Old 26th December 2020, 22:43   #81  |  Link
-QfG-
QfG Group Germany
-QfG-'s Avatar
AWESOME!!! A long time im searching for a tool like this, with them i can speed up and slow down via FFMPEG and this in a GUI. I have few Ideas, if this is OK for you:
-Turn On/Off Dynamic Range Compression for AC3 Files (Example: ffmpeg.exe -drc_scale 0 -y -i)
-Extract all channels as single wavs (Example for 7.1 file: (%down16% is still empty for 16-Bit wavs, using "-c:a pcm_s24le" for 24-Bit Wavs) -filter_complex "[0:a]channelsplit=channel_layout=7.1[FL][FR][FC][LFE][BL][BR][SL][SR]" -map "[FL]" %downs16% "%~dp1[FFMPEG] %~n1\%~n1.L.wav" -map "[FR]" %downs16% "%~dp1[FFMPEG] %~n1\%~n1.R.wav" -map "[FC]" %downs16% "%~dp1[FFMPEG] %~n1\%~n1.C.wav" -map "[LFE]" %downs16% "%~dp1[FFMPEG] %~n1\%~n1.LFE.wav" -map "[BL]" %downs16% "%~dp1[FFMPEG] %~n1\%~n1.Lsr.wav" -map "[BR]" %downs16% "%~dp1[FFMPEG] %~n1\%~n1.Rsr.wav" -map "[SL]" %downs16% "%~dp1[FFMPEG] %~n1\%~n1.Ls.wav" -map "[SR]" %downs16% "%~dp1[FFMPEG] %~n1\%~n1.Rs.wav")
-After extracting a video / audio source don't leave the menu, still stand in the menu for faster extracting of other streams.
-A Simple Checkbox for Output Dir = Input Dir
-Video Codecs DNxHR HQ and HQX (for BD/UHD DI Files, in mxf or mov Container for using in DaVinci Resolve)
"dnxhd -profile:v dnxhr_hq"
"dnxhd -profile:v dnxhr_hqx"
"dnxhd -profile:v dnxhr_444"
-QfG- is offline   Reply With Quote
Old 30th December 2020, 17:03   #82  |  Link
ProWo
@ -QfG-
Thank you for your suggestions. I will see what can be done.
ProWo is offline   Reply With Quote
Old 31st December 2020, 19:06   #83  |  Link
ProWo
December 30, 2020 update to version 2.7.0.
Fixed: Small bugs.
Added: Audio delay info, Inverse Telecine (IVTC) for 29.97, 30, 59.94, 60 FPS Sources.
Improved: Many fine tunings.
Old 4th January 2021, 22:15   #84  |  Link
ProWo
@ -QfG-
Added dnxhr support in the newest beta. Try it and report issues here.
Old 7th January 2021, 01:30   #85  |  Link
-QfG-
QfG Group Germany
-QfG-'s Avatar
DnxHR Encoding works perfectly. Good choice is the mxf container. I have a *bat script for my Audio to single channel wav encoding, perhaps it helps you to implate.
[SPOILER]
@echo off & setlocal
mode con cols=120 lines=50
TITLE Audio Stream Channel Extractor [Team QfG] v0.13 beta
rem --- Hardcoded settings. Can be changed manually ---
set "sfkpath=%~dp0tools\sfk.exe" rem Path to sfk.exe
set "eac3topath=%~dp0tools\eac3to.exe" rem Path to eac3to.exe
set "FFMPEGpath=%~dp0tools\ffmpeg.exe" rem Path to FFMPEG.exe
set "ENCODER=FFMPEG" rem FFMPEG/eac3to - Standard Encoder
set "DOWNS=Yes" rem Yes/No - Activate/Deactivate 16 Bit downsampling
set "SURROUND=71" rem 10/20/21/51/61/71/71S - Channel Layout for FFMPEG
set "TRACK=2" rem 1/2/3/... - Standard Track Nunmber
rem --- Hardcoded settings. Cannot be changed ---
set WAIT="%sfkpath%" sleep
set GREEN="%sfkpath%" color green
set RED="%sfkpath%" color red
set YELLOW="%sfkpath%" color yellow
set WHITE="%sfkpath%" color white
set CYAN="%sfkpath%" color cyan
set MAGENTA="%sfkpath%" color magenta
set GREY="%sfkpath%" color grey
%green%
echo        Copyright (c) 2020 TeamQfG
echo.
