6th April 2021, 14:03 | #921 | Link | |
6th April 2021, 19:58 | #922 | Link | |
Formerly davidh*****
Well it certainly won't make an audible difference. Personally I'd go for cvtps - the tiny bias towards even numbers is statistically fair, and is not going to be audible (how often are two neighbouring .5 float samples likely to crop up? And even if they do, it's parts-in-billions), particularly if you're using it (as is currently done but with doubles) as the first step for converting to the lower bit-depths.
Edit: that missing 0.5 is causing a slight "visible" bias to waveforms when converting to 8-bit compared to 3.6.1. Not sure about 16-, 24-, and 32-bit yet as I'm having other problems of my own with those. PS Does anyone know the logic behind this behaviour of Amplify(): Quote:
7th April 2021, 09:50 | #924 | Link | |
It is not "better than nothing" is the correct way. Amplify, ConvertToMono, MixAudio, MonoToStereo, Normalize, ResampleAudio, SuperEQ, SSRC and TimeStretch must work always in float format. The user is free to use the ConvertAudioTo any int format if desired, most the times unnecesary because players or encoders accept float samples without problems. Preserve int format is usefull for lossless manipulation, but when a volume change is done the audio is lossy now, and does not make sense preserve int format.
BeHappy, AviSynth audio transcoder. Last edited by tebasuna51; 7th April 2021 at 10:11. Reason: add info |
7th April 2021, 11:21 | #926 | Link |
Maybe the user don't know than is a bad choice (lose precission, risk of clip) manipulate the volume with int formats.
Is always better operate with float samples and recover the int format at end if is necesary ( I can't imagine for what).
7th April 2021, 11:32 | #927 | Link |
Well either they should all preserve the input format, or they should all convert to float - although the latter would, in my opinion, violate the Principle of Least Astonishment. I spent a little while last night tracking down what I thought was a bug in my filter that only seemed to affect 8-bit and 24-bit audio, but it was actually a problem with float audio because I had used an Amplify().
After all, the levels video filter doesn't convert to high bit depth, and nor would anyone expect it to. If users want higher resolution they should convert explicitly first. Most of my recent video filters convert to float internally but always convert back to the input format (with dithering) - except for YUY2, aka the Freak Colourspace. |
7th April 2021, 12:53 | #928 | Link |
In audio there are some input classes:
- lossy formats (MP3, AC3, DTS, AAC,... ). The decoders always output float samples, if aren't requested to downsample the output. There are users than don't know that, and ask about AC3 16 bits or DTS 24 bits when lossy formats don't have bitdepth, and doesn't make sense convert that float samples to int. - 8 bits int (PCM or equivalent, rare cases): can be converted to float, manipulate it and reconvert to 8 bits int without lose that poor quality. - 32 bits int: I never see a real sample, only useless experiments (the human ear can distinguise only until a 20 bit precission). - 16/24 bits int PCM or lossless encoded (FLAC,TrueHD,DTS-MA,...) only functions than remain the volume unchanged (AudioTrim,DelayAudio, Get/MergeChannels) must preserve the input format, other functions deceive the user, than can think have still a lossless audio when is already lossy or even distorted by clip. Only that last case is relevant for the discussion, we can lie the user with the Principle of least astonishment, or follow the correct way already used in AviSynth: "Audio samples will be automatically converted if any filters requires a special type of sample." And include Amplify, ConvertToMono, MixAudio, MonoToStereo, Normalize, ResampleAudio to only manage Float samples. My 5 cent. for Avs+ audio development. If you want other 5 cent. include ChannelMask like audio property instead NumChannels.
BeHappy, AviSynth audio transcoder. Last edited by tebasuna51; 7th April 2021 at 13:08. |
7th April 2021, 15:11 | #929 | Link |
Pig on the wing
Any ideas why Asd-g's GMSD and MDSI functions don't get any benefit from multithreading? I just tested one clip with AVSMeter and without Prefetch, got avg 6.81 fps and with Prefetch(24,1), 6.66 fps. Average CPU usage 23,3% / 26,1% respectively.
