Old 17th August 2016, 20:40   #1  |  Link
doomleox999
MPC double playback speed
Hi everyone, first of all, english is not my native language so sorry for any mistake here and there. I have a problem when I play 60fps videos at double playback speed. Every 5 seconds or so, the video freezes, audio gets out of sync, and only when the audio catchs up to the video the playback continues. This doesn't happen when I play 30fps videos at double playback speed. Is there any special setting that I have to change or the problem is my hardware?
PS: help me improve my english by pointing out any mistake that I may had made.
doomleox999 is offline   Reply With Quote
Old 17th August 2016, 21:57   #2  |  Link
luigizaninoni
Your hardware is not powerful enough to show 120 frames per second on given settings. So you can either use more powerful hardware, or lower your settings (for example if you use madvr lower your upscale options, etc). Your english looks excellent to me
luigizaninoni is offline   Reply With Quote
Old 17th August 2016, 23:36   #3  |  Link
doomleox999
luigizaninoni this are my settings (Options/Playback/Output):
Should I use madvr instead of EVR? And what do you mean by lower your upscale options?
Thanks, good to know.
Old 18th August 2016, 08:20   #4  |  Link
luigizaninoni
Try render overlay mixer, I think it is the lightest
Use nearest neighbour instead of bilinear resize. Quality will deteriorate, but it might work.
Don't use madvr, it's heavier than EVR
If it still does not work, upgrade your hardware.
You might also ask for advice in mpc-hc thread, to know if there are even lighter settings.
Old 19th August 2016, 00:05   #5  |  Link
doomleox999
It didn't work. I guess IŽll have to upgrade my hardware then. It's the obvious solution haha. Thanks anyway.
audio out of sync, lag, mpc hc, playback speed