%white%
echo                                        ====================================
%green%
echo                                           Audio Stream Channel Extractor
%white%
echo.
%white%
IF "%~1"=="" (
	%yellow%
	echo.
	echo No Input File. Drag and Drop a file over this script.
	echo.
	"%~dp0eac3to.exe" "%~1"
	echo.
	%white%
	echo Press [ENTER] to Exit.
	pause>nul
	exit
IF /i "%~x1"==".mkv" set "CONTTRUE=TRUE"
IF /i "%~x1"==".mka" set "CONTTRUE=TRUE"
IF /i "%~x1"==".evo" set "CONTTRUE=TRUE"
IF /i "%~x1"==".vob" set "CONTTRUE=TRUE"
IF /i "%~x1"==".m2ts" set "CONTTRUE=TRUE"
IF /i "%~x1"==".ts" set "CONTTRUE=TRUE"
:START
cls
%green%
echo.
%white%
%green%
%white%
echo.
%white%
echo Source Informations:
%yellow%
echo.
"%eac3topath%" "%~1"
echo.
%white%
echo Encoder Settings:
%green%
echo.
if "%ENCODER%"=="FFMPEG" (
	if "%SURROUND%"=="10" set "Surrounddisp=Mono"
	if "%SURROUND%"=="20" set "Surrounddisp=Stereo"
	if "%SURROUND%"=="21" set "Surrounddisp=Surround 2.1"
	if "%SURROUND%"=="51" set "Surrounddisp=Surround 5.1"
	if "%SURROUND%"=="61" set "Surrounddisp=Surround 6.1"
	if "%SURROUND%"=="71" set "Surrounddisp=Surround 7.1"
	if "%SURROUND%"=="71S" set "Surrounddisp=Surround 7.1 [STRANGE]"
if "%ENCODER%"=="eac3to" (
	echo 1. Encoder             : %ENCODER%
	echo 2. 16-Bit downsampling : %DOWNS%
	if "%CONTTRUE%"=="TRUE" echo 3. Select Audio Track  : %TRACK%
	echo.
	echo.
	%white%
	echo Change Settings and press [S] to start^!
	if "%CONTTRUE%"=="TRUE" CHOICE /C 123S /N /M "Select a Letter 1,2,3,S"
	if not "%CONTTRUE%"=="TRUE" CHOICE /C 12S /N /M "Select a Letter 1,2,S"
	if "%CONTTRUE%"=="TRUE" (
		IF errorlevel 4 goto EXTRACT
		IF errorlevel 3 (
			echo.
			%white%
			echo Type in the Audio Track Number, which will be extracted.
			echo Importend^! Only Audio Tracks are supported yet.
			echo For Example: For Audio Track 3 type 3 and press Enter^!
			echo.
			set /p "Track=Insert ONLY ONE Track Number here and press [ENTER]: "
			goto START
	if not "%CONTTRUE%"=="TRUE" (
		IF errorlevel 3 goto EXTRACT
	IF errorlevel 2 (
		if "%DOWNS%"=="Yes" set "downs=No"
		if "%DOWNS%"=="No" set "downs=Yes"
		goto START
	IF errorlevel 1 (
		set "Encoder=FFMPEG
		goto START
	echo 2. Channel Settings    : %Surrounddisp%
	echo 3. 16-Bit downsampling : %DOWNS%
	if "%CONTTRUE%"=="TRUE" echo 4. Select Audio Track  : %TRACK%
	echo.
	echo.
