#1 | Link |
Stab_Light - deshaker
This script will be useful for stabilizing video from shaking.
The script is based on Stab3 (found on real.finder's Avisynth Stuff). It is simplified and can fix large borders. It is also faster. Code:
# Stab_Light() v1.2 - deshaker # # v1.0 : - first release # v1.1 : - adapted for use in all versions of AviSynth (by StainlessS) # - added motion search method # v1.2 : - added Pre_Clip function for better search of motion vectors /* Needed plugins: MVTools2 https://github.com/pinterf/mvtools/releases DePan DePan and DePanEstimate are bundled as a package with MVTools2 DePanEstimate RgTools https://github.com/pinterf/RgTools/releases MaskTools2 https://github.com/pinterf/masktools/releases/ FillBorders https://github.com/Asd-g/AviSynth-FillBorders/releases AVSInpaint https://github.com/pinterf/AvsInpaint/releases GRunT https://github.com/pinterf/GRunT/releases GScript for AviSynth v2.60 only https://forum.doom9.org/showthread.php?t=147846 External dependencies: fftw3.dll (or renamed to libfftw3f-3.dll) from http://www.fftw.org/ (http://www.fftw.org/install/windows.html) Copy the file fftw3.dll to the folder C:\Windows\System32 for Win32. For Win64 copy 32-bit version in C:\Windows\SysWOW64 and copy 64-bit version in C:\Windows\System32. Or use LoadDLL (http://avisynth.nl/index.php/LoadDLL) Stab_Light(clip, ts, range, dxmax, dymax, zoom, rotation, PAR, mirror, MaxBorders, FixBorders, FixFalPos, MethodMS, debug) ts Default: 7 - Frames to temporal average for better motion estimation (max. 7) range Default: 1 - Frames before/after to estimate motion dxmax Default: autodetect - Maximum deviation in pixels dymax Default: autodetect - x, and y should be the same zoom Default: 1.0 - Maximum zoom factor (1 disabled). When zoom > 0 borders can be large rotation Default: false - Rotation estimation for MethodMS=2 only. If rotation=true black borders can be curved. To fix them set mirror=true PAR Default: 1.0 - Pixel Aspect Ratio of your source mirror Default: false - Depan it self fill empty borders with mirrored from frame edge pixels MaxBorders Default: autodetect - Maximum of black borders in pixels FixBorders Default: true - Fix black borders FixFalPos Default: true - Fixes borders of MaxBorders more pixels wide MethodMS Default: 1 - Method of motion search: 1 - DePan is used to search for motion in many cases better and faster 2 - MVTools is used to search for motion slower, bad border fix, recommended to set mirror=true debug Default: false - Show black borders if mirror=false and FixBorders=true This script can be Import()'ed under AviSynth+, OR, under AviSynth v2.60 Standard [ONLY IF GScript is installed]. Can also be GImport()'ed when GScript Installed. Can also be auto Loaded by AviSynth if in Plugins directory. [Needs GScript installed if not AviSynth+]. Can also be dumped in AvsInit()'s GIMPORT directory for auto loading by AvsInit(). GScript needs to be installed BEFORE attempting to AviSynth v2.60 std Import()/GImport() "Stab_Light.avsi". Either by Plugins AutoLoad, or Manual LoadPlugin() loading. Example: for AviSynth v2.60 : LoadPlugin("C:\AVS\plugins\GScript_26_32.dll") Import("C:\AVS\scripts\Stab_Light.avsi") for AviSynth+ : Import("C:\AVS\scripts\Stab_Light.avsi") Stab_Light(ts=7, zoom=1.0, mirror=false, rotation=false, FixFalPos=true, FixBorders=true, MethodMS=1, debug=false) Thread