Old 11th June 2021, 05:14   #19121  |  Link
Pauly Dunne
Grumpy Old Man.
Pauly Dunne's Avatar
Originally Posted by Wolfe999 View Post
@Pauly Dunne Thank you so much also for your "extra Avisynth degraining / denoising filters". A fantastic addition and, following your advise, used SMDegrain with more than satisfying results.
Hope you continue and expand your useful work.
And thanx to all the good info I could get reading this thread
Hi Wolfe999,
Thankyou very much for the great feedback, hopefully some other users might be interested.
And I will continue....
Cheers
Not poorly done, just doin' it my way !!!
Live every day like it's your last, because one day, it will be !! (M$B)
Pauly Dunne is offline   Reply With Quote
Old 12th June 2021, 01:43   #19122  |  Link
Ripmann
Phew, what a month. I'll be finally getting back to my encoding backlog soon (haven't even had time to update to see the Demo mode yet) but I just remembered something I wanted to ask Atak for a long, looong, looooong time:
• In the New Job window, the Output (file path/name) edit field: is it possible to make it editable (same as the Description field above it), so I can just CTRL-V paste the path and name without opening a Save As dialogue?
I don't know about the rest of us, but I'd certainly find it extremely time-saving, and I'm guessing it's an extremely quick and easy tweak to do, with no apparent downsides. I'm guessing it was disabled to avoid accidentally misspelled path errors, but hey, if you screw up one time, you'll either return to using the Save As dialogue or start being more careful about what you type in there, right? Thanks, Atak.
Ripmann is offline   Reply With Quote
Old 14th June 2021, 00:16   #19123  |  Link
coreying
Ripbot freezes when closing?
Is anyone having issues closing RipBot? I've got 2 Windows 10 systems.
On my brand new AMD Ryzen 5900 system after attempting to close RipBot, the queue window closes, but the system tray icon remains. I have to go to task manager and end process on RipBot264.exe. This happens whether I've done anything in RipBot or not (e.g. open RipBot, do nothing else other than click close). The first version installed here was v1.26.0, but it continues to occur after the update.
My old Intel i7-4770k system didn't have this issue, but then the update to v1.26.1 has introduced the problem on this system too.
coreying is offline   Reply With Quote
Old 14th June 2021, 02:41   #19124  |  Link
Pauly Dunne
Grumpy Old Man.
Hi coreying,
This is your first post here, in just over 8 years....
OK, so unfortunately this seems to happen every so often, and it's not necessarily a fault with RipBot, but it IS annoying when one pc does it, and another doesn't.
I have this happen, and have to do what you described, not sure if Atak would be able to track it down.
Off topic a bit here...
However, I have noticed some rather sneaky changes to RipBot with the last couple of updates (not that should affect this, tho), and it's mainly to do with the Avisynth MTmodes & how many "Use multiple threads for encoding" you can set for Prefetch.
It use to be a Limit of 16, NOW you can go all the way up to 64.
Back on topic...
So have you been using RipBot all these years, or just recently...just wondering about the version you had, before the problem started.
I doubt that it would be the AMD platform, as I have a 3950X, and it tends to behave itself pretty well.
Have you got nVidia software / drivers, or any Logitech stuff ??
Old 14th June 2021, 08:26   #19125  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
Check if problem stil occurs in "safe mode". I suspect some app running in background is doing this.
Old 15th June 2021, 05:25   #19126  |  Link
Pauly Dunne
Grumpy Old Man.
If there's something that has been happening, that's a little annoying is, when using DE, just very randomly, it will just "finish" a Job, and start on the next one, when indeed to previous Job has NOT completed.
Fortunately, 95% of the time, when you go back to that stopped Job, it will resume, BUT when it doesn't, it's rather frustrating, and when that happens on a LONG 4K encode, it's a real PITA !!!
Old 15th June 2021, 21:46   #19127  |  Link
slalom
slalom's Avatar
Originally Posted by Pauly Dunne View Post
And unless you have a large display, it's hard to really define the fine differences
You should try 27" 1440p
E5 2697 v2 @ 3.0GHz on P9X79 Deluxe 24GB
Xeon E5-2680 v2 @ 3.1GHz 16GB
Sony Vaio VPC-F13Z1E/B
slalom is offline   Reply With Quote
Old 16th June 2021, 01:58   #19128  |  Link
Pauly Dunne
Grumpy Old Man.
Maybe so, and I do have a 27" 2160p LG monitor.
But the situation doesn't change, it does NOT display custom settings !!!
Old 16th June 2021, 03:55   #19129  |  Link
Pauly Dunne
Grumpy Old Man.
Interesting, I just noticed that this field in Batch, IS editable...
Old 16th June 2021, 08:11   #19130  |  Link
PatchWorKs
PatchWorKs's Avatar
Question/idea: is possible to use a remote G-Colab notebook too as encoding server ?
