Old 21st June 2021, 01:11   #19181  |  Link
Pauly Dunne
Grumpy Old Man.
Pauly Dunne's Avatar
Originally Posted by frencher View Post
It is better for me to wait for the future CPU, I suspected a little.
Well, you could at least give it a try.
Don't forget you can use DE on 1 PC, it's just a little different with the IP address's.
Although, seeing you use a Wireless network, you may not need to change anything.
For example, I'm on a wired LAN, with 192.168.1.X's, and if I want to use just the one PC with DE, I just need to have the network switch / hub powered on.
otherwise-----
I think the IP address you'd need to use is 127.0.0.1, with the :1000 as well.
Nothing ventured, nothing gained.
Not poorly done, just doin' it my way !!!
Pauly Dunne is offline   Reply With Quote
Old 23rd June 2021, 22:36   #19182  |  Link
Ryushin
Originally Posted by Ryushin View Post
Hi Atak,
I've been having a memory error from x265 since the latest update:
x265_x64.exe - Application Error
The instruction at 0x00007FF701D6E902 referenced memory at 0x0000000000020000. The memory could not be written.
Click on OK to terminate the program
Same VM system that has been running for years with ECC memory. Did not install any windows updates in the last week or so. Only the RB update has occurred, but I'm not sure if it was this last update, or the update before that.
Installed the latest Windows updates and rebooted. Memory error went away. there was probably something residual left over after RB updated. The reboot probably fixed it.
Ryushin is offline   Reply With Quote
Old 24th June 2021, 18:30   #19183  |  Link
StormMeows
Hey guys, long time lurker here. I am planning to soon encode a lot of my blu-ray backups and want to maintain the best quality. I was originally going to do staxrip with my NVIDIA GPU but the more I researched it, I do not feel like the quality is up to my standards. Most of the GPU encoding I saw loses a lot of detail from the original bluray source. Would Ripbot be a good program to do x265 bluray backups? I want to be able to get the best possible quality as the original source and retain the lossless audio tracks on all of my encodes. If this is a great way to go, I plan on getting a better encoding PC dedicated to my encodes. Also, is there a guide anywhere that goes over what are good extra advanced settings I can use on all of my encodes? I want the encode to look similar to the orginal. I am fine with a bigger file size as well (as long as it is smaller by at least 20% of the original). I would really appreciate any guidance. Thanks guys!
StormMeows is offline   Reply With Quote
Old 24th June 2021, 23:40   #19184  |  Link
Ripmann
Just updated and immediately noticed that the output line is now editable. Thanks a lot, Atak. Major time saver. I don't think I'll ever be using the Save As dialog anymore.
I have a quick noob question: is there a lossy codec similar to AC3 that allows you to keep all 7.1 channels, not just 5.1? I can't afford to use uncompressed DTS or TrueHD audio and having the audio track being almost the same size (if not more) as the video track, but I'd like to keep all channels at least for some of the encodes as well. Is there a solution for this? I'm sure there must be, but I just got my first modest 7.1 system and this is the first time I have to worry about this.
Originally Posted by StormMeows View Post
...Would Ripbot be a good program to do x265 bluray backups? I want to be able to get the best possible quality as the original source and retain the lossless audio tracks on all of my encodes...
It definitely is. I've been using it for years and it's fantastic, there's no other word for it. I believe it was designed to be noob friendly, so you should be able to dive right in. Once you get the hang of it, you'll be able to optimize your encodes further and further. I highly recommend you try it.
As for the advanced settings, most of this stuff is fairly self-explanatory. It also depends on what you exactly you want and the kinds of video files you'll be processing. You may have to look up some of the terminology, but other than that, you'll probably be better off by taking a small sample file and doing several attempts to see how it looks on various settings, asking for help with specific issues, once you encounter them. Hope this helps.
Ripmann is offline   Reply With Quote
Old 25th June 2021, 00:31   #19185  |  Link
StormMeows
Thank you! I am glad to hear that it is newb friendly. I am going to do research on these advanced settings. Trial and error is going to be key. When I do a sample, how do I know what scenes of movies to test? Are there certain scenes that I need to test (like dark scenes or action sequences)? Or do I just encode the first 10 minutes of a film and compare it to the original? Is there a best practice that I can use for testing the samples so I can ensure I don't waste a whole day on an encode and there is tons of pixelation or similar in the final result? Thank you!