in Doom9's forum: https://forum.doom9.org/showthread.php?t=182532 */ Function Fb2FnNameEx(string Fn) { Try{ Eval(Fn+"()")B = true } Catch (e) { Assert(e.FindStr("syntax") == 0, "Fb2FnNameEx: Error in Function Name '"+Fn+"'") B = (e.FindStr("no function named") == 0) } return B } Fb2IsPlus = (FindStr(VersionString,"AviSynth+") != 0) Fb2HasGScript = Fb2FnNameEx("GScipt") Fb2_GS_S = """ Function FindBorders(clip c, int edge, float thr, int MaxB, int pad, int w, int h) { # edge: 0=left, 1=right, 2=top, 3=bottom result=0 for(i = 1, MaxB) { crpd = c.Crop(edge==1?w-i:0, edge==3?h-i:0, edge==0?i:0, edge==2?i:0) if(crpd.AverageLuma <= thr) { result = i + pad } else { i = MaxB } } return result } """ /* If this avsi script is not in plugins, then HasGScript [Fb2HasGScript] can be FALSE, even if using GImport() from GScript dll. Not sure why this occurs, so even if Fb2HasGScript==FALSE and is NOT AviSynth+, then we use GScript's GEval instead of Eval to install above FindBorders() function. We use Eval() to install the function, ONLY if GScript not installed and is AviSynth+. */ Try { Fb2HasGScript || !Fb2IsPlus ? GEval(Fb2_GS_S) : Eval(Fb2_GS_S) } Catch (msg) { Assert(false, ScriptFile+": Need GScript or AviSynth+ or GScript mast be loaded before the script"+Chr(10)+ \ "IsPlus="+String(Fb2IsPlus)+"; HasGScript="+String(Fb2HasGScript)+Chr(10)+ \ "SysErr="+Msg) } Function Stab_Light(clip clp, int "ts", int "range", int "dxmax", int "dymax", float "zoom", bool "rotation", float "PAR", \ bool "mirror", int "MaxBorders", bool "FixBorders", bool "FixFalPos", int "MethodMS", bool "debug") { ts = Default(ts, 7) range = Default(range, 1) dxmax = Default(dxmax, Round(clp.Width()/180.0)) dymax = Default(dymax, dxmax) zoom = Default(zoom, 1.0) rotation = Default(rotation, false) PAR = Default(PAR, 1.0) mirror = Default(mirror, false) MaxBorders = Default(MaxBorders, Max(Round(clp.Width()/60.0), 20)) FixBorders = Default(FixBorders, true) FixFalPos = Default(FixFalPos, true) MethodMS = Default(MethodMS, 1) debug = Default(debug, false) Assert(MethodMS == 1 || MethodMS == 2, "Stab_Light: Motion search method should be 1 or 2") temp = TemporalSoften(clp, ts, 255, 255, 25, 2) # SC thr to 25 otherwise pans will stutter rep = Repair(temp, TemporalSoften(clp, 1, 255, 255, 25, 2)) inter = Interleave(rep, clp) # temporal stable (better subpixel detection) pre_clp = inter.Pre_Clip(blur=1.0, contrast=0.7, brightness=100).RemoveGrain(mode=17) vectors = MethodMS == 2 ? pre_clp.MSuper(hpad=8, vpad=8, pel=1, sharp=2, chroma=false) \ .MAnalyse(isb=false, blksize=Height(clp)<=720?8:16, overlap=Height(clp)<=720?2:4, \ chroma=false, truemotion=false, global=true, search=5, dct=7) \ : Undefined mdata = MethodMS == 1 ? DePanEstimate(pre_clp, range=range, pixaspect=PAR, trust=0, dxmax=dxmax, dymax=dymax, zoommax=zoom) \ : pre_clp.MDepan(vectors, zoom=zoom>1, rot=rotation, thSCD1=400) dp = DePan(inter, data=mdata, offset=-1, mirror=mirror?15:0, pixaspect=PAR, matchfields=false, subpixel=2) stab = SelectEvery(dp, 2, 0) w = Width(clp) h = Height(clp) thr = 10.0 pre = stab.ConvertToY8()#.ColorYUV(off_y=-15) stab = !mirror && FixFalPos ? \ gScriptClip(stab, " AverageLuma(Crop(pre, 0, 0, -w+MaxBorders+1, 0)) < thr ? clp : \ AverageLuma(Crop(pre, w-MaxBorders-1, 0, 0, 0)) < thr ? clp : \ AverageLuma(Crop(pre, 0, 0, 0, -h+MaxBorders+1)) < thr ? clp : \ AverageLuma(Crop(pre, 0, h-MaxBorders-1, 0, 0)) < thr ? clp : Last return Last ", args="clp, pre, MaxBorders, w, h, thr",Local=true) : stab return !mirror && FixBorders ? FillBorders2(stab, thr=thr, pad=1, MaxBorders=MaxBorders, debug=debug) : stab } Function FillBorders2(clip c, float "thr", int "pad", int "MaxBorders", bool "debug") { thr = Default(thr, 5.0) # Threshold for black borders pad = Default(pad, 0) # Extra padding for borders MaxB = Default(MaxBorders, Max(Round(c.Width()/60.0), 20)) # Maximum of black borders in pixels debug = Default(debug, false) # Show black borders w = Width(c) h = Height(c) pre = c.ConvertToY8()#.ColorYUV(off_y=-15) blank = c.mt_lut("0", chroma="-128") gScriptClip(c, """ x1 = FindBorders(pre, 0, thr, MaxB, pad, w, h) # left x2 = FindBorders(pre, 1, thr, MaxB, pad, w, h) # right y1 = FindBorders(pre, 2, thr, MaxB, pad, w, h) # top y2 = FindBorders(pre, 3, thr, MaxB, pad, w, h) # bottom PreBlur = 0 # If > 0 then there may be an error PostBlur = 0 # Max(x1, x2, y1, y2, 4) # If > 0 then there may be an error b_fix = (x1 + x2 + y1 + y2) > 0 max_fix = Max(x1, x2, y1, y2) msk = b_fix && max_fix >= 8 ? blank.ConvertToY8().LetterBox(y1, y2, x1, x2, color=$ffffff).ConvertToYV12() : blank fixed = !b_fix ? Last \ : max_fix < 8 ? FillBorders(left=x1, top=y1, right=x2, bottom=y2, mode=0, y=3, u=3, v=3) \ : InpaintLogo(mask=msk, Radius=Max(x1,x2,y1,y2,5)*1.5, PreBlur=PreBlur, PostBlur=PostBlur) debug ? mt_merge(fixed, \ blank.ConvertToRGB().LetterBox(y1, y2, x1, x2, color=$ff3333).ConvertToYV12(), \ blank.ConvertToY8().LetterBox(y1, y2, x1, x2, color=$ffffff).ConvertToYV12(), \ luma=true) \ .Subtitle("Black borders:\n "+string(y1)+"\n "+string(x1)+" "+string(x2)+"\n "+ string(y2), \ lsp=0, text_color=$ff3333, font="Courier New", x=MaxB+5, y=MaxB+5) \ : fixed return Last """, args="pre, blank, thr, pad, MaxB, debug, w, h") } function Pre_Clip(clip clp, float "blur", float "contrast", float "brightness"){ blur = Default(blur, 1.0) contrast = Default(contrast, 1.2) brightness = Default(brightness, 10.0) v = clp.mt_lut(expr="x 20 1 x 127.5 / - 21 ^ pi x * 255 / cos 21 ^ - * 1.05 * -", Y=3, U=2, V=2, scale_inputs="allf", use_expr=2) mask_1 = clp.Tweak(sat=0).Blur(blur).mt_edge(mode="min/max", thY1=0, thY2=255, Y=3, U=2, V=2) pre_1 = v.Tweak(cont=contrast, bright=brightness) pre_2 = mt_merge(v, pre_1, mask_1, Y=3, U=2, V=2) pre_3 = pre_2.Tweak(sat=0).mt_invert().Blur(1.58).Blur(1.58).Blur(1.58) pre_4 = mt_lutxy(pre_2, pre_3, expr="x 127.5 > y 255 x - 127.5 / * x 255 x - - + y x 127.5 / * ? ", Y=3, U=2, V=2, scale_inputs="allf", use_expr=2) # s = clp.vsTCanny().mt_binarize(threshold=0, chroma="-128") # Overlay(pre_4, s, mask=s, opacity=0.5) return pre_4 } Code:
# Needed plugins: DePan, DePanEstimate, GRunT, RgTools, MaskTools2, FillBorders, AVSInpaint function Stab_Light(clip clp, int "ts", int "range", int "dxmax", int "dymax", float "zoom", float "PAR", \ bool "mirror", int "MaxBorders", bool "FixBorders", bool "FixFalPos", bool "debug") { ts = Default(ts, 7) #frames to temporal average for better motion estimation (max. 7) range = Default(range, 1) #frames before/after to estimate motion dxmax = Default(dxmax, Round(clp.Width()/180.0)) #maximum deviation in pixels dymax = Default(dymax, dxmax) #x, and y should be the same zoom = Default(zoom, 1) #maximum zoom factor (1 disabled) PAR = Default(PAR, 1.0) #PAR of your source mirror = Default(mirror, false) #Edge filling MaxBorders = Default(MaxBorders, Max(Round(clp.Width()/60.0), 20)) FixBorders = Default(FixBorders, true) FixFalPos = Default(FixFalPos, true) #Fixes borders of MaxBorders more pixels wide debug = Default(debug, false) temp = TemporalSoften(clp, ts, 255, 255, 25, 2) # SC thr to 25 otherwise pans will stutter rep = Repair(temp, TemporalSoften(clp, 1, 255, 255, 25, 2)) inter = Interleave(rep, clp) # temporal stable (better subpixel detection) pre_clp = inter.mt_lut(expr="x 20 1 x 127.5 / - 21 ^ pi x * 255 / cos 21 ^ - * 1.05 * -", Y=3, U=2, V=2).RemoveGrain(mode=17) #ColorYUV(levels="PC->TV") mdata = DePanEstimate(pre_clp, range=range, pixaspect=PAR, trust=0, dxmax=dxmax, dymax=dymax, zoommax=zoom) dp = DePan(inter, data=mdata, offset=-1, mirror=mirror?15:0, pixaspect=PAR, matchfields=false, subpixel=2) stab = SelectEvery(dp, 2, 0) w = Width(clp) h = Height(clp) thr = 10 stab = mirror == false && FixFalPos == true ? gScriptClip(stab, """ pre = ConvertToY8()#.ColorYUV(off_y=-15) AverageLuma(Crop(pre, 0, 0, -w+MaxBorders+1, 0)) < thr ? clp : \ AverageLuma(Crop(pre, w-MaxBorders-1, 0, 0, 0)) < thr ? clp : \ AverageLuma(Crop(pre, 0, 0, 0, -h+MaxBorders+1)) < thr ? clp : \ AverageLuma(Crop(pre, 0, h-MaxBorders-1, 0, 0)) < thr ? clp : stab """, args="clp, stab, MaxBorders, w, h, thr") : stab mirror == false && FixBorders ==true ? FillBorders2(stab, thr=thr, pad=1, MaxBorders=MaxBorders, debug=debug) : stab } function FillBorders2(clip c, int "thr", int "pad", int "MaxBorders", bool "debug") { thr = Default(thr, 5) pad = Default(pad, 0) MaxB = Default(MaxBorders, Max(Round(c.Width()/60.0), 20)) debug = Default(debug, false) w = width(c) h = height(c) gScriptClip(c, """ pre = ConvertToY8()#.ColorYUV(off_y=-15) x1 = 0 x2 = 0 y1 = 0 y2 = 0 for(i = 1, MaxB, 1) { if (AverageLuma(Crop(pre, 0, 0, -w+i, 0)) < thr) {x1 = i + pad} else {break} } for(i = 1, MaxB, 1) { if (AverageLuma(Crop(pre, w-i, 0, 0, 0)) < thr) {x2 = i + pad} else {break} } for(i = 1, MaxB, 1) { if (AverageLuma(Crop(pre, 0, 0, 0, -h+i)) < thr) {y1 = i + pad} else {break} } for(i = 1, MaxB, 1) { if (AverageLuma(Crop(pre, 0, h-i, 0, 0)) < thr) {y2 = i + pad} else {break} } PreBlur = 0 #If > 0 then there may be an error PostBlur = 0 #Max(x1, x2, y1, y2, 4) #If > 0 then there may be an error b_fix = (x1 + x2 + y1 + y2) > 0 max_fix = Max(x1, x2, y1, y2) msk = b_fix && max_fix >= 8 ? pre.mt_lut("0", chroma="-128").LetterBox(y1, y2, x1, x2, color_yuv=$ffffff).ConvertToYV12() : \ pre.mt_lut("0", chroma="-128") fixed = b_fix ? max_fix < 8 ? FillBorders(left=x1, top=y1, right=x2, bottom=y2, mode=0, y=3, u=3, v=3) : \ InpaintLogo(mask=msk, Radius=Max(x1,x2,y1,y2,5)*1.5, PreBlur=PreBlur, PostBlur=PostBlur) : \ c debug == true ? mt_merge(fixed, \ c.mt_lut("0", chroma="-128").ConvertToRGB().LetterBox(y1, y2, x1, x2, color=$ff3333).ConvertToYV12(), \ pre.mt_lut("0", chroma="-128").LetterBox(y1, y2, x1, x2, color_yuv=$ffffff).ConvertToYV12(), \ luma=true)\ .Subtitle("Black borders:\n "+string(y1)+"\n "+string(x1)+" "+string(x2)+"\n "+ string(y2), \ lsp=0, text_color=$ff3333, font="Courier New", x=MaxB+5, y=MaxB+5) : \ fixed """, args="c, thr, pad, MaxB, debug, w, h") } Stab_Light(zoom = 1.00, mirror = false, FixFalPos = true, FixBorders = true, debug = false) or Stab_Light(ts=7, zoom=1.0, mirror=false, rotation=false, FixFalPos=true, FixBorders=true, MethodMS=1, debug=false) Original and stabilized clip Last edited by Arx1meD; 24th June 2021 at 09:38. |
#2 | Link |