Some (maybe) useful Colabs:
- https://colab.research.google.com/gi...r/MiXLab.ipynb
- https://colab.research.google.com/gi...nthColab.ipynb
- https://colab.research.google.com/gi...r_GDrive.ipynb
- https://colab.research.google.com/gi...r/FFmpeg.ipynb
Hope that inspires !
note: last but not least, why RB264 does not have a git ?
PatchWorKs is offline   Reply With Quote
Old 16th June 2021, 11:24   #19131  |  Link
coreying
Hi coreying,
<snip>
Yes, using RipBot all these years. It's excellent software.
All the above
I tried Safe Mode, and yep, RipBot closes fine. So I rebooted into Windows, and first started by closing everything in the System Tray. This is when I noticed that each time I started RipBot, the "NVIDIA Settings" tray icon would reappear.
So I tried stopping the Nvidia services one by one and found that the issue is with the "NVIDIA LocalSystem Container" which starts 3 x nvcontainer.exe background tasks. I can perform a reboot, stop only this single service, and RipBot closes normally.
It appears this service must be running for the NVIDIA GeForce Experience software to work. Not specifically sure why it causes RipBot to break or why RipBot starts the Nvidia tray icon etc.
But I have also replicated this on my old Intel computer that I've used RipBot on successfully for the past 8 years. As mentioned in my previous post, it also broke recently. I thought it was the update to 1.26.1 - but around the same time I had also put in a new GPU which updated the drivers so...
Thanks guys
Old 16th June 2021, 12:57   #19132  |  Link
Atak_Snajpera
I always install clean drivers without spying services like GeForce experience. By the way. I have never had any issues with AMD drivers for example. NVIDIA really likes to know what executables you launch...
Old 16th June 2021, 23:35   #19133  |  Link
MCFish
MCFish's Avatar
For some time now encodingclient.exe halts at 100% at random encodes. The main window closes, but the task is running and tray icon still showing 100% completion. When killing task, muxing start and encoding is resuming on next item.
Very annoying as it halts the whole ripbot thing until i kill the task again. Tried to initiate a few encodes from another computer, but same random thing happen.
Seems like it cant quit after encoding sometimes
MCFish
MCFish is offline   Reply With Quote
Old 17th June 2021, 00:43   #19134  |  Link
Atak_Snajpera
I haven't touched encodinclient's code for long time so maybe some app running in background is causing this issue. See above posts about GeForce experience
Old 17th June 2021, 03:23   #19135  |  Link
Pauly Dunne
Grumpy Old Man.
That's almost the opposite to the random problems I have...
https://forum.doom9.org/showthread.p...78#post1945078
But yeah, as Atak mentioned, if you're running any nVidia app's (behind the scenes), they play havoc with certain RB functions...someone needs to fix something...
I think you can disable them in ProcessHacker.....
Old 17th June 2021, 08:29   #19136  |  Link
MCFish
MCFish's Avatar
No nvidia on that computer. Have only seen the encodingserver thing with nvidia, it doesnt bother me. Ugh finding background task ill save for another day....are alot
MCFish
Old 18th June 2021, 01:45   #19137  |  Link
frencher
French Love
Hi all,
I search my future CPU for Ribot264 for 4K h265 @60fps.
AMD Ryzen, Intel i7/i9 ?
My actual CPU is Intel i7 3930k 6/12 threads (2011) recode at 3/4 fps.
My dream is 15/20 or better fps.
i7 3930k vs Last intel i9
https://cpu.userbenchmark.com/Compar...30K/4110vs1487
2013-11-29 MVC Player Free v0.0.2.6 BD & 3D BD's Player, Demuxer v0.0.0.8b, Recoder. Tutorial
Demo for MVC Player Free: Trailer 3D
3DBD's Free - v0.0.0.0005.exe Old
Programing free for all.
frencher is offline   Reply With Quote
Old 18th June 2021, 04:09   #19138  |  Link
Pauly Dunne
Grumpy Old Man.
Originally Posted by frencher View Post
Hi all,
I have an overclocked 3930K, they were pretty good, back in the day, but these day's, pretty slow for this sort of "work".
I also have a slightly overclocked Ryzen 9 3950X, and it's pretty damn good !!
I would strongly suggest a Ryzen 9 5900X (or higher).
Of course a Threadripper 32 or 64 core would just smoke this stuff, but at what cost
Check this :-
https://www.tomshardware.com/feature...-ryzen-9-5900x
Old 18th June 2021, 04:16   #19139  |  Link
Pauly Dunne
Grumpy Old Man.
Hey Ripmann,
Today is your lucky day, Atak has released another autoupdate, and amongst a couple of other changes (yet tbd), your request has been granted, and you can now freely edit this :-
Old 18th June 2021, 12:14   #19140  |  Link
frencher
French Love
Check this :-
Hello,
How many fps in 4K encoding do you encode with your Ryzen?
Has anyone done the test with a Threadripper 32 or 64?