	%white%
	if "%CONTTRUE%"=="TRUE"  CHOICE /C 1234S /N /M "Select a Letter 1,2,3,4,[S]tart"
	if not "%CONTTRUE%"=="TRUE" CHOICE /C 123S /N /M "Select a Letter 1,2,3,[S]tart"
		IF errorlevel 5 goto EXTRACT
		IF errorlevel 4 (
			%white%
			echo.
			echo.
			goto START
	IF errorlevel 3 (
		goto START
	IF errorlevel 2 (
		if "%SURROUND%"=="10" set "Surround=20"
		if "%SURROUND%"=="20" set "Surround=21"
		if "%SURROUND%"=="21" set "Surround=51"
		if "%SURROUND%"=="51" set "Surround=61"
		if "%SURROUND%"=="61" set "Surround=71"
		if "%SURROUND%"=="71" set "Surround=71S"
		if "%SURROUND%"=="71S" set "Surround=10"
		goto START
	IF errorlevel 1 (
		set "Encoder=eac3to
		goto START
:EXTRACT
%WHITE%
if "%CONTTRUE%"=="TRUE" set "EXTRACTCONT=TRUE"
if "%ENCODER%"=="eac3to" if "%CONTTRUE%"=="TRUE" goto EXTRACTEAC3TOCONT
if "%ENCODER%"=="eac3to" if not "%CONTTRUE%"=="TRUE" goto EXTRACTEAC3TO
if "%ENCODER%"=="FFMPEG" if "%CONTTRUE%"=="TRUE" goto EXTRACTFFMPEGCONT
if "%ENCODER%"=="FFMPEG" if not "%CONTTRUE%"=="TRUE" goto EXTRACTFFMPEG
:EXTRACTEAC3TO
cls
if not "%DOWNS%"=="Yes" set "downs16="
if "%DOWNS%"=="Yes" set "downs16=-down16"
echo.
echo Encoding with [eac3to] using the following settings:
echo.
echo 16-Bit downsampling : %DOWNS%
echo.
"%eac3topath%" "%~1" "%~dp1[eac3to] %~n1\%~n1.wavs" %downs16%
echo.
echo Press [ENTER] to continue ...
pause>nul
goto START
:EXTRACTEAC3TOCONT
cls
if not "%DOWNS%"=="Yes" set "downs="
if "%DOWNS%"=="Yes" set "downs=-down16"
echo.
echo.
echo.
"%eac3topath%" "%~1" %TRACK%: "%~dp1[eac3to] %~n1_[Stream#%TRACK%]\%~n1.wavs" %downs16%
echo.
pause>nul
goto START
:EXTRACTFFMPEG
cls
if not "%DOWNS%"=="Yes" set "downs16=-c:a pcm_s24le"
if "%DOWNS%"=="Yes" set "downs16="
if not exist "%~dp1[FFMPEG] %~n1" md "%~dp1[FFMPEG] %~n1"
echo.
echo Encoding with [FFMPEG] using the following settings:
echo.
echo Channel Settings    : %Surrounddisp%
echo.
if "%SURROUND%"=="71S" "%FFMPEGpath%" -drc_scale 0 -y -i "%~1" -loglevel error -stats -filter_complex "[0:a]channelsplit=channel_layout=7.1[FL][FR][FC][LFE][BL][BR][SL][SR]" -map "[FL]" %downs16% "%~dp1[FFMPEG] %~n1\%~n1.L.wav" -map "[FR]" %downs16% "%~dp1[FFMPEG] %~n1\%~n1.R.wav" -map "[FC]" %downs16% "%~dp1[FFMPEG] %~n1\%~n1.C.wav" -map "[LFE]" %downs16% "%~dp1[FFMPEG] %~n1\%~n1.LFE.wav" -map "[BL]" %downs16% "%~dp1[FFMPEG] %~n1\%~n1.Lsr.wav" -map "[BR]" %downs16% "%~dp1[FFMPEG] %~n1\%~n1.Rsr.wav" -map "[SL]" %downs16% "%~dp1[FFMPEG] %~n1\%~n1.Ls.wav" -map "[SR]" %downs16% "%~dp1[FFMPEG] %~n1\%~n1.Rs.wav"
