9th February 2021, 16:28 | #161 | Link | |
9th February 2021, 19:12 | #163 | Link |
Seems like it was a one time bug xD Can't reproduce it too.
10th February 2021, 17:52 | #164 | Link |
Updated to R5
changelog Code:
R5: [2021-02-10] - Bug fixed: switching from tab A with a larger frame number than the max frame number of tab B will cause an out of range frame request error - Bug fixed: switching to tabs that are not in the same group during playback would keep on playing - Bug fixed: in group playback, switching to the same tab using hotkey would break the playback - Fixed missing connect for preview advance setting dialog, but its usage is still unknown to me - Config file now saved as vsedit2.config to avoid conflicting with the original version - Updated to VSAPI 3.6 calls, now requires Vapoursynth R47 or higher - Updated deprecated QProcess calls for encode and job server watcher - Autocompleter list shows only function names instead of the entire definition - Autocompletion for Python script functions, but only limited to non alias calls - Autocompletion popup now triggers on zero character type after "." on known filter/script names, normal words will not be affected - Added "about Vapoursynth", "open plugins folder" and "open scripts folder" options to menu And many bug fixes for tab switching on playback, hopefully no more crashings. Also there're some changes in the QProcess syntax so I need to change some logic for encode and job server watcher, so you may want to test it out to see if they still work. |
28th February 2021, 13:52 | #165 | Link | |
2nd March 2021, 21:28 | #167 | Link |
Updated to R5.2,
changelog Code:
- File association for vpy file option on Windows platform, opening vpy will load as new tab in the program - A vapoursynth logger plugin for vseditor to log warning messages to console The reported line number for fatal error has also been offset by the logger script so just ignore it for now. I'll fix it altogether later after no issues reported for the logger. For the file association, first try to associate it using right click->open with->choose program to see if it works. The "associate vpy" button in the program setting will write to registry and I'm not sure if it's necessary. |
3rd March 2021, 00:02 | #168 | Link |
R5.2 error msg
Failed to evaluate the script: Python exception: No attribute with the name vsedit exists. Did you mistype a plugin namespace? Traceback (most recent call last): File "src\cython\vapoursynth.pyx", line 2244, in vapoursynth.vpy_evaluateScript File "src\cython\vapoursynth.pyx", line 2245, in vapoursynth.vpy_evaluateScript File "script_42", line 29, in File "src\cython\vapoursynth.pyx", line 1756, in vapoursynth.Core.__getattr__ AttributeError: No attribute with the name vsedit exists. Did you mistype a plugin namespace? Code:
import vapoursynth as vs core = vs.get_core() clip = core.std.BlankClip(format=vs.YUV420P8, length=240, color=[16, 128, 128]) clip = core.std.AssumeFPS(clip, fpsnum=24000, fpsden=1001) clip = core.text.FrameNum(clip) clip.set_output() |
3rd March 2021, 08:28 | #172 | Link |
I like the new logger.
But can this be improved with maybe showing the module or filename as additional info? Code:
DeprecationWarning : line 105: get_core() is deprecated. Use "vapoursynth.core" instead. DeprecationWarning : line 2142: get_core() is deprecated. Use "vapoursynth.core" instead. DeprecationWarning : line 2622: get_core() is deprecated. Use "vapoursynth.core" instead. DeprecationWarning : line 1757: get_core() is deprecated. Use "vapoursynth.core" instead. DeprecationWarning : line 6: get_core() is deprecated. Use "vapoursynth.core" instead. DeprecationWarning : line -4: get_core() is deprecated. Use "vapoursynth.core" instead. <-- can this be true?
3rd March 2021, 08:44 | #173 | Link | |
3rd March 2021, 10:14 | #175 | Link | |
The -4 is triggerd by Code:
#https://github.com/theChaosCoder/lostfunc import lostfunc as lst clip = lst.MfTurd(clip)
3rd March 2021, 10:26 | #176 | Link |
Yes the line number were offset by 19 because of the logger script that was prepended to the main script. I'll put a check on the origin of the warning message and keep the line number untouch for those that came from imported modules.
12th March 2021, 09:30 | #177 | Link |
Updated to v5.3
changelog Code:
- Single instance implementation using the KDSingleApplication library - vsedit logger dll will now auto load on program start up, no more need for putting it into the plugins directory |
14th March 2021, 01:01 | #178 | Link |
It is very nice to see that someone has continued the project, I have a suggestion and would like to check some problems. It would be nice to have to press enter or click outside the frame box before going to the typed frame. If I want to go to frame 1000, it loads frames 1, 10 and 100 as I type, which is a problem in heavy filtering.
Someone already asked, but I couldn't find an answer, is there any prediction when the crop editor will work? Also some buttons are cut off here, I tried changing the DPI settings but it didn't work. These two buttons are without icon, I don't know if they have always been like this Last edited by danfgtn; 14th March 2021 at 01:06. |
14th March 2021, 06:50 | #179 | Link | |||
There are many actions in the menu that are without icons right now because the icon package had like 1,000 icons and it gave me a headache trying to find the right one out of that. You can help if you can spot them. |
29th March 2021, 17:31 | #180 | Link |
vsedit color picker issue with RGB30
-The vsedit2 r5.x branch reads only displays values in the "R" channel (incorrect for "G", "B", "RGB"; for example, the R value should be placed in the "G" channel for the G strip, or the "B" channle for the B strip, etc...) -works ok in vsedit r19 , vsedit2 r4.x RGB30 (gbrp10le) R, G, B, R+G+B ramp pattern 0-1023 . 1024x720. FFV1 https://www.mediafire.com/file/3libj..._ffv1.mkv/file clip = core.lsmas.LWLibavSource(r'Comp_GradientRamp_RGB30_1024x720_ffv1.mkv') |
vapoursynth editor |
