Old 1st November 2016, 22:19   #81  |  Link
real.finder
@pinterf
can you add rgb24 support in MSuper and MAnalyse and MRecalculate?
making the support work as if it one colour not treats it as R G B separately
See My Avisynth Stuff
Old 1st November 2016, 23:39   #82  |  Link
feisty2
I'm Siri
feisty2's Avatar
RGB sucks
I added RGB support in my branch of mvtools and it didn't work out so well
feisty2 is offline   Reply With Quote
Old 1st November 2016, 23:43   #83  |  Link
Originally Posted by real.finder View Post
@pinterf
How exactly would one measure differences if implemented as above ?
Would diff in blue count a teeny weeny bit, in green somewhat more, and in red a helluva lot ?
Old 2nd November 2016, 00:16   #84  |  Link
real.finder
I didn't get what you mean well but what about convert rgb24 to hex internally in MAnalyse and MRecalculate?
Old 2nd November 2016, 00:26   #85  |  Link
One would have to have some difference measure, eg convert rgb to luma-y, and measure dif in that.
Or rgb color cube distance.
I don't get what you are saying about convert to hex.
Perhaps you should elaborate a little on what you want.
Old 2nd November 2016, 00:31   #86  |  Link
real.finder
https://en.wikipedia.org/wiki/Web_co...to_hexadecimal
Old 2nd November 2016, 00:45   #87  |  Link
pinterf
Mixing color component together does not help. The base of the whole motion analysis is SAD, pixel values of two frames get subtracted, then we get the absolute value and finally sum them up for 8x8, 16x16, up to 128x128 (vapoursynth mvtools2 port) pixel blocks.
Creating a compound representation of rgb value result us that the component at the lsb side will affect the result for 1/65536 of weight than the component at the msb side 0xff0000 mask (for 8 bits)
pinterf is offline   Reply With Quote
Old 14th November 2016, 02:22   #88  |  Link
See here Bug in v2.5.11.2 and v2.5.11.20, and v2.5.11.22. Fixed in v2.7.1.22:- http://forum.doom9.org/showthread.php?t=174025
Also, MvTools2 v2.7.1.22 MBlockFps(Blend=False) and MFlowFps(Blend=False) are broken, creates mangled frames at scene change.
Old 14th November 2016, 08:55   #89  |  Link
pinterf
mvtool2
could you please try this test build (overlap fix only), and report back, though the scenechange problem is not intended to be fixed.
http://www.mediafire.com/file/u8pp73...orStainless.7z
(test only, not for public)
Edit: what do you mean under "mangled", can you provide a test script and a hint where to look at that behaviour, and also, whether older 2.5.xx or 2.6.0.5 versions behave similarly?
Old 14th November 2016, 10:25   #90  |  Link
Overlap fix seems to work ok.
By Mangled I meant that bad frame was produced, did not seem to be blend or correct behavior when Blend=False, ie duplicate previous frame
(that is End Of Scene Frame) at scene change.
Script testing v2.6.0.5 (frames are so different that synthesized frames should be same as frame prior to them [EDIT: when Blend=false).
EDIT: Result Frames 0, 2 and 4 are the original frames with a scene change between each, frames 1 and 3 are synthesized frames at scene change.
