Old 28th April 2023, 10:43   #281  |  Link
ProWo
I don't know what to say.
Just tested it, the temp files are deleted as intended and the cut file is in the output folder.
ProWo is offline   Reply With Quote
Old 28th April 2023, 11:01   #282  |  Link
guest
Posts: n/a
It's just another mystery, and these things always happen to me
That's why I tested it on 2 different PC's, with different input files.
I think I've used "clever" enough recently to know how to set it up, I mean all it needs is to "know" where ffmpeg is, and the output folder...simple.
But when you see the files disappear and leave the folder empty is rather frustrating, to say the least.
I guess I'll have to try it on yet another PC...
Regards
MORE:- I just tried it on my little laptop with an mp4, watched it create the temp files, click "DONE", ALL gone... so 3 different machines now...
Old 28th April 2023, 11:11   #283  |  Link
ProWo
If you don't click on the OK button in the small Done window, can you see the output file then?
Old 28th April 2023, 11:31   #284  |  Link
guest
Posts: n/a
No, just the temp files...
I just did something else, those first couple of tests were using Frame Accurate, but using KeyFrame it just creates the cutted file, with no temp files...but for whatever reason the cutted file would not play in PotPlayer
Old 8th May 2023, 13:28   #285  |  Link
ProWo
Newest beta (v3.1.0.06), online now.
Fixed: Keep HDR metadata on recoding HDR Video with H.265
Added: HDR to SDR with tonemap and desaturation settings, with any avaiable video codec.
Old 9th May 2023, 06:43   #286  |  Link
ProWo
Please post a mediainfo report (text mode) from the tested video here.
Old 9th May 2023, 10:27   #287  |  Link
ProWo
Newest beta (v3.1.0.07), online now.
Fixed: Bugs in HDR10 commandline.
Old 9th May 2023, 11:42   #288  |  Link
guest
Posts: n/a
I forgot to mention, that in the "Cut" section, I could only choose Keyframe...not the frame accurate
Old 9th May 2023, 16:24   #289  |  Link
ProWo
This is intentional, as HDR10 encoding is very costly for the part that needs to be re-encoded.
For this reason, I have disabled it for now.
Old 9th May 2023, 16:25   #290  |  Link
ProWo
I thought I had already shown enough MediaInfo info of the conversion (on the right of the previous post)
You have posted the mediainfo from the encoded video, not from the source one.
Old 10th May 2023, 03:40   #291  |  Link
guest
Posts: n/a
Tried the latest build, it obviously detects the HDR10, and there are no other options shown, and the cutted encode retains all the originals specs
Old 10th May 2023, 03:41   #292  |  Link
guest
Posts: n/a
This is the MediaInfo of the source clip:-
Video
Format                                   : HEVC
Format/Info                              : High Efficiency Video Coding
Format profile                           : Main 10@L6.1@High
HDR format                               : SMPTE ST 2086, HDR10 compatible
Codec ID                                 : V_MPEGH/ISO/HEVC
Duration                                 : 2 min 0 s
Bit rate                                 : 14.9 Mb/s
Width                                    : 3 840 pixels
Height                                   : 2 160 pixels
Display aspect ratio                     : 16:9
Frame rate mode                          : Constant
Frame rate                               : 23.976 (24000/1001) FPS
Bit depth                                : 10 bits
Bits/(Pixel*Frame)                       : 0.075
Stream size                              : 214 MiB (72%)
Title                                    : GalenMao@HDSky
Default                                  : No
Forced                                   : No
Color range                              : Limited
Color primaries                          : BT.2020
Transfer characteristics                 : PQ
Matrix coefficients                      : BT.2020 non-constant
Mastering display color primaries        : BT.2020
Mastering display luminance              : min: 0.0020 cd/m2, max: 1000 cd/m2
Old 12th May 2023, 09:30   #293  |  Link
ProWo
May 12, 2023 release version 3.1.1.
Fixed: missing variable reset bug, x265 profile settings bug, Bugs in HDR10 commandline.
Added: Keep section open checkbox (for audio encoding ,video encoding, cut section), switch background color button, Keep HDR metadata on recoding HDR Video with H.265, HDR to SDR with tonemap and desaturation settings for any avaiable video codec.
Changed: seeking approach in cut section, cosmetics on many forms.
Old 13th May 2023, 04:04   #294  |  Link
guest
Posts: n/a
Added: Keep section open checkbox (for audio encoding ,video encoding, cut section), switch background color button, Keep HDR metadata on recoding HDR Video with H.265, HDR to SDR with tonemap and desaturation settings for any available video codec.
Hi, just tried the newest build, seems to do most things, and keeps the P-level & HDR10, as per original.
But it still doesn't cut exactly where the user might like the cut. (Damn those Keyframes)
Sorry.
As you can see by my signature, I use RipBot, it just had a Trim function added to it by the author, it trims the video, audio & soft subtitles, but I'm pretty sure it's Avisynth based.
Works VERY well, it was a LONG time coming to that app.
Old 16th May 2023, 15:31   #295  |  Link
ProWo
Newest beta (v3.1.1.01), online now.
Improved: DVD Rip imports all streams now.
Added:Info link for tonemap and desat (HDR10 to SDR).
Old 20th June 2023, 07:25   #296  |  Link
ProWo
Newest beta (v3.1.1.02), online now.
Fixed: created chapters with short title missing, bitmap subtitle burn in issue with wrong sizes.
Added: (subtitles burn in): automatic scale and allignment for bitmap subtitles.
Old 3rd July 2023, 10:04   #297  |  Link
ProWo
July 03, 2023 release version 3.1.2.
Fixed: Created chapters with short title missing, bitmap subtitle burn in issue with wrong sizes.
Added: Info link for tonemap and desat (HDR10 to SDR), (subtitles burn in): automatic scale and allignment for bitmap subtitles.
Changed: Audio channels remap for all reasonable combinations.
Old 4th July 2023, 20:33   #298  |  Link
ProWo
Newest beta (v3.1.2.01), online now.
Improved: raw h264/hevc videostream handling.
Added: dat videofile(vcd/svcd) handling.
Old 6th July 2023, 20:04   #299  |  Link
ProWo
Newest beta (v3.1.2.02), online now.
Fixed: bug in raw h264/hevc videostream handling.
Old 11th July 2023, 17:15   #300  |  Link
ProWo
Newest beta (v3.1.2.03), online now.
Improved: raw h264/hevc handling.
Changed: various options/settings handling in main section and video encoding section, selected streams handling in multiplex section..
Added: rotate without reencoding (metadata only, main section), rotate and flip (video encode section).
