Old 19th July 2008, 14:48   #281  |  Link
talz13
Originally Posted by Mgz View Post
<-- still faithful user of RealAnime 5.0 @_@, I fraps a lot and RealAnime 1 click 2-pass XVID enconding no-bs approach saves me a lot of time and HD space . But still I want to upgrade to xvid 1.1.2 :-/ but development is dead, oh well.
so what GUI/program do Bencos/RA users use/move to anyway ?
That's what I want to know! I still haven't found anything as easy to use as realanime for quick batch jobs. I've tried megui, straight up ffmpeg, and others, but realanime is still the best (when it doesn't bomb on audio, that is)
talz13 is offline   Reply With Quote
Old 1st October 2008, 17:00   #282  |  Link
Sirber
retired developer
Sirber's Avatar
BENCOS 2008-10-01
no major updates, code same as 2008-03-24.
just a codec update and a new mirror.
  • compiled with Lazarus 1.9.27 beta, FPC 2.2.3, win32
  • mplayer/mencoder svn-27323
Download:
Installer (exe, 10MB)
Sources (7z, 27MB)
Sirber is offline   Reply With Quote
Old 4th December 2008, 00:16   #283  |  Link
Veterinar
Good day Sirber, you made very useful tool. Thank you.
I'm using RealAnime 6 from 25.09.07 with encoders update. It works very well, and still is unmatched by rival tools. I'm not saying it's bug free, mind you, but I did encode much files with it.
I hope your effort will not just get lost, and RA or Bencos will get their well deserved development. Or, if you decide to resign, at least knowledge will reincarnate in some successor program.
In the meantime, I put here some feedback.
Videos at 120 fps I'd prefer to downsample to 24 or 30 fps, but with RA6 I can't. Also there are videos at what seems to be variable fps 24/30, which are encoded by RA6 as 120 fps result.
Sometimes RA6 crashes at various points. I've noticed this is GUI crash. Encoders continue to work till the end of current job and next job does not start. The crash occurs when showing the window from system tray or when switching tabs. It seems like various actions in GUI "accumulate" chance to crash. The less I medde with it, the less it crashes. Keeping the most active first tab in background also helps.
That was some feedback. One more time, thank you for your tool.
Veterinar is offline   Reply With Quote
Old 4th December 2008, 00:39   #284  |  Link
Sirber
retired developer
Sirber's Avatar
Hi Veterinar!
I'm glad you like the tools! Unfortunatly I haven't played with them for more than a year now. If you want to play with the code I'd suggest you grab bencos and lazarus (free pascal IDE) since bencos is more complete than RA6. I can help you a bit to get started but I won't code on those projects anymore.
Regards,
Sirber
Old 4th December 2008, 22:24   #285  |  Link
killerhex
i can't use the mirror for the exe the source in the other hand i can access
killerhex is offline   Reply With Quote
Old 14th December 2008, 18:02   #286  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
try those (BENCOS 2008-10-01):
installer
sources
Old 15th January 2009, 20:20   #287  |  Link
Sirber
retired developer
Sirber's Avatar
Thanks Sharktooth!
Old 1st October 2009, 16:10   #288  |  Link
Sirber
retired developer
Sirber's Avatar
even with the latest Lazarus, bencos fails on Vista and Windows 7. I did a search installing older version and from the first one (BENCOS_20061223.exe) to BENCOS_20070430.exe, they all run perfectly. Starting BENCOS_20070505.exe, I get a popup "A reference was returned from the server." and it fails. I'll try to make a new project file and copy / paste the code. I think my project file is corrupt or have bad settings, but they look good to me. I compiled an empty project and it ran perfectly.
in the meantime you can grab the latest binaries here: http://sites.google.com/a/detritus.qc.ca/realanime/
stay tuned!
Old 1st October 2009, 16:19   #289  |  Link
Eretria-chan
Just a maintenance update or a revival of the project, Sirber?
