#261 | Link | |||
Uncheck the Change length box. Quote:
Which ffmpeg version are you using? Last edited by ProWo; 11th April 2023 at 09:59. |
#262 | Link |
Yes it does, but with telecined video that is not the way to go.
If your video is a 29.97 fps video coming from a 23.976 fps source, the IVTC filter is the right choice. This will return the 29.97 fps video to its original 23.976 fps state and remove the frames added during the telecine process. If you just change the frame rate (while keeping the duration the same), it will only add or remove more frames and pretty much ruin the video. |
#263 | Link | ||
Posts: n/a
And if memory serves, I did a run with 50 in the "fps" box, and that did process, but it was still the original 23.9xx. I am still using those Game of Thrones episodes that didn't like the Cut function, so maybe they are the problem.... Quote:
I get my builds from here:- https://github.com/BtbN/FFmpeg-Build...ses/tag/latest |
#264 | Link | |
and a 4k video, no problem, works fine. |
#265 | Link | |
Posts: n/a
It's not that I only use it on 1 PC, so it's not that. It's always the way, isn't it, you try and explain a problem, and the creator has no issue's. Last edited by TDS; 11th April 2023 at 13:38. |
#266 | Link | |
You write about problems that I cannot reproduce here. There can be many reasons for this, different operating systems, different video sources, different software versions, etc. You could try a different video for example. |
#267 | Link | ||
Posts: n/a
I was trying to say that its not just a particular pc that I'm having an issue on. Its like taking your car to a mechanic, explaining the problem, they can't find the problem, so they can't do anything about it...they take it for test drive, no problems, but when you drive back home, the problem is still there. I'm running Windows 11 22H2.. I will try another video. |
#269 | Link | |
Posts: n/a
Using this latest build, I imported a short 4K clip, and changed the FPS to 60 (from 23.97x), changed it to x265, CRF to 16, preset to medium, but when the profile is changed, was when the encode was done in an instant, with a 0kb file. If left @ auto, it was fine with all the other settings. Virtualdub2 is a nice addition. |
#270 | Link | |
Indeed, when encoding with x265 encoder, the profiles of x264 encoder were used and that could not work. This bug is now fixed in the latest beta (v3.0.1.04). |
#272 | Link | |
Posts: n/a
Went thru the settings, but there seems to be a different possible issue with "Profile", with both x264, or x265, it's "stuck" @ Auto... ![]() Tried it several times with different clips, and FFmpeg's. All the other options worked OK... |
#273 | Link | |
Change Bit Depth to 8 or 10 bits and the possible profiles can be selected. The best choice is auto anyway, because then the encoder chooses the best profile by itself. Actually the profile selection is only built in for compatibility reasons, that is if you need a certain profile for some reason. |
#274 | Link | |
Posts: n/a
![]() But I have to say that I am still not having any success with changing the frame rate...I have tried 2 different clips, one with 23.97x & another with 119.88, and setting them @ 60, there are not changing. Wait just a minute....it seems that the framerate HAS been changed, however, that change in not reflected when checking with MediaInfo !!! But if I reload the clips I have just "converted" with clever, then clever displays the new framerate, as do other encoding apps. So something is being "lost in translation" regarding the new fps, and MediaInfo... And sadly, the 4K HDR10 clip still loses the HDR10 tag, and is also changed from level 6.1 to 5.1 ![]() Is there something wrong with MediaInfo ?? Is there another similar tool I can try to test ?? |
#276 | Link |
Posts: n/a
I guess it will take me a little while to figure out all the in's & out's...
I just did a conversion, and changed several settings, and it's all displayed in MediaInfo ![]() Thanks for your patience & instruction ![]() Would it be possible to add a kb/s setting in the Encoder section, and of course retain the CRF setting ? Just to have the 2 different options. And maybe also have the P-level option for x264 & non HDR x265 in the Encoder section as well ? I only mention that, due to that option being available when it IS HDR x265, so might as well have it for all. |
#278 | Link |
Posts: n/a
Hi ProWo,
Me again...So I have just given your latest beta a test run, and it seems to do the cuts where I want them (well, on the clips I tested), it does more "testing" on the file, then choose "Cut", it does all it steps (10 in all), and ALL the temp files are shown in the folder I set for the output, then when it's all done the little "DONE" window pops up, click on that, it proceeds to "clean up" all the temp files, and then the folder becomes empty ![]() I did search for it, but was no where to be found, so I tried it on another PC, different file, same result... So something nasty seems to happen after you click on "DONE". So due to this, I can't check the "cutted" file, to check the edit, the P-level, and if it's retained the HDR10 tag ![]() I was going to attach some screenshots, but I think I've described it well enough. |
#280 | Link | |
Posts: n/a
If I have the output folder open, before I click on "DONE", all the temp files are there....as soon as I click on "DONE" they ALL disappear before my eyes, and then the folder is empty...NO cutted file !!!!! |
