Old 21st September 2016, 04:12   #61  |  Link
qiangbro
qiangbro's Avatar
Does AVSEditPlus support AviSynthPlus or AviSynthPlus MT-pfmod ?
It crashed when I launch avsEditPlus.exe.
the default charset of my windows system is GBK, it is a Chinese Language system.
avsEditPlus.exe 已停止工作
问题签名:
问题事件名称: CLR20r3
问题签名 01: avsEditPlus.exe
问题签名 02: missing
问题签名 03: 57c0ad79
问题签名 04: avsEditPlus
问题签名 05: 1.25.0.0
问题签名 06: 57c0ad79
问题签名 07: 135
问题签名 08: 0
问题签名 09: System.NullReferenceException
OS 版本: 6.1.7601.2.1.0.256.1
区域设置 ID: 2052
其他信息 1: 0a9e
其他信息 2: 0a9e372d3b4ad19135b953a78882e789
其他信息 3: 0a9e
其他信息 4: 0a9e372d3b4ad19135b953a78882e789
qiangbro is offline   Reply With Quote
Old 21st September 2016, 04:19   #62  |  Link
I believe that AvsEdit+ does support AVS+, so would guess that your problem relates to spoken language (or all of those squiggly bits in your post).
Old 2nd October 2016, 16:54   #63  |  Link
kagetoki
Author of AVSEdit Plus
kagetoki's Avatar
I'm sorry for the fatal error You keep getting, I'm going to find a solution asap. The text editor uses ANSI encoding while saving because AviSynth (at least 2.5x) reads files encoded only in this format.
AVSEdit Plus has been tested with the following:
  • AviSynth 2.58
  • AviSynth 2.60
  • AviSynth+ (AVSEdit Plus works only if x86 build is also installed)
kagetoki is offline   Reply With Quote
Old 30th April 2020, 15:46   #64  |  Link
keraki
How to open a .mp4 file with this app?
keraki is offline   Reply With Quote
Old 30th April 2020, 17:34   #65  |  Link
Look up LSmash plugin for Avisynth, LSmashVideoSource and LSmashAudioSource.
You'll find it in the Devs forum (no idea why some devs think users may not be interested in their plugins).
External (not Avisynth builtin) filters on wiki here:- http://avisynth.nl/index.php/External_filters
The App is for avisynth script, you will have to write some script.
avisynth editor, avisynth script editor, avsedit plus, encoder gui, side by side