Old 25th June 2021, 01:50   #19186  |  Link
Pauly Dunne
Grumpy Old Man.
I "told" you about this, age's ago....have you been hiding under a rock ?
https://forum.doom9.org/showthread.p...90#post1945290
You must be compressing your encodes down a LOT, if the audio track is a similar size to the video track.
Old 25th June 2021, 02:02   #19187  |  Link
Pauly Dunne
Grumpy Old Man.
Hi StormMeows,
I wouldn't exactly say it was "newb" / "noob" friendly, but it is fairly easy to use, and I'm not too sure about these "Advanced Setting's" either, they're just "setting's" !!!
I'd say the complicated function of RipBot is the Distributed Encoding, now once you've sorted that out, you'll never look back.
Do you have more than one PC ???
What have you got in mind for your "new" encoding PC ???, something pretty powerful, I would suggest !!! (Ryzen 9 5950X)
Also, what is you main objective, meaning do you do a lot of 4K encoding ??
After reading your recent posts on other Forums, you have a pretty powerful system already, and also from what I understand, encoding & re encoding, is just a waste of time & energy (electricity), as you want to basically keep the movies "as is" !!!
SO...
If you want to keep the original size & quality of any of your video's (especially 4K), you'd be just as well off running them thru MKVToolNix, and removing any video, audio & subtitles tracks you don't need, and that's that...quick 'n easy, and will in most cases greatly reduce the file size.
It's just that any 4K encoding can take a very long time, especially if you're using "strong" filter's.
But like Ripmann suggested, grab a sample or a short video, and just test any settings that you think that particular file needs, to "look good", in your eye's.!!!
Old 25th June 2021, 05:14   #19188  |  Link
Ripmann
Sorry, missed it. As I said, busy month. Never had a chance to update RipBot before today, let alone have enough time to read the forums.
An uncompressed TrueHD 7.1 stream for a 90-minute movie is 2.5GB. If my goal is to make a 4.37gb DVD-sized encode, that's 57% of the overall file wasted on audio. Even if it's a 7.94gb encode, it's still 31.5% of the total. Clearly a waste of space, especially considering that the 640kbps 5.1 AC3 version for the same file is 413mb. If there's a way to compress that 7.1 to half a gigabyte, I'll gladly take it. Who wouldn't?
Old 25th June 2021, 07:21   #19189  |  Link
Pauly Dunne
Grumpy Old Man.
Hey Ripmann,
Well, unfortunately, I have no use for 7.1 "anything" as my Home Theatre only supports 5.1.
I was going to a lot of trouble to convert THD to DTSMA with eac3to, and another old app that I can't recall the name of atpit.
But then I found a quick way to convert pretty much ANY audio to E-AC3, using eac3to, (which is still 5.1), but it sounds pretty good to my old ears.
Unfortunately, RipBot doesn't convert THD to much, or at least E-AC3, but there other ways.
Anyway, we all have different ways of doing things that we want, just a shame that there isn't just one app, that will do it all.
Imagine combining Handbrake, Straxrip, Hybrid & RipBot, together.
https://forum.doom9.org/showthread.p...13#post1945413
Old 25th June 2021, 15:41   #19190  |  Link
Ripmann
Damn, I stopped actively following the codec scene a long time ago, but I was expecting that an easy 7.1 solution was out there, considering that such systems became widespread years ago.
I'm definitely looking up all the stuff you mentioned, though. RipBot is so convenient, familiar, and time-saving that I became utterly lazy relying on its features. I heard about E-AC3 a while ago but stayed with RipBot's AC3 anyway. Same with better degraining methods like SMDegrain. We discussed it more a month ago and I already did a dozen of jobs using RipBot's built-in denoising methods. Time to get off my butt and take a crash course in newer alternatives. Thanks for the pointers.
EDIT: From the first glance, it looks like E-AC3 supports 7.1 after all. Thanks again for the motivation.
Old 25th June 2021, 18:09   #19191  |  Link
chainring
chainring's Avatar
Yep, just lossy vs. TrueHD being lossless.
chainring is offline   Reply With Quote
Old 26th June 2021, 13:32   #19192  |  Link
Ripmann
Atak, how difficult would it be to fully switch to E-AC3? After playing with it for a bit, it looks like a superior successor to AC3 in every possible way. Up to 15 channels, Atmos compatibility, much higher maximum bitrate, better compression algorithm, etc. Would it be too time consuming for you to implement it at this point?
