Old 7th February 2011, 11:20   #621  |  Link
quasit
I don't think it's new. Though some people thought only video/audio header compression needed to be disabled. I doesn't seems so. I don't have a hardware player myself (using a HTPC). I just read about this so I'd though I'd suggest it.
Unfortunately, you can only disable header compression for the audio and video streams on default in the newest MKVMerge. For subtitles, you have to manually disable it every time in the advanced options.
http://forum1.netgear.com/showthread.php?p=324079
quasit is offline   Reply With Quote
Old 8th February 2011, 12:37   #622  |  Link
7ekno
Posts: n/a
Might be worth reading the subtitle compression comments in this thread ...
For those that can't be bothered reading the gist is "all MKV readers support subtitle header compression, or they don't support subtitles at all" :P
7ek
Old 20th February 2011, 19:29   #623  |  Link
rail grinder
First off this is a great tool and have been using it quite a bit for the past few months now.
I'm not sure if this has been reported yet but I noticed a bug with the interface. If you leave the About window open (Help > About) while the program is demuxing, it doesn't start muxing after demuxing finishes until you close the About window. I was wondering why it was still demuxing when I woke up this morning but it continued as soon as I closed the About window. I'm not too sure if other windows/menus will do the same thing but this is just a minor snag.
In any case, keep up the great work.!
rail grinder is offline   Reply With Quote
Old 22nd February 2011, 04:06   #624  |  Link
Mtz
Mtz's Avatar
Is possible for Subtitles Advanced settings to write some info like "Director Comments" ? Or make a check box named "Director Comments".
Also for audio will be nice.
On some Blu-Ray are 2 subtitles streams for every language and if we have some information about the size of stream (or bitrate like in BD Info) we can know which is the forced stream and finally select only the desired track:
Presentation Graphics           Italian
Presentation Graphics           Spanish
Presentation Graphics           Russian
enjoy,
Mtz
Mtz is offline   Reply With Quote
Old 22nd February 2011, 10:44   #625  |  Link
_hawk_
BluRip author
Mtz
I will add this in advanced (audio/subtitle) settings.
I think I'll have more time for development next month
BluRip : 1-Click BluRay/m2ts to h264 mkv converter
http://code.google.com/p/blurip/
_hawk_ is offline   Reply With Quote
Old 22nd February 2011, 10:45   #626  |  Link
_hawk_
BluRip author
I'll try to fix this.
Old 22nd February 2011, 13:03   #627  |  Link
Mtz
Mtz's Avatar
Also try to fix the link from your signature. I found BluRip on softpedia.com.
enjoy,
Mtz
Old 22nd February 2011, 15:49   #628  |  Link
_hawk_
BluRip author
enjoy,
Mtz
There is nothing to fix
The link in my signature is the official homepage. BluRip is an open source project. Official builds you will only find there.
Old 23rd February 2011, 22:41   #629  |  Link
Mtz
Mtz's Avatar
I have this error but only with Maxthon browser and IE:
Google Error
Server Error
The server encountered an error and could not complete your request.
If the problem persists, please report your problem and mention this error message and the query that caused it.
But in firefox and chrome is OK.
Maybe some add blocker with bad settings.
enjoy,
Mtz
Old 24th February 2011, 01:27   #630  |  Link
DIEGO7-5
If there would be a subtitle routine like in "Another EAC3toGUI-Plus" i would stick with this software forever. This would really make it perfect.
DIEGO7-5 is offline   Reply With Quote
Old 1st March 2011, 09:39   #631  |  Link
Mtz
Mtz's Avatar
Do you think for audio options to have one more additional conversion from HD audio to flac?
Example:
- from TrueHD > flac + ac3 core
- from DTS-HD Ma ? flac + DTS core + AC3640kbps
enjoy,
Mtz
Old 19th March 2011, 21:27   #632  |  Link
lukyluke
pb with subtitles
I just start using blurip 0.5.2, looks a very nice tool, but I have a problem with subtitles.
I want to rip the Inception bluray
If I choose "mux all subtitles (sub/idx)", then, when I activate subtitle on my PCH A110, it says "unsupported format".
