30th May 2023, 01:40 | #7262 | Link | |
https://sourceforge.net/p/megui/feature-requests/ |
30th May 2023, 03:13 | #7263 | Link | |
13th June 2023, 02:07 | #7264 | Link |
Hello, I hope everyone's well . It's been a while, but I'm venturing into 4K-HEVC sources for the first time and have discovered that, when indexing any (well, at least x264 and x265) 10 bit source with L-SMASH Works, MeGUI does the indexing without issue but as soon as I choose a preset script it crashes. A bit of testing later, I've learned that L-SMASH (or MeGUI?) adds ", format="YUV420P10" to the end of the "LWLibavVideoSource\PATH" and is the cause of the crash, because if I change the "10" to an "8" (even though the source is 10 bit) the script runs without issue. It's not a burden to edit the "10" to an "8" but I'm simply curious if there's a fix for this. Ahhh, Win 7 with the latest MeGui updates from the developmental server. Thanks for any information.
Just because, I tried to index with FFMSIndex and it was the same result--crashing as soon as I selected a preset script--but there's no "format" addition to edit and adding ',format="YUV420P8"' to the end of the source path doesn't help (MeGUI still crashes). |
13th June 2023, 11:37 | #7265 | Link |
@LCM,
Latest LSMash, give it a try:- https://forum.doom9.org/showthread.p...93#post1988293 Probably a lot more recent than auto updated (That thread has lotsa new ver$ tools) for MeGUI.
13th June 2023, 20:26 | #7268 | Link | |
Futurama (I dont have a TV), is not the first thing that came to mind the first time that LCM used the word. EDIT: To below, no offense taken [I dont recall discusssing that topic before, perhaps I was a bit pissed]
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 14th June 2023 at 01:03. |
13th June 2023, 22:07 | #7269 | Link |
StainlessS: I explained this once years ago: the combination of your avatar (I know he's Jack Haley as The Tin Man) and "I sometimes post sober." make me hear Bender's (well, John DiMaggio's) voice in my head when I read your posts. Absolutely zero offense intended and I apologize if you are .
_____________ Snatched the newest L-SMASH thanks to StainlessS's--say that fast five times--suggestion but MeGUI still crashes as soon as I select a preset script, and now it doesn't even leave an .avs file (it used to). Last edited by LouieChuckyMerry; 14th June 2023 at 00:43. Reason: Tested Newest L-SMASH |
21st July 2023, 02:52 | #7270 | Link |
Member
I don't know if someone already reported this, but there is a problem with hardcoded subtitles.
I have tried to re-convert an old movie (mp4) with hardcoded subtitles (ssa). After loading the subtitle and clicking on "Preview AVS Script" I get the following message: AvySinth Script error: Plugin was designed for a later version of Avisynth (8) I have MeGUI 2944 (x64) and updated according to "Development update server" I think the problem lies in the AviSynth plugin version 13 because I didn't have this problem with version 11. Is there any solution for this? Or at least be able to downgrade AviSynth plugin to version 11? Thanks. |
21st July 2023, 10:41 | #7271 | Link |
The problem can be in the VSFilter.dll v3.2.0.806 than need a new AviSynth version still not verified with MeGUI.
You can extract the VSFilter.dll v3.1.0.801 from Megui 2913 (with the plugins v11 package) and replace it in ...megui\tools\avisynth_plugin folder. I tested it and work fine. Or you can install the last AviSynth+ v3.7.3 r4003 and a new AviSynthWrapper.dll and use it instead the MeGUI default AviSynth+ v3.5.1 included. Verified ok also.
BeHappy, AviSynth audio transcoder. Last edited by tebasuna51; 21st July 2023 at 10:52. |
21st July 2023, 21:18 | #7272 | Link | |
Member
I've already installed that version of AviSynth and it didn't work (although I think I didn't add a new AviSynthWrapper.dll... is it mandatory?). I'll downgrade the VSFilter.dll and see how it goes. Thanks. Last edited by castellanos; 21st July 2023 at 21:30. |
22nd July 2023, 09:45 | #7273 | Link | |
25th November 2023, 11:58 | #7274 | Link |
21 years and counting...
REQUEST: Is it possible to add a zoom factor larger than 1:1 to the preview window?
Working with SD material on a 4k screen gives just such a tiny preview window that it's very hard to see how good or bad my filtering scripts work. |
25th November 2023, 16:11 | #7276 | Link |
@LeXXuz Make the request over at MeGUI's Sourceforge page.
Sent from my SM-S908B via Tapatalk
Do NOT re-post any of my Mediafire links. Download & re-host the content(s) if you want to share it somewhere else. |
26th November 2023, 09:53 | #7277 | Link | |
The annoyance here is that I often compare source and filtered version. So I have to switch between two scripts instead of just pressing the "reopen original video" button. Problem this way is I often make temporary tweaks in my stored scripts which are gone when I have to switch to a 2nd script with just an upsizer to compare source and filtered version. With the "open original video" button MeGUI keeps my script with the latest tweaks but displays a tiny source video. Hence my wish and suggestion for a permanent zoom setting in the preview window. |
2nd December 2023, 15:59 | #7279 | Link | |
Request:
After the new soxfilter 2.0 (32 and 64 bits) I recommend use it to downmix 7.1 -> 5.1 instead SoftClipperFromAudX() Quote:
BeHappy, AviSynth audio transcoder. Last edited by tebasuna51; 3rd December 2023 at 15:20. Reason: Add info |
2nd December 2023, 22:38 | #7280 | Link |
@tebasuna51 - Make the request over at MeGUI's Sourceforge page. Biggest chance that it will be noticed.
