Old 23rd April 2009, 10:27   #1  |  Link
teedoubleyou
Changing start timecode of h.264?
Hi all,
I've had a look around but can't seem to find an answer.
Is it possible to change the start timecode of an h.264? Basically something along the lines of restream which I can just change it from 01:00:00:00 to 10:00:00:00 for example.
Thanks in advance.
teedoubleyou is offline   Reply With Quote
Old 6th May 2009, 16:03   #2  |  Link
teedoubleyou
bump
Sorry to do this, I realise it's irritating but after much searching I still haven't found anything that can do this.
I came across TSPE (http://www.videohelp.com/tools/TS_Packet_Editor) which is a great tool, but unfortunately is meant for editing Transport Streams, where as I need something to edit the ES.
Just looking at editing the first GOP timestamp.
Cheers.
Old 6th May 2009, 17:50   #3  |  Link
What AVC ES timecode are you referring to? GOP headers don't exist in AVC.
Old 7th May 2009, 10:13   #4  |  Link
teedoubleyou
That's a good start -- explains a lot.
I'm referring to the start time code of an AVC/H.264, which has a start timecode of 01:00:00:00 but I would like to change to 10:00:00:00.
Old 7th May 2009, 10:29   #5  |  Link
Dust Signs
There is no such time stamp in H.264/AVC streams. Perhaps you are referring to the time code which is specified in your container? In this case you might want to change the start time stamp of the video track in the container if the container supports that. What container are you using anyways? MKV, MP4, MPEG-2 TS?
Dust Signs
Note: if this is (as I assume) related to the container you are using, this should be moved into the container discussion forum
The number you dialed is imaginary. Please turn your phone by 90° and try again
Dust Signs is offline   Reply With Quote
Old 7th May 2009, 11:16   #6  |  Link
teedoubleyou
Ahhh right, thanks for the information.
It's an MPEG-4, in which case you're right it's a container issue.
Old 7th May 2009, 13:33   #7  |  Link
Originally Posted by teedoubleyou View Post
It's an MPEG-4
Then why does your thread title specifically say H.264?
Old 7th May 2009, 14:02   #8  |  Link
buzzqw
HDConvertToX author
ugly avi+h264 ?
BHH
AutoMen: The Mencoder GUI
AutoWebM: supporting WebM/VP8
Old 7th May 2009, 14:05   #9  |  Link
My bad. I thought he meant MPEG4 ASP video.
Old 7th May 2009, 15:21   #10  |  Link
teedoubleyou
Sorry if I'm confusing anyone it's not my intention.
I have an AVC/H.264 which I am using for authoring -- I wanted to change the start timecode as the subtitles were not 10 based, rather they were 01 based. I have since repaired the problem, but for future reference it would have been a lot easier to change the start timecode of the asset. In DVD Authoring you can just use Restream, so I was hoping someone might know of a tool that I could use to do the same but for a BD.
I wasn't aware of them being in a container, which seems where I'm causing some confusion.
h.264, restream, timecode