if "%SURROUND%"=="71" "%FFMPEGpath%" -drc_scale 0 -y -i "%~1" -loglevel error -stats -filter_complex "[0:a]channelsplit=channel_layout=7.1[FL][FR][FC][LFE][BL][BR][SL][SR]" -map "[FL]" %downs16% "%~dp1[FFMPEG] %~n1\%~n1.L.wav" -map "[FR]" %downs16% "%~dp1[FFMPEG] %~n1\%~n1.R.wav" -map "[FC]" %downs16% "%~dp1[FFMPEG] %~n1\%~n1.C.wav" -map "[LFE]" %downs16% "%~dp1[FFMPEG] %~n1\%~n1.LFE.wav" -map "[BL]" %downs16% "%~dp1[FFMPEG] %~n1\%~n1.Lsr.wav" -map "[BR]" %downs16% "%~dp1[FFMPEG] %~n1\%~n1.Rsr.wav" -map "[SL]" %downs16% "%~dp1[FFMPEG] %~n1\%~n1.Lss.wav" -map "[SR]" %downs16% "%~dp1[FFMPEG] %~n1\%~n1.Rss.wav"
if "%SURROUND%"=="61" "%FFMPEGpath%" -drc_scale 0 -y -i "%~1" -loglevel error -stats -filter_complex "[0:a]channelsplit=channel_layout=6.1[FL][FR][FC][LFE][BC][SL][SR]" -map "[FL]" %downs16% "%~dp1[FFMPEG] %~n1\%~n1.L.wav" -map "[FR]" %downs16% "%~dp1[FFMPEG] %~n1\%~n1.R.wav" -map "[FC]" %downs16% "%~dp1[FFMPEG] %~n1\%~n1.C.wav" -map "[LFE]" %downs16% "%~dp1[FFMPEG] %~n1\%~n1.LFE.wav" -map "[BC]" %downs16% "%~dp1[FFMPEG] %~n1\%~n1.Cs.wav" -map "[SL]" %downs16% "%~dp1[FFMPEG] %~n1\%~n1.Ls.wav" -map "[SR]" %downs16% "%~dp1[FFMPEG] %~n1\%~n1.Rs.wav"
if "%SURROUND%"=="51" "%FFMPEGpath%" -drc_scale 0 -y -i "%~1" -loglevel error -stats -filter_complex "[0:a]channelsplit=channel_layout=5.1[FL][FR][FC][LFE][SL][SR]" -map "[FL]" %downs16% "%~dp1[FFMPEG] %~n1\%~n1.L.wav" -map "[FR]" %downs16% "%~dp1[FFMPEG] %~n1\%~n1.R.wav" -map "[FC]" %downs16% "%~dp1[FFMPEG] %~n1\%~n1.C.wav" -map "[LFE]" %downs16% "%~dp1[FFMPEG] %~n1\%~n1.LFE.wav" -map "[SL]" %downs16% "%~dp1[FFMPEG] %~n1\%~n1.Ls.wav" -map "[SR]" %downs16% "%~dp1[FFMPEG] %~n1\%~n1.Rs.wav"
if "%SURROUND%"=="21" "%FFMPEGpath%" -drc_scale 0 -y -i "%~1" -loglevel error -stats -filter_complex "[0:a]channelsplit=channel_layout=2.1[FL][FR][LFE]" -map "[FL]" %downs16% "%~dp1[FFMPEG] %~n1\%~n1.L.wav" -map "[FR]" %downs16% "%~dp1[FFMPEG] %~n1\%~n1.R.wav" -map "[LFE]" %downs16% "%~dp1[FFMPEG] %~n1\%~n1.LFE.wav"
if "%SURROUND%"=="20" "%FFMPEGpath%" -drc_scale 0 -y -i "%~1" -loglevel error -stats -filter_complex "[0:a]channelsplit=channel_layout=stereo[LEFT][RIGHT]" -map "[LEFT]" %downs16% "%~dp1[FFMPEG] %~n1\%~n1.L.wav" -map "[RIGHT]" %downs16% "%~dp1[FFMPEG] %~n1\%~n1.R.wav"
if "%SURROUND%"=="10" "%FFMPEGpath%" -drc_scale 0 -y -i "%~1" -loglevel error -stats -filter_complex "[0:a]channelsplit=channel_layout=mono[FC]" -map "[FC]" %downs16% "%~dp1[FFMPEG] %~n1\%~n1.C.wav"
echo.
