Old 17th May 2013, 21:46   #1  |  Link
Soukyuu
Soukyuu's Avatar
Trim causing weird errors when feeding .avs to x264
I'm not sure if this is the right section. I'm using MeGUI (newest version) to encode a couple of MJPEG avi files to h264.
The .avs is quite simple:
AviSource("file.avi", audio = true)
Trim(72,5463)
ConvertToYV12()
It does work for most files, but now I stumbled upon a few that show the following behavior: let's say the video is composed from parts a-b-c-d. If i comment out the Trim() line, the h264 output is as expected, a-b-c-d. However if I leave the Trim() line I get something along the lines of a-b-c-d-d squeezed into the same duration of the original file.
Obviously the audio is out of sync. I also noticed that the encoding process on those files that show this behavior is twice as slow when Trim() is uncommented, so I suspect it might have something to do with avisynth.
From what I see, MEGui uses avs 2.5.8 and I'm using the mp4 muxer to mux the audio and video. Do you have any idea what the problem might be?
Soukyuu is offline   Reply With Quote
Old 17th May 2013, 21:52   #2  |  Link
If it views OK in VirtualDub, then it must be a MeGUI problem.
View in VD and scroll forwards/backwards, is it OK ?
Does "Newest Version" mean development version, or v2341 ?
Zathor visits here so he should see your thread.
Old 17th May 2013, 21:58   #3  |  Link
Soukyuu
Soukyuu's Avatar
The preview is fine in either program, only the encoded output is mangled. By "the newest version" I mean the one served by the update, so yes, 2341
Old 19th May 2013, 18:18   #4  |  Link
Soukyuu
Soukyuu's Avatar
I tested further and it looks like it's the first parameter of trim that is causing this. For example, if I change the line to Trim(0,5463), everything works fine, but as soon as I change the first parameter to anything else, encoding speed gets halved and the output is mangled.
I have installed avisynth 2.5.8 ST 32-Bit and got the x264.exe (32-bit, 8-bit output) from the x264.nl site and same behavior can be seen.
Furthermore, encoding with virtualdub shows exactly the same behavior as well - no matter the codec.
So for me it looks like 100% avisynth's at fault here.
edit: one more thing: even re-encoding said videos to huffyuv doesn't fix this, so it doesn't seem to be codec-related either. The filesize of the input files is about 1,96GB, so shouldn't be 32-bit limited (although the huffyuv variant is 8GB, so that might be a problem)
edit2: 2.6.0 shows same behavior as well
Old 19th May 2013, 19:28   #5  |  Link
creaothceann
It sounds to me as if the input's video codec can't handle non-linear frame access correctly. I'd dump the raw video data with e.g. x264's lossless mode to a temporary file.
IIRC if you have a codec pack like k-Lite you can select which codec is assigned to MJPEG.
Just fmi, what is your video resolution and framerate?
creaothceann is offline   Reply With Quote
Old 19th May 2013, 19:36   #6  |  Link
poisondeathray
MJPEG is I-frame only, so source shouldn't have problem with linear access
If the preview is ok, the encode should be ok - so your observation don' t make sense to me...
Old 19th May 2013, 19:42   #7  |  Link
Do you mean you loaded directly into Vdub and re-encoded as HUFFYUV, and THEN retried via avisynth ?
By the way, UT Video is pretty good, I Almost never use HuffYUV now, YV12 and YUY2 codecs available.
Old 19th May 2013, 21:33   #8  |  Link
creaothceann
VDub may decode MJPEG internally instead of using a system-wide codec.
Old 19th May 2013, 21:51   #9  |  Link
poisondeathray
Yes if you load the video directly.
I think he is checking the .avs script preview AVISource(), which won't use vdub's internal MJPEG decoder - how else would he preview Trim() ?
Eitherway, MJPEG is intra only, and not prone to decoding out of order issues like long GOP formats
Old 19th May 2013, 23:20   #10  |  Link
hello_hello
I'd be suspecting a decoding problem rather than an AVISynth problem as such, although it doesn't seem logical Trim() seems to be working as it should in the preview but not when encoding. Not having any idea why that'd happen.... things I'd try (in no particular order):
Open the AVI with VirtualDub or VirtualDubMod, edit it as required and save it as a new AVI using DirectStreamCopy for the video and audio. Then you can encode the new AVI without using Trim().
If you use AVISource try making sure the frame rate is correct. As an example: AVISource("file.avi", audio = true).AssumeFPS(25,1)
Don't use AVISource. Use MeGUI's file indexer to index and open the video instead.
If indexing the AVI doesn't help, remux the AVI as an MKV with MKVMergeGUI (or MeGUI's muxer) and then open the MKV for indexing and encoding.
