which you have no control while you are capturing but which interrupts it such that you get a glitch in your capture. (e.g. something else accesses your hard drive). Whereas a dedicated recorder has one sole purpose, is designed and optimised to do just that one thing. And it leaves you free to do something else (on your PC if you like) while that tape is playing....
Old 20th October 2024, 15:44   #18  |  Link
Sharc
Legacy DVD recorders encode the video on the fly as mpeg2 with all its compromises. While being a simple process and giving for some users an acceptable quality, it is clearly inferior compared to making a lossless capture, post process it (denoising, deinterlacing, color and levels adjustments etc.) and then encode it offline using an advanced encoder like x264 / AVC or x265 HEVC. Of course the more elaborate procedure has its pitfalls one has to be aware of and know how to cope with for producing decent results.
Post processing mpeg2 recorded stuff requires re-encoding which once more is a quality hit. An option would be to use take the digitized signal from the HDMI output (if available) of the recorder.
Old 20th October 2024, 16:07   #19  |  Link
RetsimLegin
Quite true. But
a) a high (max) bitrate (= high "quality") minimises these to what I'd consider practically indistinguishable from lossless
b) and in any case the source here is (S-)VHS which is intrinsically a massive compromise. You can't make a silk purse, as they say.
And there is no such thing as lossless capture. The very fact of sampling an analog signal, regardless of where it's done, is liable to cause something. Now, how good is that capture card/dongle?
Old 20th October 2024, 16:45   #20  |  Link
Sharc
Quite true. But
All this has been discussed to death. If one is happy with what can get from his (noisy) tapes recorded as mpeg2 (blocky) DVDs so be it.
I agree though that it's a simple and (widely) fool-proof process for obtaining mediocre satisfactory results. To each his own