![]() Join Date: Oct 2001
Your filter has arrived at the right time as I've just begun work on an especially jumpy video. It seems to work fine but there's a line imprinted at the top of the entire video: Script error: Syntax error ([Script Clip], line 8 column 21) Would you happen to know anything about that? Thank you. Last edited by manono; 13th March 2021 at 02:02. |
#3 | Link | |
Avs+ ? [Uses for/next loop - OR, if not Avs+, use GScript's GImport() on OP script]
and all requirements fulfilled ? # DePan, DePanEstimate, GRunT, RgTools, MaskTools2, FillBorders, AVSInpaint Quote:
gScriptClip(c, """ pre = ConvertToY8()#.ColorYUV(off_y=-15) x1 = 0 x2 = 0 y1 = 0 y2 = 0 for(i = 1, MaxB, 1) { # <<<<< Line 8, coloumn 21 is @ the curly brace thing '{' : looks like need Avs+ or GScript for for/next loop if (AverageLuma(Crop(pre, 0, 0, -w+i, 0)) < thr) {x1 = i + pad} else {break} } for(i = 1, MaxB, 1) { if (AverageLuma(Crop(pre, w-i, 0, 0, 0)) < thr) {x2 = i + pad} else {break} } for(i = 1, MaxB, 1) { if (AverageLuma(Crop(pre, 0, 0, 0, -h+i)) < thr) {y1 = i + pad} else {break} } for(i = 1, MaxB, 1) { if (AverageLuma(Crop(pre, 0, h-i, 0, 0)) < thr) {y2 = i + pad} else {break} } PreBlur = 0 #If > 0 then there may be an error PostBlur = 0 #Max(x1, x2, y1, y2, 4) #If > 0 then there may be an error b_fix = (x1 + x2 + y1 + y2) > 0 max_fix = Max(x1, x2, y1, y2) msk = b_fix && max_fix >= 8 ? pre.mt_lut("0", chroma="-128").LetterBox(y1, y2, x1, x2, color_yuv=$ffffff).ConvertToYV12() : \ pre.mt_lut("0", chroma="-128") fixed = b_fix ? max_fix < 8 ? FillBorders(left=x1, top=y1, right=x2, bottom=y2, mode=0, y=3, u=3, v=3) : \ InpaintLogo(mask=msk, Radius=Max(x1,x2,y1,y2,5)*1.5, PreBlur=PreBlur, PostBlur=PostBlur) : \ c debug == true ? mt_merge(fixed, \ c.mt_lut("0", chroma="-128").ConvertToRGB().LetterBox(y1, y2, x1, x2, color=$ff3333).ConvertToYV12(), \ pre.mt_lut("0", chroma="-128").LetterBox(y1, y2, x1, x2, color_yuv=$ffffff).ConvertToYV12(), \ luma=true)\ .Subtitle("Black borders:\n "+string(y1)+"\n "+string(x1)+" "+string(x2)+"\n "+ \ string(y2), lsp = 10, text_color=$ff3333, font="Courier New", x=MaxB+5, y=MaxB+5) : \ fixed """, args="c, thr, pad, MaxB, debug, w, h") Code:
AviSource("d:\Parade.avi") Stab_Light() Code:
AviSource(".\stab_example.mkv.AVI") # OP's sample, After ffmpeg conversion to UT_Video AVI W=width/2 crop(0,0,W,0) # only unstable half ORG=Last Stab_Light(zoom = 1.00, mirror = false, FixFalPos = true, FixBorders = true, debug = false) D=Last.Subtract(ORG) T=StackHorizontal(ORG,Last) B=StackHorizontal(D,D) StackVertical(T,B) ![]()
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 12th March 2021 at 22:12. |
#4 | Link | ||||
Thanks for taking the time to have a look, StainlessS.
LWLibavVideoSource("EK Do Teen.mp4") Stab_Light(zoom = 1.00, mirror = false, FixFalPos = true, FixBorders = true, debug = false) Return Last Even with no arguments (Stab_Light()), same thing. Maybe Arx1meD will have an idea. Thanks again. Last edited by manono; 13th March 2021 at 07:47. |
#5 | Link |
OK, I'm gettin' same error message as you now with 2.6 std.
I'll play a bit more but may not do it tonite if takes very long, its after 04:00 am here.
