#441 | Link | |
#442 | Link |
Okay, I guess I deserved that
![]() BUT... Okay then... So, you send the file to 'Batch' then quit the program, and then it generates the file after the program has closed, right? But, then, how do you change anything? Do you mean that if I add/change the cmd line in that BE_open.txt file, somehow mysteriously the NEXT time I just happen to open the program with whatever totally different encode I'm going to do, it will somehow REMEMBER whatever changes I did the LAST time even though there may be absolutely no connection between the two times? You see what I mean, how confusing it is? I PROMISE, once I've got this then that should be it! ![]() |
#443 | Link | ||
The file is read in with the modified commandline. If you go to "Batch tasks" and click execute, the task will be executed with the modified commandline. |
#444 | Link | |
One LAST thing... ![]() So, at this point the BE_open.txt file is in the same folder where the original file to be encoded is, and the program is closed. Okay... so, then if I wish to edit that file I can do so and save it. Got it... But, WHERE do I save it? Do I just leave it in this random folder where my LAST encode happened to be and CleverFFMpeg will just somehow go and find it for my next encode when I open the program, because at this point the program is not running and the txt file is just sitting in the folder where the previous file to be encoded was. Does CleverFFMpeg just magically somehow search EVERYWHERE when I open it the next time and just fine it no matter where it is? See what I mean... OR... is there a specific place where I should save it? Just seems a bit odd simply to save it exactly where the last file happened to be. That should do it! ![]() |
#445 | Link | |
The output folder is saved by clever Ffmpeg-GUI, so there is no magic. |
#446 | Link | |
So, say I've edited the text now that the program is not running, okay... So what, I just leave the newly edited txt file in that same 'OUTPUT' folder, right? (I'm now thinking THAT is the key!) In other words, KEEPING the same output folder is the trick, right? ![]() Ah...! I think I talked myself into it... Using the SAME output folder, that is it, isn't it? Please just tell me I'm right and I will leave you in peace... ![]() |
#447 | Link | |
#449 | Link |
Newest beta (v3.2.8.03), online now.
Added: New function: If the program is closed and there are still unprocessed batch tasks or processed streams that have not yet been muxed, the program starts directly in the batch tasks section or in the multiplex section. The batch tasks section has priority. Tooltip for change framrate in various section. Fixed: Bug in batch tasks for file names with non-conforming characters. Removed: Mux dvb_subtitle in m2ts not working, mux pgs subtitle in ts, not working. |
#451 | Link | |
The error message: Stream 2, codec hdmv_pgs_subtitle, is muxed as a private data stream and may not be recognized upon reading. |
#452 | Link |
Yep, when I was trying to figure out my 'situation', I tried muxing in the 'corrected' PGS subtitle that BDRB converted from my mistaken SRT format. But CleverFFMpeg on the streams page would not allow me to select it and just stated that this file cannot be converted (or even read or passed through apparently)
#453 | Link | |
#454 | Link | |
Only when FFmpeg can mux pgs into ts can I customize it. |
#455 | Link |
Would it be kindly possible to make the program totally portable? (that is, It keeps all configuration files within it's executable folder, no infoes to registry, and stores all paths in a format relative to the executable binary file).
Thank you |
#456 | Link | |
https://www.upload.ee/files/16918730...table.zip.html then report here. Last edited by ProWo; 1st August 2024 at 12:24. Reason: typo |
#457 | Link | |
c:\Documents and Settings\<UserAccount>\AppData\Local\Application Data\clever_FFmpeg_GUI\) and relative paths set manually in the portable.config file. Thank you very much ![]() |
#458 | Link | |
![]() This will be implemented in the next release. |
#459 | Link |
August 08 2024 release version 3.2.8. ---------------------------------------------------------------------------------- Added: Batch tasks: if you want replicate the first batch commandline to other files, you can now add them. There is an info message then. The filename addon from the first batch is copied to all other files. New function: If the program is closed and there are still unprocessed batch tasks or processed streams that have not yet been muxed, the program starts directly in the batch tasks section or in the multiplex section. The batch tasks section has priority. Tooltip for change framerate in various section. h263 stream extraction, as raw stream too. h263 mux to 3gp, asf, avi, mkv, mov, wmv. pcm_mulaw mux to asf, avi, flv, mkv, mov, wmv. Automatic switch to muxing grid after batch task completed. Scale filter lanczos (downsizing) and neighbor (upsizing) Fixed: Bug in batch tasks counter reset. Bug in batch tasks for file names with non-conforming characters. Bug with resuming normal windows size after batch tasks finished (minimized to tray). Bug in avs script creation (now UTF-8 without BOM) Bug in GOP assigning with mpeg 1/2 encoding. Improved: Subtitle handling for burn in. High DPI support, many code adaptions (thx to Iomero). Crop function. Mpeg 1/2 encoding, respecting exact target size now. Mpeg 1/2 encoding, maxrate now up to 38.8Mb. Code for colorspace changing. Target filename with videostream sample encoding. Changed: The program is fully portable now. Mpeg 1/2 videostream extraction to m1v, m2v (instead of mpg). Removed: 8 channels support for trueHD encoding, not working (thx to Darkhorse). Mux dvb_subtitle in m2ts not working, mux pgs subtitle in ts, not working. ---------------------------------------------------------------------------------- |
