#21 | Link |
Hi Chikuzen, since HBVFWSource is able to convert Vapoursynth's YUV42xP10/16 format into Dither's interleaved msb/lsb.
I was wondering if is possible to output the stacked msb/lsb also? It can be usefull for futher proccesing. I tried converting the interleaved format to stacked msb/lsb manually, but I was unsuccessful. Also, I don't know if the results would be *correct*. * Edit * I don't know if this is also correct but did manage to output stacked msb/lsb using f3kdb. The thing is I don't want to deband .Code:
HBVFWSource("16-bit test.vpy")
f3kdb(input_mode=2, input_depth=16, output_mode=1, output_depth=16)
#22 | Link | |
typo lover
however, Since it will be slower than interleaved mode, I don't want to implement it not much. Code:
thus, Your purpose is already achieved.
my repositories |
#23 | Link | |
If I find a way to turn interleaved into stacked manually I'll report back. Thanks anyways Chikuzen. |
#24 | Link |
契約者
Reel.Deel
Set all thresholds/noise generation to 0 if you want to be super sure is does nothing. I did that myself some time ago. Also this probably works: turnleft().separatefields() StackHorizontal(Selectodd(),Selecteven()).Turnright() Last edited by Keiyakusha; 6th October 2012 at 19:16. |
#25 | Link | ||
f3kdb(range=0, y=0, Cb=0, Cr=0, GrainY=0, grainC=0, blur_first=false, input_mode=2, input_depth=16, output_mode=1, output_depth=16) Quote:
#26 | Link | |
契約者
edit: but f3kdb approach 2 times faster Last edited by Keiyakusha; 6th October 2012 at 23:44. |
#27 | Link |
I just double checked. You're correct, sorry. It only worked when the colorspace YUV420P16 but fails with YUV422P16.Turning interleaved YUV422P16 to Stacked 4:2:2 msb/lsb must be another ballgame.
#28 | Link | |
契約者
But I'll post another try anyway. Seems to be working: ![]() SeparateColumns(2) StackVertical(Selectodd(),Selecteven()) ^avisynth 2.6 required edit: it also ~30% faster than f3kdb Last edited by Keiyakusha; 7th October 2012 at 00:29. |
#30 | Link |
typo lover
stacked output was implemented.
as I said, that is slower than interleaved mode. but that may be faster than separatecolumns.
my repositories |
#31 | Link |
typo lover
update to 0.2.1
a bit faster stacked output.
my repositories |
#32 | Link |
Take a look at the bright side. HBVFWSource uses less resources than f3kdb and SeparateColumns.
Thanks again Chikuzen. Vapoursynth script Code:
import vapoursynth as vs core = vs.Core(accept_lowercase=True) core.std.LoadPlugin(path=r'C:\Vapoursynth\FFMS2\ffms2.dll') # Source is 720p60 YUV420P8 src = core.ffms2.source(source=r"X:\MVI_1597.MOV") src = core.resize.Spline(clip=src, format=vs.YUV420P16) last = src Code:
AVSMeter v1.40b3
[AVISynth version]
AviSynth 2.60, build:May 16 2012 [03:31:34]
Active MT Mode: 0
HBVFWSource Interleaved f3kdb Stacked
[Clip info] [Clip info]
Number of frames: 5736 Number of frames: 5736
Length (hh:mm:ss.ms): 00:01:35.694 Length (hh:mm:ss.ms): 00:01:35.694
Frame width: 2560 Frame width: 1280
Frame height: 720 Frame height: 1440
Framerate: 59.940 (60000/1001) Framerate: 59.940 (60000/1001)
Progressive: Yes Progressive: Yes
Colorspace: YV12 Colorspace: YV12
[AVSMeter runtime info] [AVSMeter runtime info]
Frames processed: 5736 Frames processed: 5736
FPS (min | max | avg): 94.3 | 149.0 | 129.5 FPS (min | max | avg): 55.0 | 78.4 | 74.8
CPU usage (average): 87% CPU usage (average): 69%
Physical Memory usage (peak): 389 MB Physical Memory usage (peak): 633 MB
Virtual Memory usage (peak): 393 MB Virtual Memory usage (peak): 637 MB
Time (elapsed): 00:00:44.305 Time (elapsed): 00:01:16.722
[Script] [Script]
HBVFWSource("test.vpy", stacked=false) HBVFWSource("test.vpy", stacked=false)
f3kdb(range=0,y=0,Cb=0,Cr=0,GrainY=0,grainC=0,blur_first=false,input_mode=2,input_depth=16,output_mode=1,output_depth=16)
_________________________________________________________________________________________________________________________________________________________________________________
HBVFWSource Stacked Separate Columns Stacked
Frame width: 1280 Frame width: 1280
Frame height: 1440 Frame height: 1440
Progressive: Yes Progressive: yes
FPS (min | max | avg): 85.8 | 131.7 | 124.2 FPS (min | max | avg): 35.2 | 91.5 | 88.7
CPU usage (average): 86% CPU usage (average): 64%
Physical Memory usage (peak): 385 MB Physical Memory usage (peak): 613 MB
Virtual Memory usage (peak): 387 MB Virtual Memory usage (peak): 614 MB
Time (elapsed): 00:00:46.194 Time (elapsed): 00:01:04.703
[Script] [Script]
HBVFWSource("test.vpy", stacked=true) HBVFWSource("test.vpy", stacked=false)
SeparateColumns(2)
Last edited by Reel.Deel; 9th October 2012 at 05:37. Reason: Updated to a more relevant comparison and added SeparateColumns. |
#33 | Link |
typo lover
@Reel.Deel
HBVFWSource is not able to use on avisynth2.5x. (because I need YV16 for P210/P216) thus, you should use SeparateColumns script on your comparison. The cost of TurnLeft/Right is quite high.
my repositories Last edited by Chikuzen; 8th October 2012 at 16:23. |
#35 | Link |
typo lover
sorry, I found a very stupid bug.
updated to 0.2.2
my repositories |
#37 | Link |
It seems that this plugin is broken.
My scripts that used to work (https://forum.doom9.org/showthread.p...76#post1594176), now give an error : Code:
[avisynth @ 025a6e00] Cache: Filter returned invalid response to CACHE_GETCHILD_CACHE_MODE. 87825032 (K:\film\Vapoursynth\hbVFWSource_test.avs, line 6) K:\film\Vapoursynth\hbVFWSource_test.avs: Unknown error occurred If I just replace HBVFWSource by VSImport (VapourSource plugin) and replace last in the .vpy script by last.set_output(), everything works ! Any help on this issue would be more than welcome !! Last edited by Pat357; 28th April 2017 at 21:44. |
| Thread Tools | |
| Display Modes | |