#6 | Link |
Well I've had a bit more play, and not sure whats going on (maybe I need sleep badly or something, things just dont add up).
this thing Code:
for(i = 1, MaxB, 1) { if (AverageLuma(Crop(pre, 0, 0, -w+i, 0)) < thr) {x1 = i + pad} else {break} } I think I once asked for Gavino to implement break and Do {} Until (), he was non too keen, he likes the easy life. Does anybody know if Pinterf impemented break, and if it was documented somewhere ? [Break seems to be the prob, but it somehow flags the error earlier in script]. I'll try fix it [to work under GScript]. EDIT: Fixed as below, but still gives pretty much same error. Code:
for(i = 1, MaxB, 1) { if (AverageLuma(Crop(pre, 0, 0, -w+i, 0)) < thr) {x1 = i + pad} else { i = MaxB } }
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 13th March 2021 at 06:28. |
#7 | Link |
manono I am using AVS + and I have no errors.
Earlier I used the borders search method written in FillBorders_stabi. In FillBorders_stabi, the maximum borders is 4 px. I increased the search for the borders to 16 px. Old version of my FillBorders2. See the modified version in post #27 Code:
function FillBorders2(clip c, int "thr", int "pad", int "MaxBorders", bool "debug") { thr = Default(thr, 5) pad = Default(pad, 0) MaxB = Default(MaxBorders, 16) debug = Default(debug, false) w = width(c) h = height(c) gScriptClip(c, """ pre = ConvertToY8()#.ColorYUV(off_y=-15) x1 = AverageLuma(crop(pre, 0, 0, -w+1, 0)) < thr ? \ (AverageLuma(crop(pre, 0, 0, -w+2, 0)) < thr ? \ (AverageLuma(crop(pre, 0, 0, -w+3, 0)) < thr ? \ (AverageLuma(crop(pre, 0, 0, -w+4, 0)) < thr ? \ (AverageLuma(crop(pre, 0, 0, -w+5, 0)) < thr ? \ (AverageLuma(crop(pre, 0, 0, -w+6, 0)) < thr ? \ (AverageLuma(crop(pre, 0, 0, -w+7, 0)) < thr ? \ (AverageLuma(crop(pre, 0, 0, -w+8, 0)) < thr ? \ (AverageLuma(crop(pre, 0, 0, -w+9, 0)) < thr ? \ (AverageLuma(crop(pre, 0, 0, -w+10, 0)) < thr ? \ (AverageLuma(crop(pre, 0, 0, -w+11, 0)) < thr ? \ (AverageLuma(crop(pre, 0, 0, -w+12, 0)) < thr ? \ (AverageLuma(crop(pre, 0, 0, -w+13, 0)) < thr ? \ (AverageLuma(crop(pre, 0, 0, -w+14, 0)) < thr ? \ (AverageLuma(crop(pre, 0, 0, -w+15, 0)) < thr ? \ (AverageLuma(crop(pre, 0, 0, -w+16, 0)) < thr ? 16 : 15) : 14) : 13) : 12) : 11) : 10) : 9) : 8) : 7) : 6) : 5) : 4) : 3) : 2) : 1) : 0 x2 = AverageLuma(Crop(pre, w-1, 0, 0, 0)) < thr ? \ (AverageLuma(Crop(pre, w-2, 0, 0, 0)) < thr ? \ (AverageLuma(Crop(pre, w-3, 0, 0, 0)) < thr ? \ (AverageLuma(Crop(pre, w-4, 0, 0, 0)) < thr ? \ (AverageLuma(Crop(pre, w-5, 0, 0, 0)) < thr ? \ (AverageLuma(Crop(pre, w-6, 0, 0, 0)) < thr ? \ (AverageLuma(Crop(pre, w-7, 0, 0, 0)) < thr ? \ (AverageLuma(Crop(pre, w-8, 0, 0, 0)) < thr ? \ (AverageLuma(Crop(pre, w-9, 0, 0, 0)) < thr ? \ (AverageLuma(Crop(pre, w-10, 0, 0, 0)) < thr ? \ (AverageLuma(Crop(pre, w-11, 0, 0, 0)) < thr ? \ (AverageLuma(Crop(pre, w-12, 0, 0, 0)) < thr ? \ (AverageLuma(Crop(pre, w-13, 0, 0, 0)) < thr ? \ (AverageLuma(Crop(pre, w-14, 0, 0, 0)) < thr ? \ (AverageLuma(Crop(pre, w-15, 0, 0, 0)) < thr ? \ (AverageLuma(Crop(pre, w-16, 0, 0, 0)) < thr ? 