https://github.com/Asd-g/AviSynthPlu...ster/GMSD.avsi https://github.com/Asd-g/AviSynthPlu...ster/MDSI.avsi EDIT: with Prefetch(threads=24, frames=10), 2.37 fps / 34,1%
And if the band you're in starts playing different tunes I'll see you on the dark side of the Moon... Last edited by Boulder; 7th April 2021 at 15:20. |
7th April 2021, 16:04 | #930 | Link | |
Frames processed: 442 (0 - 441) FPS (min | max | average): 10.76 | 50.43 | 43.85 Process memory usage (max): 321 MiB Thread count: 66 CPU usage (average): 7.4% Time (elapsed): 00:00:10.081 Code:
Frames processed: 1750 (0 - 1749) FPS (min | max | average): 47.45 | 987.9 | 172.3 Process memory usage (max): 580 MiB Thread count: 74 CPU usage (average): 65.9% Time (elapsed): 00:00:10.156 |
7th April 2021, 16:24 | #931 | Link |
Pig on the wing
Script based on my Zopti script:
SetCacheMode(0) orig = FFVideoSource("c:\zopti\lotr_fotr.avi").AssumeFPS(24000./1001) b = -75/100.0 # optimize b = _n_/100.0 | -150..50 | b c = 15/100.0 # optimize c = _n_/100.0 | -100..100 | c downscaled_width = 1920 downscaled_height = 808 alternate = BicubicResize(orig, downscaled_width, downscaled_height, b=b, c=c).Lanczos4Resize(orig.width(),orig.height()) GMSD(alternate, orig, show=true) #prefetch(24) Code:
AVSMeter 3.0.6.0 (x64), (c) Groucho2004, 2012-2020 AviSynth+ 3.7.0 (r3382, 3.7, x86_64) (3.7.0.0) Number of frames: 400 Length (hh:mm:ss.ms): 00:00:16.683 Frame width: 3840 Frame height: 1608 Framerate: 23.976 (24000/1001) Colorspace: YUV420P16 Frames processed: 400 (0 - 399) FPS (min | max | average): 0.980 | 8.501 | 7.318 Process memory usage (max): 865 MiB Thread count: 41 CPU usage (average): 25.0% Time (elapsed): 00:00:54.661 Code:
AviSynth+ 3.7.0 (r3382, 3.7, x86_64) (3.7.0.0) Number of frames: 400 Length (hh:mm:ss.ms): 00:00:16.683 Frame width: 3840 Frame height: 1608 Framerate: 23.976 (24000/1001) Colorspace: YUV420P16 Frames processed: 400 (0 - 399) FPS (min | max | average): 0.116 | 30.55 | 6.887 Process memory usage (max): 1044 MiB Thread count: 65 CPU usage (average): 27.0% Time (elapsed): 00:00:58.078
7th April 2021, 16:57 | #932 | Link |
To use prefetch efficiently you should start with prefetch(x) where x is 2 and increase by 2 until find the most efficient value.
Here quick example with similar to your script: Without prefetch: Code:
orig=ffvideosource("001.mkv").ConvertBits(16) #source is 10-bit HEVC downscaled_width = 1920 downscaled_height = 1080 b=1/3.0 c=1/3.0 b=BicubicResize(orig, downscaled_width, downscaled_height, b=b, c=c).Lanczos4Resize(orig.width(),orig.height()) gmsd(b, orig) Code:
Number of frames: 1350 Length (hh:mm:ss.ms): 00:00:56.306 Frame width: 3840 Frame height: 2160 Framerate: 23.976 (24000/1001) Colorspace: YUV420P16 Frames processed: 28 (0 - 27) FPS (min | max | average): 2.269 | 3.377 | 2.797 Process memory usage (max): 1639 MiB Thread count: 46 CPU usage (average): 5.9% Time (elapsed): 00:00:10.009 Code:
orig=ffvideosource("001.mkv").ConvertBits(16) #source is 10-bit HEVC downscaled_width = 1920 downscaled_height = 1080 b=1/3.0 c=1/3.0 b=BicubicResize(orig, downscaled_width, downscaled_height, b=b, c=c).Lanczos4Resize(orig.width(),orig.height()) gmsd(b, orig) prefetch(4) Code:
Number of frames: 1350 Length (hh:mm:ss.ms): 00:00:56.306 Frame width: 3840 Frame height: 2160 Framerate: 23.976 (24000/1001) Colorspace: YUV420P16 Frames processed: 73 (0 - 72) FPS (min | max | average): 1.091 | 256416 | 7.141 Process memory usage (max): 1961 MiB Thread count: 50 CPU usage (average): 38.9% Time (elapsed): 00:00:10.223 |
7th April 2021, 17:47 | #934 | Link | |
Pig on the wing
With my go-to settings of Prefetch(threads=24, frames=10) (fastest when encoding with x265), it gets just ridiculously slow. 2.35 fps / 32,1% this time.
7th April 2021, 18:07 | #935 | Link |
Pig on the wing
I think I may have found the problem. My test clip is produced by using these:
SelectEvery(920, 1) Trim(3, 202) When encoded with ffmpeg, it gives the clip a very strange framerate instead of the original one. If the clip is decoded with orig = FFVideoSource("c:\zopti\silverado.avi"), it's slow as molasses but opens normally in VDub. If it's decoded with orig = FFVideoSource("c:\zopti\silverado.avi",fpsnum=24000,fpsden=1001), it's very fast but it keeps on processing beyond the clip length, which is 200 frames. I checked the output in VDub, and it's actually repeating the same frame for the amount of frames that was in the original SelectEvery call So where is the actual problem? I tested LWLibavVideoSource as well, same problem there. You can find a testclip here: https://drive.google.com/file/d/1fuV...ew?usp=sharing
7th April 2021, 18:12 | #936 | Link | ||
Those scripts benefit of mt. It seems you have additional filters/processing in the script? Did you try with prefetch(4): Code:
SetCacheMode(0) orig = FFVideoSource("c:\zopti\lotr_fotr.avi").AssumeFPS(24000./1001) b = -75/100.0 # optimize b = _n_/100.0 | -150..50 | b c = 15/100.0 # optimize c = _n_/100.0 | -100..100 | c downscaled_width = 1920 downscaled_height = 808 alternate = BicubicResize(orig, downscaled_width, downscaled_height, b=b, c=c).Lanczos4Resize(orig.width(),orig.height()) GMSD(alternate, orig, show=true) prefetch(4) |
7th April 2021, 18:16 | #937 | Link |
Pig on the wing
Please see the previous post, it's definitely an issue caused by the source clip confusing the decoder. I don't know how it gets worse with multithreading because source decoding should be serialized anyway.
12th April 2021, 01:25 | #940 | Link |
New hqdn3d support HBD
https://github.com/Asd-g/hqdn3d |