Convert the video to a lossless format without Trim() and then use Trim() while re-encoding the lossless version. If you tick MeGUI's "Add pre-rendering job" before adding the video encoding job to the queue, MeGUI should convert it to a lossless format for you. Or you could do it with VirtualDub(Mod) either by opening the AVI directly or via the AVISynth script.
Old 20th May 2013, 01:09   #11  |  Link
Soukyuu
Soukyuu's Avatar
1080p30, recorded with MSI afterburner
Yes, then loaded the huffyuv avi instead of the mjpeg with .avs
The funny thing is that other video files recorded with exactly the same parameters are fine while these 5 freak avs (or the decoder) out -_-
If you use AVISource try making sure the frame rate is correct. As an example: AVISource("file.avi", audio = true).AssumeFPS(30,1)
Did that, the file got encoded as 21,1fps @_@
No change except the indexer shows around 3.8k frames instead of 5.4k without the indexer
Doing this with a x264 lossless version makes both the indexer and MEGui hang, then crash (file size = 3GB)
This worked. I remember doing that way back when AVI was the typical container and remember stopping because cutting wasn't frame-exact most of the time. Is MJPEG safe because it doesn't have keyframes?
Still, I'm rather curious what is failing here. Is there any way I can provide more information so that someone could take a look at it?
Old 20th May 2013, 01:48   #12  |  Link
How bout doing last step above, but without any trimming, just direct stream copy to a new file, and then trim in AVS.
Old 20th May 2013, 01:58   #13  |  Link
IanB
Avisynth Developer
Avisynth 2.6.0 alpha 4 include a new filter Preroll(video=0, Audio=0.0) which may help with recalcitrant sources that malfunction with random access.
...Source("...dodgy...")
Preroll(Video=25, Audio=10.0) # 25 frame video preroll, 10.0 seconds audio preroll
Trim(1234, 5678)
It works by detecting any out of order access in the audio or video track, and seeking the specified amount earlier in the stream and then taking a contiguous run up to the desired frame or audio sample. Skipping forward less than the preroll values results in linear access behaviour, i.e. all the intervening samples are accessed and discarded.
For earlier versions you can try adding a ChangeFPS(Last, Last, True) after the source filter, it's linear access feature may give enough protection to circumvent the issue. For audio issues it can be a softer option than the brute force EnsureVBRMP3Sync().
The best solution of course is to use source filters with accurate random access behaviour.
IanB is offline   Reply With Quote
Old 20th May 2013, 09:15   #14  |  Link
hello_hello
I don't know much about mjpeg but I think it's all keyframes (as such) so you can cut it anywhere as normally you can only cut on keyframes without re-encoding.
If you hold down the shift key while using the VirtualDub navigation slider thingy, it'll only stop on keyframes, and of course there's the keyframe buttons which navigate back and forth between them.
I used to do a lot of wondering until I realised it was driving me slowly mad. Now I mostly accept it when something works and try not to think about it.
As StainlessS suggested, you could try remuxing the original AVI (DirectStremCopy) without editing it to see if using Trim() will work correctly with the newly muxed version. Maybe the original AVIs have some sort of problem which remuxing will fix? Or you could try remuxing one as an MKV and re-encoding it instead. The "why" is largely over my head.
I tend to be lazy with "problem" video these days. If something won't encode correctly and remuxing doesn't fix it I'll open it with VirtualDubMod via a DirectShow script and convert it to a lossless format and work with that instead. Either huffyuv or ffv1. I've never used x264 lossless myself. For all it's shortcomings DirectShow will generally keep on decoding files which cause other decoding methods to spit the dummy.... as long as you encode the entire video from start to finish.
Video To Video Converter and AnyVideoConverter are a couple of programs which seem to cope with problem files fairly well. Especially when the usual conversion methods cause audio sync issues for no apparent reason. I don't use either program for much else, but if all else fails I'll open a problem video with one of those programs, convert it to a lossless format, then re-encode the lossless version the usual way.
Old 20th May 2013, 14:52   #15  |  Link
Soukyuu
Soukyuu's Avatar
It seems to be a muxing issue after all. I made a direct stream copy and used the same .avs to load the new file and it went without a hitch. The newly muxed .avi also seems to be quite bigger than the original, for example 2,96GB instead of 2,0GB. Maybe MSI afterburner is using some sort of weird compression when muxing the avi? Who knows.
Thanks for the help.
Old 21st May 2013, 10:44   #16  |  Link
VD does clean up junk chunks when you do a direct stream copy (temporary chunks written by some AVI file writers), perhaps it does more corrections,
you probably found the file got a little smaller unless you wrote uncompressed audio (sometimes a good idea).
Old 21st May 2013, 12:08   #17  |  Link
Soukyuu
Soukyuu's Avatar
Hmm, no, the file actually grows after direct stream copy, though not by much. Depends on the file, about 10-20MB for a 2 minute file. Both the source and the resulting one have a 6ch wav as audio.
avs, error, trim