16 : 15) : 14) : 13) : 12) : 11) : 10) : 9) : 8) : 7) : 6) : 5) : 4) : 3) : 2) : 1) : 0 y1 = AverageLuma(Crop(pre, 0, 0, 0, -h+1)) < thr ? \ (AverageLuma(Crop(pre, 0, 0, 0, -h+2)) < thr ? \ (AverageLuma(Crop(pre, 0, 0, 0, -h+3)) < thr ? \ (AverageLuma(Crop(pre, 0, 0, 0, -h+4)) < thr ? \ (AverageLuma(Crop(pre, 0, 0, 0, -h+5)) < thr ? \ (AverageLuma(Crop(pre, 0, 0, 0, -h+6)) < thr ? \ (AverageLuma(Crop(pre, 0, 0, 0, -h+7)) < thr ? \ (AverageLuma(Crop(pre, 0, 0, 0, -h+8)) < thr ? \ (AverageLuma(Crop(pre, 0, 0, 0, -h+9)) < thr ? \ (AverageLuma(Crop(pre, 0, 0, 0, -h+10)) < thr ? \ (AverageLuma(Crop(pre, 0, 0, 0, -h+11)) < thr ? \ (AverageLuma(Crop(pre, 0, 0, 0, -h+12)) < thr ? \ (AverageLuma(Crop(pre, 0, 0, 0, -h+13)) < thr ? \ (AverageLuma(Crop(pre, 0, 0, 0, -h+14)) < thr ? \ (AverageLuma(Crop(pre, 0, 0, 0, -h+15)) < thr ? \ (AverageLuma(Crop(pre, 0, 0, 0, -h+16)) < thr ? 16 : 15) : 14) : 13) : 12) : 11) : 10) : 9) : 8) : 7) : 6) : 5) : 4) : 3) : 2) : 1) : 0 y2 = AverageLuma(Crop(pre, 0, h-1, 0, 0)) < thr ? \ (AverageLuma(Crop(pre, 0, h-2, 0, 0)) < thr ? \ (AverageLuma(Crop(pre, 0, h-3, 0, 0)) < thr ? \ (AverageLuma(Crop(pre, 0, h-4, 0, 0)) < thr ? \ (AverageLuma(Crop(pre, 0, h-5, 0, 0)) < thr ? \ (AverageLuma(Crop(pre, 0, h-6, 0, 0)) < thr ? \ (AverageLuma(Crop(pre, 0, h-7, 0, 0)) < thr ? \ (AverageLuma(Crop(pre, 0, h-8, 0, 0)) < thr ? \ (AverageLuma(Crop(pre, 0, h-9, 0, 0)) < thr ? \ (AverageLuma(Crop(pre, 0, h-10, 0, 0)) < thr ? \ (AverageLuma(Crop(pre, 0, h-11, 0, 0)) < thr ? \ (AverageLuma(Crop(pre, 0, h-12, 0, 0)) < thr ? \ (AverageLuma(Crop(pre, 0, h-13, 0, 0)) < thr ? \ (AverageLuma(Crop(pre, 0, h-14, 0, 0)) < thr ? \ (AverageLuma(Crop(pre, 0, h-15, 0, 0)) < thr ? \ (AverageLuma(Crop(pre, 0, h-16, 0, 0)) < thr ? 16 : 15) : 14) : 13) : 12) : 11) : 10) : 9) : 8) : 7) : 6) : 5) : 4) : 3) : 2) : 1) : 0 x1 = x1 > 0 ? x1+pad : x1 x2 = x2 > 0 ? x2+pad : x2 y1 = y1 > 0 ? y1+pad : y1 y2 = y2 > 0 ? y2+pad : y2 PreBlur = 0 #If > 0 then there may be an error PostBlur = 0 #Max(x1, x2, y1, y2, 4) #If > 0 then there may be an error b_fix = (x1 + x2 + y1 + y2) > 0 max_fix = Max(x1, x2, y1, y2) msk = b_fix && max_fix >= 8 ? pre.mt_lut("0", chroma="-128").LetterBox(y1, y2, x1, x2, color=$ffffff).ConvertToYV12() : \ pre.mt_lut("0", chroma="-128") fixed = b_fix ? max_fix < 8 ? FillBorders(left=x1, top=y1, right=x2, bottom=y2, mode=0, y=3, u=3, v=3) : \ InpaintLogo(mask=msk, Radius=Max(x1,x2,y1,y2,5)*1.5, PreBlur=PreBlur, PostBlur=PostBlur) : \ c debug == true ? mt_merge(fixed, \ c.mt_lut("0", chroma="-128").ConvertToRGB().LetterBox(y1, y2, x1, x2, color=$ff3333).ConvertToYV12(), \ pre.mt_lut("0", chroma="-128").LetterBox(y1, y2, x1, x2, color=$ffffff).ConvertToYV12(), \ luma=true)\ .Subtitle("Black borders:\n "+string(y1)+"\n "+string(x1)+" "+string(x2)+"\n "+string(y2), lsp = 10, text_color=$ff3333, font="Courier New", x=MaxB+5, y=MaxB+5) : \ fixed """, args="c, thr, pad, MaxB, debug, w, h") } Stab_Light(zoom = 1.00, mirror = false, MaxBorders=16, FixFalPos = true, FixBorders = true, debug = false) Last edited by Arx1meD; 14th March 2021 at 07:43. Reason: Changed color_yuv to color in LetterBox |
#8 | Link |
And thank you for taking a look. I'm not entirely sure I understand you correctly, but if change the filter settings to: Stab_Light(zoom = 1.00, mirror = false, MaxBorders=16, FixFalPos = true, FixBorders = true, debug = false) I still get the same error message. Should this filter be used only with AviSynth+? |
#9 | Link |
Thank you for taking the time to test this script.