Old 26th June 2021, 13:57   #19193  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
Does ffmpeg even support E-AC3 7.1 encoding?
Old 26th June 2021, 14:45   #19194  |  Link
Pauly Dunne
Grumpy Old Man.
Not yet it don't, and I've been looking !!
Handbrake, clever FFmpeg-GUI, & Axiom can change nearly any format to E-AC3, but the max is still only 5.1.
Also, a certain procedure using eac3to, with the help of FFMPEG, can do conversions to E-AC3, up to default E 640, but you can edit that value, and I use 1536.
But a downmixed THD or DTS 7.1 to E-AC3 5.1 sound's pretty good, if you run it @ 1536.
If you could (and I know you could) add an E-AC3 option, that would be brilliant
Old 26th June 2021, 21:36   #19195  |  Link
g0th1ckn1ght
Hi all, i have recently come back to Ripbot for backing up my blu rays. Can any offer any advice on how i use Ripbot. I run anydvd hd along with ripbot
insert blu ray into drive
I open the stream and demux the bluray using ripbot (demux audio as well to keep original uncompressed audio as well as any subtitles i need)
I then select hevc and copy stream for video
Copy stream for audio
Add subtitles (including forced)
Then hit done and it starts remuxing
So far the quality has great (as far as i can tell, no difference between inserting the disc into the player vs watching my ,mkv's via Kodi)
Large file sizes are not a big deal for me, video and audio quality are
g0th1ckn1ght is offline   Reply With Quote
Old 27th June 2021, 01:59   #19196  |  Link
Pauly Dunne
Grumpy Old Man.
Nearly 6 years since your last post.....
Not too sure why you're asking, you have described your process, that works for you, just carry on.
What else do you want to know ??
Old 27th June 2021, 11:58   #19197  |  Link
g0th1ckn1ght
I was just wondering if there was anything else i am missing or if this method is the best way to get the best quality
Old 28th June 2021, 01:11   #19198  |  Link
Pauly Dunne
Grumpy Old Man.
I would say that the way you are doing it, is probably the quickest way, and you maintain the original video & audio quality, so like I said before, if you're happy with that, then by all means continue doing that.
Once you start using different filters, for removing grain or noise, then it becomes a different & slower process.
Sometimes you can "clean up" the video, and actually make it look better than original, unfortunately, too many movies have grain & noise, which can be filtered out, however, there are ppl out there that like the "feel" of some grain & noise.....me, not so much, the clearer & cleaner the better.
It's all in the eye of the beholder (as they say).
Old 28th June 2021, 01:22   #19199  |  Link
g0th1ckn1ght
Thank you for the advice. I am going for the "as close to original" as I can get.
I do understand what you mean about noise an grain though. Doesn't always look the best.
Thanks again
Old 28th June 2021, 16:56   #19200  |  Link
kempodragon
Update on using Ripbot with3-D movies
After much experimentation, I've partially succeeded in getting Ripbot to encode my 3-D movies. First I tried loading the main view file, which is also used for 2D playback. I then copied the avs file that BD3D2MK3D generated into Ripbot's editor. When I tried previewing the file, I got the message it could not initialize the mvc file, and listed the line with the plugin.
To confirm that BD3 avs file wasn't the problem, I opened it with VirtualDub2, and, just for fun, I made an uncompressed full SBS file. I wanted to see how Ripbot would handle an uncompressed file, but at 1.6 TB it was too big to transfer to the ssd that I have Ripbot's temp file on.
Finally, I directly opened the BD3 avs in Ripbot. It opened with no problem, but took so long extracting the frame information that I thought Ripbot had locked up. Once it finished, I was able to preview it with no problems, so I crossed my fingers and tried encoding.
Here's why I partially succeeded. Ripbot encoded it with no problems, but DE would not start no matter what. Task manager showed nothing in the wait states, but did say the DE server was waiting for network I/O. I could not manually start DE either. There were no error messages, DE simply refused to start. Hopefully, Atak can figure this problem out because I would love to see what kind of encoding speed I can get with DE, since even w/o it Ripbot still managed a respectable 32 fps encoding a full SBS at level 5.0
kempodragon is offline   Reply With Quote