pause>nul
goto START
:EXTRACTFFMPEGCONT
cls
set /A FFMPEGSTREAM=%TRACK%-1
if not exist "%~dp1[FFMPEG] %~n1_[Stream#%TRACK%]" md "%~dp1[FFMPEG] %~n1_[Stream#%TRACK%]"
echo.
echo.
echo.
if "%SURROUND%"=="71S" "%FFMPEGpath%" -drc_scale 0 -y -i "%~1" -loglevel error -stats -filter_complex "[0:%FFMPEGSTREAM%]channelsplit=channel_layout=7.1[FL][FR][FC][LFE][BL][BR][SL][SR]" -map "[FL]" %downs16% "%~dp1[FFMPEG] %~n1_[Stream#%TRACK%]\%~n1.L.wav" -map "[FR]" %downs16% "%~dp1[FFMPEG] %~n1_[Stream#%TRACK%]\%~n1.R.wav" -map "[FC]" %downs16% "%~dp1[FFMPEG] %~n1_[Stream#%TRACK%]\%~n1.C.wav" -map "[LFE]" %downs16% "%~dp1[FFMPEG] %~n1_[Stream#%TRACK%]\%~n1.LFE.wav" -map "[BL]" %downs16% "%~dp1[FFMPEG] %~n1_[Stream#%TRACK%]\%~n1.Lsr.wav" -map "[BR]" %downs16% "%~dp1[FFMPEG] %~n1_[Stream#%TRACK%]\%~n1.Rsr.wav" -map "[SL]" %downs16% "%~dp1[FFMPEG] %~n1_[Stream#%TRACK%]\%~n1.Ls.wav" -map "[SR]" %downs16% "%~dp1[FFMPEG] %~n1_[Stream#%TRACK%]\%~n1.Rs.wav"
if "%SURROUND%"=="71" "%FFMPEGpath%" -drc_scale 0 -y -i "%~1" -loglevel error -stats -filter_complex "[0:%FFMPEGSTREAM%]channelsplit=channel_layout=7.1[FL][FR][FC][LFE][BL][BR][SL][SR]" -map "[FL]" %downs16% "%~dp1[FFMPEG] %~n1_[Stream#%TRACK%]\%~n1.L.wav" -map "[FR]" %downs16% "%~dp1[FFMPEG] %~n1_[Stream#%TRACK%]\%~n1.R.wav" -map "[FC]" %downs16% "%~dp1[FFMPEG] %~n1_[Stream#%TRACK%]\%~n1.C.wav" -map "[LFE]" %downs16% "%~dp1[FFMPEG] %~n1_[Stream#%TRACK%]\%~n1.LFE.wav" -map "[BL]" %downs16% "%~dp1[FFMPEG] %~n1_[Stream#%TRACK%]\%~n1.Lsr.wav" -map "[BR]" %downs16% "%~dp1[FFMPEG] %~n1_[Stream#%TRACK%]\%~n1.Rsr.wav" -map "[SL]" %downs16% "%~dp1[FFMPEG] %~n1_[Stream#%TRACK%]\%~n1.Lss.wav" -map "[SR]" %downs16% "%~dp1[FFMPEG] %~n1_[Stream#%TRACK%]\%~n1.Rss.wav"
if "%SURROUND%"=="61" "%FFMPEGpath%" -drc_scale 0 -y -i "%~1" -loglevel error -stats -filter_complex "[0:%FFMPEGSTREAM%]channelsplit=channel_layout=6.1[FL][FR][FC][LFE][BC][SL][SR]" -map "[FL]" %downs16% "%~dp1[FFMPEG] %~n1_[Stream#%TRACK%]\%~n1.L.wav" -map "[FR]" %downs16% "%~dp1[FFMPEG] %~n1_[Stream#%TRACK%]\%~n1.R.wav" -map "[FC]" %downs16% "%~dp1[FFMPEG] %~n1_[Stream#%TRACK%]\%~n1.C.wav" -map "[LFE]" %downs16% "%~dp1[FFMPEG] %~n1_[Stream#%TRACK%]\%~n1.LFE.wav" -map "[BC]" %downs16% "%~dp1[FFMPEG] %~n1_[Stream#%TRACK%]\%~n1.Cs.wav" -map "[SL]" %downs16% "%~dp1[FFMPEG] %~n1_[Stream#%TRACK%]\%~n1.Ls.wav" -map "[SR]" %downs16% "%~dp1[FFMPEG] %~n1_[Stream#%TRACK%]\%~n1.Rs.wav"