Function DoubleRate(clip c,Bool "Blend",Bool "Flow") {
    # Works OK with MvTools2 v2.6.0.5
    c
    Blend=Default(Blend,False)                                      # Avoid blends at scene change (copy previous frame)
    Flow=Default(Flow,False)                                        # If True, Use MFlowFps instead of MBlockFps
    super     = MSuper(pel=2, hpad=16, vpad=16,rfilter=4)
    bw_1      = MAnalyse(super, chroma = false, isb = true,  blksize = 16, OverLap=2, searchparam = 3, plevel = 0, search = 3, badrange = (-24))
    fw_1      = MAnalyse(super, chroma = false, isb = false, blksize = 16, OverLap=2, searchparam = 3, plevel = 0, search = 3, badrange = (-24))
    bw_2      = MRecalculate(super, chroma = false, bw_1, blksize = 8, searchparam = 1, search = 3)    # No Overlap (currently broken for final vectors)
    fw_2      = MRecalculate(super, chroma = false, fw_1, blksize = 8, searchparam = 1, search = 3)    # No Overlap
    Return (!Flow)
        \ ? MBlockFps(super, bw_2, fw_2, num=FramerateNumerator(c) * 2, den=FramerateDenominator(c), mode=0, Blend=Blend)
        \ : MFlowFps(super, bw_2, fw_2, num=FramerateNumerator(c) * 2, den=FramerateDenominator(c), Blend=Blend)
BLEND=False
FLOW=False
A=Colorbars.Killaudio.ConvertToYV12.Trim(0,-1)
B=A.FlipHorizontal
(A++B++A).ShowFrameNumber
DoubleRate(Blend=BLEND,Flow=FLOW)
BilinearResize(320,240)
I=Last.Blankclip(Height=4)
StackVertical(Trim(0,-1),I,Trim(1,-1),I,Trim(2,-1),I,Trim(3,-1),I,Trim(4,-1))
result
Script testing v2.7.1.22 and working for OverLap and without the previous script MRecalculate to step over the Overlap bug (In actual fact v2.6.0.5 puts
up error OverLap Must be 0, if function creating MBlockFps used vectors, use Overlap>0).
    # for MvTools2 v2.7.1.22 testing
    c
    Return (!Flow)
        \ ? MBlockFps(super, bw_1, fw_1, num=FramerateNumerator(c) * 2, den=FramerateDenominator(c), mode=0, Blend=Blend)
        \ : MFlowFps(super, bw_1, fw_1, num=FramerateNumerator(c) * 2, den=FramerateDenominator(c), Blend=Blend)
BLEND=False
FLOW=False
B=A.FlipHorizontal
Result (showing 'Mangled frames')
You can check the behaviour using 2nd script DoubleRate() and look at any scene change, with Blend=True, should create blend at scene change, if false, then should use copy of End of Scene frame for synthesized frame [EDIT: As in first above result].
Thanks pinterf, looking good.
EDIT: I dont know if you saw a previous edit from the Interframe thread, here tis:-
EDIT: The problem seems to occur if OverLap used in creating final BackWards and Forwards vectors supplied to MBlockFps,
ie MAnalyse(Overlap=whatever) if MRecalculate not used, and in final MRecalculate(Overlap=whatever) if used.
This works ok without Overlap in final vectors
Function foo2(clip source, int "multi") {
    last       = source
    multi      = default(multi, 2)
    prefilt    = DeGrainMedian()                                        # some smoothing
    superfilt  = MSuper(prefilt, hpad=16, vpad=16)                         # all levels for MAnalyse
    super      = MSuper(source, pel = 2, hpad = 16, vpad = 16, rfilter = 4) # one level is enough for MRecalculate
    bw_1       = MAnalyse(superfilt, chroma = false, isb = true, blksize = 16,  OverLap=8, searchparam = 3, plevel = 0, search = 3, badrange = (-24))
    fw_1       = MAnalyse(superfilt, chroma = false, isb = false, blksize = 16, OverLap=8, searchparam = 3, plevel = 0, search = 3, badrange = (-24))
    bw_2       = MRecalculate(super, chroma = false, bw_1, blksize = 8, OverLap=4, searchparam = 1, search = 3)
    fw_2       = MRecalculate(super, chroma = false, fw_1, blksize = 8, OverLap=4,searchparam = 1, search = 3)
    bw_3       = MRecalculate(super, chroma = false, bw_2, blksize = 4, searchparam = 0, search = 3)    # No Overlap
    fw_3       = MRecalculate(super, chroma = false, fw_2, blksize = 4, searchparam = 0, search = 3)    # No Overlap
    MBlockFps(source, super, bw_3, fw_3, FramerateNumerator(Source) * multi, FramerateDenominator(Source), mode = 0, Blend=False)
    return last
But think I'll be using this until fixed at least.