If I choose "mux untouched subtitles (PGS), then strictly nothing happens when I activate subtitles on my A110, however, vlc displays the subtitles correctly.
Note that in both cases, mediainfo actually reports the correct subtitles in the final mkv file, so it looks more a problem with the PCH, but if someone can help, I would appreciate.
Thanks
lukyluke is offline   Reply With Quote
Old 21st March 2011, 13:04   #633  |  Link
_hawk_
BluRip author
Afaik only the 200 series supports pgs subs.
Both series do not support highres sub/idx. In blurip there is an option to mux lowres sub/idx. They should work with the a110.
Old 27th March 2011, 17:15   #634  |  Link
cge
Ripping Blu-ray with interlaced video
Hi Hawk,
Is there a known issue about ripping interlaced video.
I tried to rip 2 blu-ray which have video format 1080i50 and 1080i60, but Blurip simply crashes on both of them while "indexing / Cropping", I cannot even get a log since blu-rip hangs...
Regards
Christophe
Edit: I tried to rip it with autocropping disabled (advanced options) then Blurip doesn't crash anymore but the result is unwatchable, encoded as 25fps...
cge is offline   Reply With Quote
Old 13th April 2011, 17:35   #635  |  Link
quasit
It seems BluRip doesn't write any meaningful message (except "Return code: 1") in the log if there's not enough space to demux. I tried demuxing a BD a couple times and couldn't figure out what was wrong. All I got was an error sound. I finally saw that I didn't have enough space.
This is all that's written at the end before it stops demuxing.
4/13/2011 6:13:18 PM] Creating file "E:\Temp\Remuxing-working\_001_chapter.txt"...
[4/13/2011 6:13:18 PM] v02 Extracting video track number 2...
[4/13/2011 6:13:18 PM] s06 Extracting subtitle track number 6...
[4/13/2011 6:13:18 PM] a04 Extracting audio track number 4...
[4/13/2011 6:13:18 PM] a04 Removing DTS dialog normalization...
[4/13/2011 6:13:18 PM] v02 Muxing video to Matroska...
[4/13/2011 6:13:18 PM] a04 Creating file "E:\Temp\Remuxing-working\_004_audio_dtsHD_71_English.dtshd"...
[4/13/2011 6:14:03 PM] ---s06 Creating file "E:\Temp\Remuxing-working\_006_subtitle_Swedish.sup"...
[4/13/2011 6:27:48 PM] -----------------------------------------a04
[4/13/2011 6:27:50 PM] -----------------------------------------
[4/13/2011 6:27:50 PM] Return code: 1
[4/13/2011 6:27:50 PM] Done.
Old 16th April 2011, 19:24   #636  |  Link
quasit
Hmm. Why won't BluRip mux this? Mux log say "Audio file(s) not found".
log: http://pastebin.com/S4YkhFDh
I tried muxing the demuxed files with with mkvmerge and the audio plays fine and is identified correctly as DTS-HD MA.
What's the difference between the demuxed SUP files "_011_subtitle_English.sup" and "_011_subtitle_English_complete.sup"?
Old 23rd April 2011, 23:06   #637  |  Link
Socketman
Need to download suptitle.dll
Hi all i have searched the www up and down and can not find suptitle.dll . the only site that has it wont load. can someone help me out.
Socketman is offline   Reply With Quote
Old 24th April 2011, 09:11   #638  |  Link
quasit
http://forum.doom9.org/showpost.php?...&postcount=118
Old 24th April 2011, 16:46   #639  |  Link
Socketman
Bah, thanks for that. My lame excuse: new here,tired blah blah blah LOL
Old 3rd May 2011, 15:19   #640  |  Link
quasit
All my recent remuxes with Swedish subtitles are labeled as Northern Sami (Finnish). I thought it was maybe because of the mkvtoolnix upgrade, but it didn't help downgrading to 4.4.0.
log: http://pastebin.com/ernWhBbX
edit: It seems the reason this happens is because "preferred subtitle" (stream selection) is bugged. When I removed Swedish from the settings and chose the Swedish subtitle manually it was correctly labeled as Swedish instead of Finnish when muxed.
blu-ray, blurip, eac3to, ffms2, mkv, mkvtoolnix, x264
