Old 14th August 2022, 05:29   #161  |  Link
chronis
feature request
1. Would you consider adding support for qaac codec?
2. Is there an option to change video frame rate (e.g. from 25 to 24) without encoding? I couldn't find one.
3. A drag-and-drop option for file specification would be very helpful.
Thanks
chronis is offline   Reply With Quote
Old 19th August 2022, 10:42   #162  |  Link
ProWo
qaac codec is not included in ffmpeg, and because clever FFmpeg GUI is built on top of ffmpeg only, the use of qaac is not provided.
No.
What exactly do you mean by file specification?
ProWo is offline   Reply With Quote
Old 26th August 2022, 12:13   #163  |  Link
ProWo
August 26, 2022 update to version 3.0.2.
Fixed: Exception handling, webm as container selection (multiplex).
Added: Chapters support (creating, editing, use extern chapters file), Source file check for warnings or errors, writing app info in outputs, select/deselect all streams in multiplexing, selection to move headers from mp4 and mov to the beginning for better streaming.
Changed: Scan type handling, LUT filter chain, Nero chapters entrys deleted for mp4+mov.
Improved: Hardcode subtitles handling, interlaced encoding from interlaced source, Video cutting.
Old 20th September 2022, 20:38   #164  |  Link
ProWo
September 20, 2022 update to version 3.0.3.
Fixed: Video filter chain issue, extended range for IVTC detection issue.
Added: hdmv_pgs_sultitle mux to ts.
Changed: Missing scantype handling (progressive is assumed, but can be changed).
Improved: Chapters handling, Video cut, defective video handling, errors scan.
Old 25th October 2022, 09:13   #165  |  Link
ProWo
October 25, 2022 update to version 3.0.4.
Changed: Video Fade Out, Audio delay handling.
Improved: Avisynth support, avs handling, interlaced encoding.
Old 5th November 2022, 05:04   #166  |  Link
guest
Posts: n/a
Hi ProWo,
I had a little job to do with this today,
I wanted to convert a 7.1 TrueHD track to AAC 7.1, which this did, took a while, but that's ok.
However, the channel mapping changed considerably from original.
If you would like to know how it changed, please go here :-
https://forum.doom9.org/showthread.p...75#post1977775
Cheers
Old 5th November 2022, 14:29   #167  |  Link
tebasuna51
tebasuna51's Avatar
I use MediaInfo channel names.
Here show 3 options for AAC Defined Layouts 7.1:
AAC_7_1: C L R Ls Rs Lw Rw LFE
AAC_7_1_B: C L R Ls Rs Lb Rb LFE
AAC_7_1_C: C L R Ls Rs Tfl Tfr LFE
The default one is the first and some aac encoders (Nero, ffmpeg, fhgaacenc) output always that channel layout using this WAV to AAC channel equivalence:
FL/FR -> Lw/Rw
FC/LFE = C/LFE
BL/BR -> Ls/Lr
SL/BR -> L/R
Using ffmpeg like decoder recover the correct layout sending a message:
[aac @ 00000215e4c73d80] Assuming an incorrectly encoded 7.1 channel layout instead of a spec-compliant 7.1(wide) layout, use -strict 1 to decode according to the specification instead.
If you want the standard 7.1 must use qaac or fdkaac than output the correct AAC_7_1_B: C L R Ls Rs Lb Rb LFE
Old 6th November 2022, 16:47   #168  |  Link
ProWo
Originally Posted by TDS View Post
Hi ProWo,
Cheers
Hi TDS,
I checked this and just now encoded a TrueHD 7.1 audio stream to AAC 7.1 using clever FFmpeg-GUI.
Mediainfo shows the differences in channel layout you showed, but when I compare the files in Audacity, the channels are arranged exactly the same.
Maybe a problem of Mediainfo?
Compare yourself (see attached picture).
On the left the original TrueHD 7.1 file, on the right the converted AAC 7.1 file.
Old 6th November 2022, 21:31   #169  |  Link
tebasuna51
tebasuna51's Avatar
...but when I compare the files in Audacity, the channels are arranged exactly the same.