Function DoubleRate(clip c,Bool "Blend") {
    c
    superfilt = MSuper(prefilt, hpad=16, vpad=16, rfilter = 4)      # all levels for MAnalyse
    super     = MSuper(pel=2, hpad=16, vpad=16,rfilter=4,levels=1)  # one level is enough for MRecalculate
    bw_1      = MAnalyse(superfilt, chroma = false, isb = true,  blksize = 16, OverLap=2, searchparam = 3, plevel = 0, search = 3, badrange = (-24))
    fw_1      = MAnalyse(superfilt, chroma = false, isb = false, blksize = 16, OverLap=2, searchparam = 3, plevel = 0, search = 3, badrange = (-24))
    Return Last
EDIT: Ive Added BLEND arg to above two scripts, Default False, here are both results in order with BLEND=True
script 1
script 2 (showing 'Mangled frames')
EDIT: I've added FLOW=False default to both scripts, so you can also test MFlowFps if set true.
EDIT: I spoke too soon, there seems to be a problem at right and bottom edges on real video, also can be seen on frames 1 and 3
of 2nd results.
Script producing
    c
    Return (!Flow)
AvisourcE("F:\v\StarWars.avi")
DoubleRate
Trim(12744,12746)
LanczosResize(400,224)
StackVertical(Trim(0,-1),Trim(1,-1),Trim(2,-1))
EDIT: Still occurs if adding Crop(4,4,-4,-4) before call to DoubleRate (get rid of any crud, for padding).
EDIT: Still occurs if changing hpad and vpad to 0.
EDIT: And a live video scene change (Blend=false)
EDIT: What above looks like using v2.6.0.5 and same script but with script1 DoubeRate(Blend=True), Blend=False (as above)
should produce 2nd frame same as the 1st frame.
Old 14th November 2016, 16:35   #91  |  Link
pinterf
Thanks, don't spend any more time on it, fabuolus error report. Now it's my turn.
Old 16th November 2016, 00:43   #92  |  Link
pinterf
Hi StainlessS!
Try this test build please.
http://www.mediafire.com/file/aako4w...StainlessS.zip
About the bug. er...
Guess what: A /256 was somehow changed into /(8*8) for better readability . No, it wasn't really me, but the monkeys.
As a side-effect I think I have ported MFlowFPS to native 10-16 bits that can be used with Avisynth+.
Old 16th November 2016, 03:42   #93  |  Link
MBlockFPS, have fixed side green border, but bottom green border remains in synthesized frames where not at scene change,
ie at scene change, synthesized frame is duplicate of previous frame (blend=false), or simple 50.0/50.0 blend (Blend=True),
so just a problem in synthesized frames that are not at scene change.
The Mangled frames at scene change have gone.
MFlowFPS, dont see any problems.
Unfortunately, I made a bob-boo earlier in other 'Compiler Error ???' thread, I said problem was gone (MSCDetection floating point -1.#IND000),
unfortunately, I dont seem to have checked for more than the disappearance of the floating point error, seems that the MSCDetection return clip
never spots a scene change, all frames identical Green, which is I think all YUV channels 0. (Both End of Scene and Start of Scene clips fail).
Below, code snippet to do detections easily yourself, requires no external plugins (EXCEPT of course MVTools2, which I know you have ).