Eretria-chan is offline   Reply With Quote
Old 1st October 2009, 16:27   #290  |  Link
Sirber
retired developer
Sirber's Avatar
for now just an update (and codec updates) so it can work on vista and w7 while I slowly code RealAnime 7.
Detritus Software
Old 1st October 2009, 16:57   #291  |  Link
Eretria-chan
Ah, RealAnime 7. I wonder what this version will contain then?
Nice to see RA back on track again. It has been far too long without it.
Btw, what will RA7 be coded in? Good ol' delphi?
Old 1st October 2009, 17:12   #292  |  Link
Sirber
retired developer
Sirber's Avatar
Indeed... it's been a long while .. well if you don't count Bencos as a realanime
It is based on a new toolchain, using direct264 (directshow enabled x264), a directshow-enabled aac encoder and mp4box. ffshow is recommended to be used as a decoder and for filtering. The firsts release will be 32bit, but I'll make a 64bit version as soon as direct264 64bit builds will be avalible. The interface should be simpler and look like:
I'm regiving a try with csharp (.NET 3.5). In 2005-6 I tryed with xAnime, to learn the language, but I didn't like it and launhcing process and managing them was hellish.
Detritus Software
Old 1st October 2009, 17:41   #293  |  Link
Eretria-chan
Sounds very nice.
Also very nice to see HD settings. HD is getting common these days, and I will admit - I always download the 720p encodes. They always look better.
Ah, Microsoft's devil language again. Cannot say I like it, but meh. But as long as it works...
Still, it should be interesting to see if you can find some settings to further compress downloaded HD encodes today...
Old 1st October 2009, 17:46   #294  |  Link
Sirber
retired developer
Sirber's Avatar
New language to learn, always good
Delphi 7 and later versions are a pain to use on W7 (or vista) because they are too old.
I'll have to ask help for the settings, I'm really rusty with those, even for SD
Detritus Software
Old 1st October 2009, 20:11   #295  |  Link
anj
I got error # 1
Writing of 3GPP file failed.
What's solution??
anj is offline   Reply With Quote
Old 1st October 2009, 20:25   #296  |  Link
Sirber
retired developer
Sirber's Avatar
Originally Posted by anj View Post
I got error # 1
What's solution??
Everything you need to know is right here: link
Detritus Software
Old 1st October 2009, 20:38   #297  |  Link
PatlaborForce
Posts: n/a
And yet the two languages had their design lead by the same person. Why is his work now a "devil language" just cause he works for Microsoft? Secondly, many parts of the ECMA standard were designed by people who didn't even work for Microsoft (HP, Intel, etc).
Old 1st October 2009, 20:40   #298  |  Link
Eretria-chan
I would not call it that...
Boo to Delphi, yay to modern programming languages ^_^
Ah, then hopefully Sharktooth's settings will work well, then.
Originally Posted by PatlaborForce View Post
And yet the two languages were designed by the same person. Why is his work now a "devil language" just cause he works for Microsoft? Secondly, many parts of the ECMA standard were designed by people who didn't even work for Microsoft (HP, Intel, etc).
Who?
I know it is a standardized language, too, but I call it Microsoft's devil language because it is pretty much what Microsoft wants everyone to use and it is what you hear and see all about today. Always C#, C#, C#, C#, C#, C#, C#, C#, C#, C#, C#, C#, C#, C#, C#, C#, C#, C#, C#, C#.
And besides, it is all about the language, and the creators. IOW, I would not care even if Bjarne himself was involved in C#. It would still be a devil language in my eyes.
Old 1st October 2009, 20:43   #299  |  Link
Sirber
retired developer
Sirber's Avatar
no flamewar please
like c#? ;p
At least I'm not trying Java
Detritus Software
Old 1st October 2009, 20:47   #300  |  Link
Eretria-chan
like c#? ;p
More like C++
And I applaud you for that. Another devil language me thinks
aac, bencos, gui, webm, x264