Have you replaced the FillBorders2 function? Can you write what kind of error? As before: [Script Clip], line 8 column 21 ? Try using Stab3 until I find the error. Perhaps you are right and my FillBorders2 works correctly only in AVS+. Last edited by Arx1meD; 13th March 2021 at 09:40. |
#10 | Link |
manono, I checked my old version of the FillBorders2 function in AviSynth 2.6 and there was no error.
Whatever I do I have failed to fix a bug in gScriptClip ([Script Clip], line 8 column 21). I guess I'm using "for(i = 1, MaxB, 1)..." incorrectly. Last edited by Arx1meD; 13th March 2021 at 15:31. |
#11 | Link |
I dont think Manono quite understood that you intended for him to replace posted Fillborders2 with your older one in post #7.
I'll try with both old and new and see if I can find solution more like your inital posted Fillborders2. EDIT: OK, you just beat me with your post.
#13 | Link |
It should with GScript installed. [ so long as used with eg for(){} : If/Else, or While(){} ].
EDIT: If below GG() function is held in eg GG.avsi, and GImport'ed instead of inline with GSCript(""" ... """) would work OK. Code:
GScript(""" Function GG() { t=0 for(i=0,10,1) { t=t+i if(i==5) { i=10 # Break } } return t } """) blankclip x = GG() Subtitle(String(x)) return last
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 13th March 2021 at 16:29. |
#15 | Link |
Sorry, that was just an example showing that can use '{' '}' using GScript with V2.60 Std.
Example can use as given in prev post, ie surrounded by GScript(""" ... """), or without the GScript(""" ... """) thing if GImport'ed. But of course you need GScript dll in plugins. Avs+ has GScript functionality builtin, does not need the GScript(""" ... """) thing, nor GImport(), nor the plugin dll. If we get a solution, then avs 2.60 std [with gscript dll loaded] needs to GImport the avsi, and Avs+ needs to Import, or have it in plugins dir.
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 13th March 2021 at 17:22. |
#17 | Link |
Break is not implemented in GScript [despite my asking for it some years ago].
#19 | Link |
As I mentioned last time, I wasn't sure I understood your earlier post. Your list of required filters in your first post mentions only FillBorders. There's nothing about FillBorders2. Okay, I copied it from your post and added an Import line to the script.
Since the last time I ran an encode using other filters and now have a Lagarith AVI with which to work. The current script: AVISource("Movie.avi") Stab_Light(zoom = 1.00, mirror = false, MaxBorders=16, FixFalPos = true, FixBorders = true, debug = false) Return Last I opened it in VDub and got a different error message this time: "_lut: unsupported colorspace, masktools only support planar YUV colorspaces (YV12, YV16, YV ([ScriptClip], line 83)" The message appears to be cut off after the 'YV'. The AVI is already in YV12. |
#20 | Link |
manono, which version of MaskTools2 are you using?
The problem in mt_lut. In http://avisynth.nl says that mt_lut supports the Y8 color format. Code:
msk = b_fix && max_fix >= 8 ? pre.mt_lut("0", chroma="-128").LetterBox(y1, y2, x1, x2, color=$ffffff).ConvertToYV12() : \ pre.mt_lut("0", chroma="-128") # line 83 Code:
pre = ConvertToY8()#.ColorYUV(off_y=-15) Last edited by Arx1meD; 13th March 2021 at 21:08. |
deshaker |
