#2 | Link |
ffx264/ffhevc author
No, but on 1080p, a lot of people use cu-size of 32. 64 is mostly beneficial for UHD
TV: Samsung 50" QE50Q60T AVR: Yamaha RX-V481 5.1 CD Player: Yamaha CD-S300 DAB+ Tuner: Yamaha T-D500 BD Player: Samsung UBD-M8500 UHD Speakers: Klipsch 5.1 Reference Phono: Audio-Technica AT-LP120XUSB |
#4 | Link |
Derek Prestegard IRL
![]() Join Date: Nov 2003
Don't get confused between --ctu and --min-cu-size
https://x265.readthedocs.io/en/defau...on-min-cu-size You probably don't want to mess with this. Use the presets. 8 is the default for everything except ultrafast. It sets the minimum possible coding unit size. The HEVC standard lets you go as small as 8x8 and the encoder will do this when it makes sense. If you force this to be higher then you can go faster in some cases because you don't even evaluate 8x8. In practice, you will usually want to have some 8x8 CUs though, so forcing the encoder to never consider this is a bad idea. --ctu on the other hand is a super important setting. The default (64) makes sense most of the time. Lower values can preserve a bit more fine detail in still images and can be more parallel (since you're processing a larger number of smaller CUs), but the 64x64 CU is a HUGE deal in HEVC and helps a ton overal for most content, especially 4K, and especially when you compare clips in motion vs still images. The reduction in blocking is great! I suggest always leaving this at 64 unless you need to go fast, in which case you should be using the presets anyway ![]() Last edited by Blue_MiSfit; 10th April 2020 at 01:58. |
#5 | Link | |
![]() Though I don't understand this: Note All encoders within a single process must use the same settings for the CU size range. --ctu and --min-cu-size must be consistent for all of them since the encoder configures several key global data structures based on this range. By consistent, doesn't that mean it should be ctu=32 min-cu-size=32 / instead of ctu=64 min-cu-size=8?. Last edited by F3low; 10th April 2020 at 11:58. |
#6 | Link |
結城有紀
That means if you choose 64/8 for one encoder inside a running process (a running process is an individual program process, refer to OS text book if you don't know), you can't run another encoder within the same process with different settings.
For example you have a tool called a.exe that internally initialize x265 encoder with mincu=8, then you can't internally initialize another x265 encoder with mincu=16. You have to run another a.exe to encode in a different cu size. If you run x265.exe, then if you run x265 with mincu=8, and you want to make another encode with mincu=16, you have to run another x265.exe. Hope this is clear.
Projects x265 - Yuuki-Asuna-mod Download / GitHub TS - ADTS AAC Splitter | LATM AAC Splitter | BS4K-ASS Neo AviSynth+ filters - F3KDB | FFT3D | DFTTest | MiniDeen | Temporal Median Last edited by MeteorRain; 10th April 2020 at 14:37. |
#7 | Link | |
newbie |