FN="F:\v\StarWars.avi"
BLEND= false
FLOW = false
Avisource(FN)
#Trim(10000,0)
DORG=SelectEvery(1,0,0)                                 # Original Each frame twice
DBL =DoubleRate(Blend=BLEND,Flow=FLOW)
DORG_S = DORG.Sub("Original, Each frame twice",0)
DBL_S  = DBL.Sub("Double Rate : Blend="+String(Blend)+" Flow="+String(Flow),1)
Return StackVertical(DORG_S,DBL_S)
    c
    Return (!Flow)
        \ ? MBlockFps(super, bw_1, fw_1, num=FramerateNumerator(c) * 2, den=FramerateDenominator(c), Blend=Blend, mode=0)
Function Sub(clip c,string tit,int Md) {
    Function SubStrLo(int n,string tit,Int Md) {Return string(n)+"] "+tit+(n%2==0?"":Md==0?" (Duplicate)":" (Synthesized)")}
    S = "SubTitle(SubStrLo(current_frame,"+Chr(34)+tit+Chr(34)+","+String(Md)+"))"
    StackVertical(c.BlankClip(height=20).ScriptClip(S),c)
Produces something like below (at scene change, Blend=true [no green bottom border in synth frame at scene change])
EDIT: Above script, you can scrub through whole movie in eg VDubMod and check-out scene changes, and mod BLEND and FLOW
to check other modes.
EDIT: Oops, sorry, above script requires Grunt plugin.
EDIT: Got rid of Grunt() requirement, script updated.
Old 16th November 2016, 15:22   #94  |  Link
pinterf
Hi! Found something, another try
http://www.mediafire.com/file/60o8c4...tainLessS2.zip
Test build, not a release.
The bottom line bug was fixed.
The fixes/additions since 2.7.1.22:
- new: MBlockFPS 10-16 bit
- nSCD2 regression fix
- nSCD1 (thCSD1) scale for 10+ bits
- MBlockFPS: overlaps working buffers were not copied to the output.
- MBlockFPS: overlaps: Right columns were ok for the luma only.
- MBlockFPS: overlaps: Blend of bottom rows were operating on somewhere the top rows instead of the last row.
There are still visible differences on the edges, because right and bottom lines are simply blended when we use overlaps, but this is the way it works.
Old 17th November 2016, 14:09   #95  |  Link
Oh dear, wish you had not told me that, I'll be forever looking for it now
Script, no requirements.
BLEND= false
FLOW = false
Avisource(FN)
DORG = SelectEvery(1,0,0)                                 # Original Each frame twice
DBLA = DoubleRateA(Blend=BLEND,Flow=FLOW)
DBLB = DoubleRateB(Blend=BLEND,Flow=FLOW)
DBLC = DoubleRateC(Blend=BLEND,Flow=FLOW)
DBLA_S = DBLA.Sub("DoubleRate_A(OLap=0) : Blend="+String(Blend)+" Flow="+String(Flow),1)
DBLB_S = DBLB.Sub("DoubleRate_B(NEW, Olap=8)    : Blend="+String(Blend)+" Flow="+String(Flow),1)
DBLC_S = DBLC.Sub("DoubleRate_C(MRecalc, Olap=8): Blend="+String(Blend)+" Flow="+String(Flow),1)
H     = DORG_S.Blankclip(Height=4,color=$FFFFFF)
LFT   = StackVertical(DORG_S,H,DBLB_S)
RGT   = StackVertical(DBLA_S,H,DBLC_S)
V     = LFT.Blankclip(Width=4,color=$FFFFFF)
Return  StackHorizontal(LFT,V,RGT)  #.trim(48115,0)
Function DoubleRateA(clip c,Bool "Blend",Bool "Flow") {
    # Overlap = 0
    c
    bw_1      = MAnalyse(super, chroma = false, isb = true,  blksize = 16, OverLap=0, searchparam = 3, plevel = 0, search = 3, badrange = (-24))
    fw_1      = MAnalyse(super, chroma = false, isb = false, blksize = 16, OverLap=0, searchparam = 3, plevel = 0, search = 3, badrange = (-24))
    Return (!Flow)
Function DoubleRateB(clip c,Bool "Blend",Bool "Flow") {
    c
    bw_1      = MAnalyse(super, chroma = false, isb = true,  blksize = 16, OverLap=8, searchparam = 3, plevel = 0, search = 3, badrange = (-24))
    fw_1      = MAnalyse(super, chroma = false, isb = false, blksize = 16, OverLap=8, searchparam = 3, plevel = 0, search = 3, badrange = (-24))
    Return (!Flow)
Function DoubleRateC(clip c,Bool "Blend",Bool "Flow") {
    c
    Return (!Flow)
        \ ? MBlockFps(super,bw_2, fw_2, num=FramerateNumerator(c) * 2, den=FramerateDenominator(c), Blend=Blend, mode=0)
Shows Synthesized frame, not at scene change, motion coming in from RHS.