Audacity can't decode itself AAC, it uses ffmpeg and maybe silent do:
"Assuming an incorrectly encoded 7.1 channel layout instead of a spec-compliant 7.1(wide)"
But MediaInfo now is correct, ffmpeg encode the standard 7.1 to a non-standard 7.1 channel layout.
Use qaac or fdkaac if you want the correct channel layout 7.1, without problems with 5.1.
Old 7th November 2022, 06:39   #170  |  Link
guest
Posts: n/a
So what does this really mean, does someone need to look into this a bit deeper ??
Fortunately for me, tho, I don't use 7.1 anyway, it was just a test, as a question was asked on another forum.
Old 7th November 2022, 10:21   #171  |  Link
tebasuna51
tebasuna51's Avatar
The problem is how decode your player an AAC 7.1, strictly it must decode ffmpeg aac 7.1 like the second image in my post and can output a wrong channel map.
To avoid problems encode 7.1 with qaac (the recommended and free AAC encoder) or fdkaac, when the source is the image 1 the decoded output is the same.
The same for me, my AVR is configured like 5.1.2, and only use aac 5.1,
Old 7th November 2022, 11:10   #172  |  Link
ProWo
I wanted to try that, but qaac does not recognize the truehd 7.1 file.
D:\Freeware\Audio\qaac\x64>qaac64.exe O:\rip\mainmovie\Audio_dolby-spheres-TrueHD_7.1_1_A_extracted.mka
qaac 2.76, CoreAudioToolbox 7.10.9.0
ERROR: Not available input file format
Can you show me the exact command line?
Old 7th November 2022, 14:58   #173  |  Link
tebasuna51
tebasuna51's Avatar
You need ffmpeg like decoder:
"C:\Portable\0\ffmpeg.exe" -i "input.thd" -acodec pcm_s24le -f wav - | "C:\Portable\0\qaac.exe" -V 91 --ignorelength --adts --no-delay -o "output.aac" -
Old 7th November 2022, 15:22   #174  |  Link
ProWo
Thanks, this worked, but the new created file cannot be opened by foobar or audacity.
Old 8th November 2022, 00:49   #175  |  Link
tebasuna51
tebasuna51's Avatar
You are rigth, seems problems of these soft's with ADTS AAC format, without problems in MP4 container:
"C:\Portable\0\ffmpeg.exe" -i "input.thd" -acodec pcm_s24le -f wav - | "C:\Portable\0\qaac.exe" -V 91 --ignorelength --no-delay -o "output.m4a" -
Old 8th November 2022, 08:47   #176  |  Link
ProWo
It's not the container, the adts switch is problematic.
Thanks anyway.
What software can display the effective AAC channel layout without the decoder changing it (like ffmpeg)?
Old 8th November 2022, 15:07   #177  |  Link
tebasuna51
tebasuna51's Avatar
Yes, because the adts header have a field for NumChannels not for a MaskChannel. The qaac and fdkaac put '0' in that header field and MediaInfo and many decoders read that like AAC_7_1_B: C L R Ls Rs Lb Rb LFE
If NumChannels is '8' is read like AAC_7_1: C L R Ls Rs Lw Rw LFE
I don't know where is documented that workaround.
To display audio we need always decode it, to wav or equivalent uncompressed formats. Then your question is what decoders output wav files with waveformatextensible header and correct channelmask.
After decode you need a wav editor than read the channelmask correctly
The correct channelmask for a AAC_7_1: C L R Ls Rs Lw Rw LFE must be:
255 (FL FR FC LF BL BR FLC FRC)
I recommend qaac to Decode .aac or .m4a:
"qaac.exe" -D -b 24 -o "aac_.wav" "input"
Now you can display "aac_.wav" with Audacity, Wavosaur, GoldWave or Audition
Old 8th November 2022, 15:37   #178  |  Link
ProWo
Thanks a lot for all this Information, tebasuna51.
Old 8th November 2022, 17:00   #179  |  Link
ProWo
November 8, 2022
Added: Drag & Drop in the newest beta (v3.0.4.02).
Old 11th November 2022, 14:46   #180  |  Link
ProWo
November11, 2022 beta version 3.0.4.03.
Improved: Drag & Drop in Select Source section, in Multiplex section and in Join section (You can drag & drop on the full frame).
Added: ffv1 encoding (level 1 and 3), ffv1 muxing.
