Go Back   Doom9's Forum > Video Encoding > (Auto) Gordian Knot
Old 21st June 2009, 03:46   #1  |  Link
MPAA
Poor and angry.
converting 1920x1200 to 1680x1050 ???
i have video clips at 1920x1200. i want them to be converted to 1680x1050. can agk do this itself ? if yes how ?
§ Pimp of Mario's World. Hater of society. §
MPAA is offline   Reply With Quote
Old 21st June 2009, 06:47   #2  |  Link
netmask
netmask's Avatar
What do you mean converted? Do you mean cropped ie removing bits from the top and bottom and side or what?
If you want to crop then open the 'secret menu' in AutoGK (cnt F9) and take a look at the possibilities. You can also force aspect ratio's of 16:9, 4:3 and original.
A bit more information would be helpful
SONY 75" Full array 200Hz LED TV
Yamaha A1070 amp
Zidoo UHD3000, Popcorn Hour A-500
BeyonWiz PVR T3 & V2 (Enigma2 clone)
Chromecast
Pioneer Bluray BDP-150-K
Windows 7 Ultimate
QNAP NAS TS851
netmask is offline   Reply With Quote
Old 21st June 2009, 07:18   #3  |  Link
MPAA
Poor and angry.
ok, i capture game clips using fraps at my native lcd resolution of 1920x1200. when i upload them to youtube they have black bars on the left/right and don't fill the whole "available space". i want to crop? my 1920x1200 clips to a size that will make it so that the youtube hd clips have no bars anywhere. as a test, i played a game at 1680x1050, recorded a clip, uploaded it to youtube, and it was perfect - no bars and it took the whole space. but i don't want to play games at less then my maximum resolution.
Old 21st June 2009, 12:42   #4  |  Link
Arshad07
Jeremy Duncan Fan
Arshad07's Avatar
^Post a sample
Arshad07 is offline   Reply With Quote
Old 21st June 2009, 14:27   #5  |  Link
Keiyakusha
契約者
Keiyakusha's Avatar
MPAA
You can Crop your video to 1920x1080 and then resize to 1280x720. Avisynth will help you here, don't know about AGK.
Old 22nd June 2009, 05:40   #6  |  Link
MPAA
Poor and angry.
Originally Posted by Arshad07 View Post
^Post a sample
doesn't this forum let you embed youtube clips directly ?
here's one:
link removed
Originally Posted by Keiyakusha View Post
MPAA
i'll look into it, avisynth. but i don't think after i crop it to 1920x1080 i should then also resize it to a lower resolution. i'll just upload it as is and let youtube do whatever it does. otherwise the quality may be worse.
Old 22nd June 2009, 11:50   #7  |  Link
manono
1920x1200 has the same 1.6:1 aspect ratio as 1680x1050, so I'm not sure why one works to do what you want but not the other. They both should have small black bars on the sides.
You might try adding this to your tags and see if it does what you want:
yt:stretch=16:9
http://help.youtube.com/group/youtub...9062509a070a0#
Old 22nd June 2009, 12:17   #8  |  Link
MPAA
Poor and angry.
i doubt it's me alone. as far as i know this will happen to anyone who uploads a 1920x1200 clip to youtube. as a test why don't you try it ? record a clip, even a short one, say 10 seconds at 1920x1200 and simply upload it to youtube - without any modifications whatsoever. (except akg to shrink it's actual size, which is what i do.) you will have two large black bars on the left and right sides. i also uploaded a 1680x1050 clip as seen here (http://www.youtube.com/watch?v=57kwfK4bCKE&fmt=22), which has no bars and is a full "screen" clip. i don't understand why this happens.
edit: and actually, the above gtr2 clip was recorder at 1680x1080 so that's why technically even this video has very tiny black bars at each side. just now i'm uploading a proper 1680x1050 clip and will post the link here.
edit 2: why aren't questions fully answered here ? i asked why this forum doesn't allow embedding youtube clips directly into the forums. links are so passe. (unless they do, and then, what's the code?)
Old 22nd June 2009, 12:35   #9  |  Link
manono
yt:stretch=16:9
The reason why I didn't answer the embedding question is that I don't know why this forum doesn't allow embedding of YouTube videos. Nor do I much care whether it does or not.
Old 22nd June 2009, 13:20   #10  |  Link
@MPAA
Keep your posted vids clean per forum rules.
Old 22nd June 2009, 13:51   #11  |  Link
MPAA
Poor and angry.
yt:stretch=16:9
thanks man, that seems to do it..
you're the man.
proof that youtube is just plain stupid. it's obvious with this fix, that it's something on their side. anyway all is cool now, since i can continue to play my games at 1920x1200 and not have to downgrade to a lower resolution.
again.
youtube