TopLeft, original frames, every other one a duplicate,
Top Right, Overlap=0,
Bot Left, New version MvTools, Overlap=8
Bot Right, Old, Overlap=8, with MRecalculate.
All seems to be working OK, for block/Flow/FPS.
Script to show problem in MSCDetection, no requrements.
FN="LowBitrateAnime.AVI"
Avisource(FN)
Function EndOfSceneClip(clip c,Int "thSCD1",Int "thSCD2") { # All Luma Samples set 255 at EOS
    thSCD1=Default(thSCD1,400)  thSCD2=Default(thSCD2,130)
    sup=c.MSuper(pel=1,sharp=0,rfilter=2,hpad=16, vpad=16)
    bv=sup.MAnalyse(isb=true, delta=1,blksize=16,overlap=8)
    Return c.MSCDetection(bv,thSCD1=thSCD1,thSCD2=thSCD2)
Function StartOfSceneClip(clip c,Int "thSCD1",Int "thSCD2") { # All Luma Samples set 255 at SOS
    fv=sup.MAnalyse(isb=false,delta=1,blksize=16,overlap=8)
    Return c.MSCDetection(fv,thSCD1=thSCD1,thSCD2=thSCD2)
EOS = EndOfSceneClip
SOS = StartOfSceneClip
#return EOS
SSS="""
    e = EOS.AverageLuma
    s = SOS.AverageLuma
    Subtitle(String(current_frame)+String(e,"] EOS=%.1f")+String(s," : SOS=%.1f"))
    (e!=0.0)
        \ ? Subtitle("End Of Scene",Size=48,Text_Color=$FF0000,Y=Height/2-24,Align=5)
        \ : (s!=0.0) ? Subtitle("Start Of Scene",Size=48,Text_Color=$0000FF,Y=Height/2+24,Align=5)
        \ : NOP
    return last
Scriptclip(SSS)
We are nearly there
EDIT: Oh damn, meant to put the MBlockFPS example up on PhotoBucket instead of MFlowFPS, arh well done now.
EDIT: MBlockFPS version
EDIT: Above image lost due to Photobucket problem.
EDIT: The Blending mentioned in the quote at top of post is shown on Right Hand Edge of lower two (Overlap) images in
both image sets (dark edge, sourced from next image coming from rhs).
Old 17th November 2016, 19:40   #96  |  Link
pinterf
I'm not saying I'm ready, this is just a new test build inspired by StainlessS
http://www.mediafire.com/file/k78dcm...tainlessS4.zip
There were side effects again, ported some more mvtools2 filters to native 10-16 bits and fixed some bugs.
Recent change log
  • 20161117: MFlow, MFlowInter, MFlowBlur: native 10-16 bits
  • 20161117: MSCDetection: fix scene change filler pixel default value
  • 20161117: MFlowFPS: native 10-16 bit
  • 20161117: MCompensate: native 10-16 bit + possible bugfix bottom padding UV
  • 20161117: Fix SAD for 10-16 bit depths for horizontal block sizes >= 16
  • 20161116: MBlockFPS: Additional overlap fixes (bottom lines)
  • 20161116: MBlockFPS: native 10-16 bit with Avisynth plus
  • 20161116: MBlockFPS: additional overlap fix (Right)
  • 20161115: Fix nSCD2 (Scene change threshold block count %) (2.7.1.22 regression)
  • 20161114: MBlockFPS overlap fix test build (copy buffer to output)
Short status report on the 8+ bit transition:
MShow, MDepan are not yet ported to 10-16 bits. You can try the others, e.g. MDegrains for 10+ bits with Avisynth plus.