if "%SURROUND%"=="51" "%FFMPEGpath%" -drc_scale 0 -y -i "%~1" -loglevel error -stats -filter_complex "[0:%FFMPEGSTREAM%]channelsplit=channel_layout=5.1[FL][FR][FC][LFE][SL][SR]" -map "[FL]" %downs16% "%~dp1[FFMPEG] %~n1_[Stream#%TRACK%]\%~n1.L.wav" -map "[FR]" %downs16% "%~dp1[FFMPEG] %~n1_[Stream#%TRACK%]\%~n1.R.wav" -map "[FC]" %downs16% "%~dp1[FFMPEG] %~n1_[Stream#%TRACK%]\%~n1.C.wav" -map "[LFE]" %downs16% "%~dp1[FFMPEG] %~n1_[Stream#%TRACK%]\%~n1.LFE.wav" -map "[SL]" %downs16% "%~dp1[FFMPEG] %~n1_[Stream#%TRACK%]\%~n1.Ls.wav" -map "[SR]" %downs16% "%~dp1[FFMPEG] %~n1_[Stream#%TRACK%]\%~n1.Rs.wav"
if "%SURROUND%"=="21" "%FFMPEGpath%" -drc_scale 0 -y -i "%~1" -loglevel error -stats -filter_complex "[0:%FFMPEGSTREAM%]channelsplit=channel_layout=2.1[FL][FR][LFE]" -map "[FL]" %downs16% "%~dp1[FFMPEG] %~n1_[Stream#%TRACK%]\%~n1.L.wav" -map "[FR]" %downs16% "%~dp1[FFMPEG] %~n1_[Stream#%TRACK%]\%~n1.R.wav" -map "[LFE]" %downs16% "%~dp1[FFMPEG] %~n1_[Stream#%TRACK%]\%~n1.LFE.wav"
if "%SURROUND%"=="20" "%FFMPEGpath%" -drc_scale 0 -y -i "%~1" -loglevel error -stats -filter_complex "[0:%FFMPEGSTREAM%]channelsplit=channel_layout=stereo[LEFT][RIGHT]" -map "[LEFT]" %downs16% "%~dp1[FFMPEG] %~n1_[Stream#%TRACK%]\%~n1.L.wav" -map "[RIGHT]" %downs16% "%~dp1[FFMPEG] %~n1_[Stream#%TRACK%]\%~n1.R.wav"
if "%SURROUND%"=="10" "%FFMPEGpath%" -drc_scale 0 -y -i "%~1" -loglevel error -stats -filter_complex "[0:%FFMPEGSTREAM%]channelsplit=channel_layout=mono[FC]" -map "[FC]" %downs16% "%~dp1[FFMPEG] %~n1_[Stream#%TRACK%]\%~n1.C.wav"
echo.
pause>nul
goto START
:EXIT
exit
[/SPOILER]
Old 8th January 2021, 22:28   #86  |  Link
-QfG-
QfG Group Germany
-QfG-'s Avatar
Found an error in the newest beta. if i put a DTS File without container in the tool, i become an error message, that i must mux this file into a container. If i click OK by this message, the message comes again. I can't stop this process and must exit the tool with CTRL+ALT+DEL.
Old 9th January 2021, 17:05   #87  |  Link
ProWo
This error can happen if the file does not contain duration information. Try to mux the DTS file into a mp4 container:
ffmpeg -i input.dts -c copy output.mp4
This will refresh the timestamps and the new mp4 should load without problems in clever FFmpeg GUI.
This procedure should make the program itself fully automatic. Why this creates a loop, I have to investigate first.
Old 11th January 2021, 09:02   #88  |  Link
ProWo
I just tested it with a DTS file on version 2.7.1_02_Beta. Works flawless.