EDIT: MFlow, MFlowInter, MFlowBlur ported, removed from the non-16 bit list.
And of course you can freely use 4:2:2 and 4:4:4 formats.
(like YV16 and YV24)
Last edited by pinterf; 17th November 2016 at 20:58. Reason: MFlow, MFlowInter, MFlowBlur ported
Old 18th November 2016, 12:25   #97  |  Link
Thanks pinterf, everything seems hunky dory,
I'll continue to use this version and report if I find any anomalies, again thanx.
EDIT: I'll probably be using something like below
Function ChangeFrameRate(clip c,Bool "Blend",Bool "Flow",Int "Num",Int "Den",Int "BlkSize",Int "OverLap") {
    # Req MvTools2 v2.7.1.22+ for Overlap>0
    BlkSize=Default(BlkSize,16)     Overlap=Default(Overlap,BlkSize/2)
    n=Default(num,0)  d=default(den,0)  valid=(n>0 && d>0)    n=(!valid)?c.FramerateNumerator*2:n    d=(!valid)?c.FramerateDenominator:d  # Default = doublerate
    super   = c.MSuper(pel=2, hpad=BlkSize, vpad=BlkSize,rfilter=4)
    bv      = MAnalyse(super, chroma=false, isb=true,  blksize=BlkSize, OverLap=OverLap, searchparam=3, plevel=0, search=3, badrange=(-24))
    fv      = MAnalyse(super, chroma=false, isb=false, blksize=BlkSize, OverLap=OverLap, searchparam=3, plevel=0, search=3, badrange=(-24))
    Return (!Flow)
        \ ? c.MBlockFps(super, bv, fv, num=n, den=d, Blend=Blend, mode=0)
        \ : c.MFlowFps(super,  bv, fv, num=n, den=d, Blend=Blend)
Function DoubleRate(clip c,Bool "Blend",Bool "Flow") {Return c.ChangeFrameRate(Blend,Flow,c.FramerateNumerator*2,c.FramerateDenominator)}
Old 18th November 2016, 23:18   #98  |  Link
pinterf
Thanks, StainlessS, you were excellent, first class tester. You really deserve a new mvtools3 that can realtime interpolate the two suns of tatooine on a ZX81.
But until then I will just bump the version numbers and make a release soon.
Good news for me that finally I have finished porting the last two filters, MDepan and MShow for high bit depth, and also finished the two other DLLs for video stabilizing with Depan (DepanEstimate) and DepanStabilize.
Old 19th November 2016, 19:46   #99  |  Link
pinterf
New release:
  • MvTools2 2.7.5.22 (20161119)
    General support of 10-16 bit formats with Avisynth Plus (r2294 or newer recommended)
    with new MDegrain4 and MDegrain5 filters.
  • Depan: 2.13.1 (20161119)
  • DepanEstimate: 2.10 (20161119)
    Compiled for 64 bit for the first time
    Supporting YV16 and YV24 for 8 bit and their 10+ bits equivalents
    Requires 2.6 interface
Download:
MvTools 2.7.5.22 + Depan + DepanEstimate for 32 and 64 bits
For general info see readme or the first page of the thread.
Have fun.
Todo:
  • greyscale support (not tested)
  • Port remaining inline assembly to SIMD intrinsics
  • satd 16 bit to SIMD
  • fix reported bugs
Old 19th November 2016, 19:56   #100  |  Link
Sparktank
47.952fps@71.928Hz
Sparktank's Avatar
Great work, guys!
Win10 (x64) build 19041
NTSC | DVD: R1 | BD: A
AMD Ryzen 5 2600 @3.4GHz (6c/12th, I'm on AVX2 now!)