Old 11th January 2021, 18:10   #89  |  Link
-QfG-
QfG Group Germany
-QfG-'s Avatar
Confirmend! DTS Raw Streams works fine now.
Is there any chance to implate single mono wavs export? With this Option i can delete all my other tools .
Old 19th January 2021, 11:24   #90  |  Link
ProWo
January 19, 2021 update to version 2.7.1.
Fixed: Many small bugs.
Added: DnxHR encoding, multiplex to mfx.
Improved: Many fine tunings, new Windows 10 design, new logo, new icon.
Old 3rd February 2021, 11:01   #91  |  Link
ProWo
February 02, 2021
Added Avisynth support (only for the video track) into the newest beta (2.7.2_05_Beta).
On request, the loaded video will be imported into an Avisynth script. This script can then be customized and modified as desired. The script can then be tested with virtualdub. If it works as desired, it is encoded in clever FFmpeg-GUI with the desired codec.
Old 8th February 2021, 14:56   #92  |  Link
ProWo
February 08, 2021 update to version 2.7.2.
Fixed: Small bugs.
Added: VP8 encoding, multiplex to webm.
Added: Video merge (concat demuxer).
Added: Support for Avisynth. A basic Avisynth script is created that you can customize, modify, test and then encode with the desired encoder.
Removed: Inverse Telecine (IVTC), QTGMC deinterlacing. You can use your own scripts now.
Old 9th February 2021, 13:12   #93  |  Link
tormento
Acid fr0g
tormento's Avatar
Does it allow to remux a mkv to mp4 with the same structure, i.e. video/audio/subs/chapter copying?
@turment on Telegram
Old 9th February 2021, 20:01   #94  |  Link
ProWo
Video, Audio, Subtitle. No chapters.
Old 9th February 2021, 20:05   #95  |  Link
tormento
Acid fr0g
tormento's Avatar
Is it possible to add chapters as a new feature?
Old 11th February 2021, 08:47   #96  |  Link
ProWo
Try
Ffmpeg -i your.mkv -map 0 -c copy output.mp4
Old 11th February 2021, 13:28   #97  |  Link
tormento
Acid fr0g
tormento's Avatar
Try Ffmpeg -i your.mkv -map 0 -c copy output.mp4
[mp4 @ 00000288a4288dc0] track 1: codec frame size is not set
[mp4 @ 00000288a4288dc0] Could not find tag for codec ass in stream #2, codec not currently supported in container
Could not write header for output file #0 (incorrect codec parameters ?): Invalid argument
Error initializing output stream 0:12 --
Stream mapping:
  Stream #0:0 -> #0:0 (copy)
  Stream #0:1 -> #0:1 (copy)
  Stream #0:2 -> #0:2 (copy)
  Stream #0:3 -> #0:3 (copy)
  Stream #0:4 -> #0:4 (copy)
  Stream #0:5 -> #0:5 (copy)
  Stream #0:6 -> #0:6 (copy)
  Stream #0:7 -> #0:7 (copy)
  Stream #0:8 -> #0:8 (copy)
  Stream #0:9 -> #0:9 (copy)
  Stream #0:10 -> #0:10 (copy)
  Stream #0:11 -> #0:11 (copy)
  Stream #0:12 -> #0:12 (copy)
    Last message repeated 1 times
It outputs 0 bytes file.
Old 11th February 2021, 16:46   #98  |  Link
ProWo
Ffmpeg -i your.mkv -map 0 -c copy -c:s mov_text output.mp4
Old 11th February 2021, 18:31   #99  |  Link
tormento
Acid fr0g
tormento's Avatar
Multiple -c, -codec, -acodec, -vcodec, -scodec or -dcodec options specified for stream 2, only the last option '-c:s mov_text' will be used.
[mp4 @ 0000021919779e00] track 1: codec frame size is not set
[mp4 @ 0000021919779e00] Could not find tag for codec ttf in stream #3, codec not currently supported in container
Stream mapping:
  Stream #0:2 -> #0:2 (ass (ssa) -> mov_text (native))
Old 11th February 2021, 19:15   #100  |  Link
ProWo
Post an mediainfo report of your video here.
